Question about Philips GoGear HDD6330 MP3 Player
Mp3 won't turn on
After I have charged my mp3 player and try to turn it on it will start to then turns off. I have tired to reset it but it won't work. It won't even register on my computer like my daugters. what do I do?
  • 8,596 Answers
Make sure the hold/lock switch wasn't accidentally engaged, then try this:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Feb 14, 2009
My mp3 player wont charge but will turn on when pouted in
connect the Sansa (via the player's USB cord) to different USB ports on the computer until the Sansa starts to charge. A weak or non-working USB port won't charge the Sansa.
  • Reset the Sansa MP3 player. Slide the player's "Power" switch all the way up to the "On" position. Hold the switch in that position for 20 seconds. The Sansa resets. Try to charge the player.
  • Install the latest firmware onto the Sansa MP3 player. Download the Sansa Firmware Updated (link in References), and then click the link in Resources for the specific model of Sansa you own to learn how to update the player's firmware.
  • May 01, 2012 | Kitchen Appliances - Others
    Hi I just recently charged up my mp3 player after a long time it's charged but lock screen won't come off I hit the reset still no success
    Hello if you see light the back light turned on and see nothing on the screen that mean the frame-wire is damaged and you need to buy new mp3. Or maybe the battery is not working change it as soon as possible and explain to the shop what is the problem. Please rate my comment
    Nov 20, 2011 | Samsung Napster YP-910 MP3 Player
    Hey my mp3 is not working when i switch onn no display???? helllpppp........
    Hi there
    You computer is probably frozen but this is how to solve the problem
    Flip the MP3 player's "Hold" switch to "Off" if the switch is on. Depending on the MP3 player you own, this switch is likely located at the side or top of the player. Once the switch is off, try to turn the player on.
    Let the battery of the MP3 player die. A frozen MP3 player is technically still running, and thus the battery for that player is being drained. Wait until the battery is fully dead before moving to Step 3.
    Charge the MP3 player using either a computer (that's turned on) or an electronic MP3 charger. Charging the player's battery may "jolt" the player out of its frozen state. Connect the player to the computer or charger via the player's USB cable. Charge the player for 30 minutes before attempting to turn it on.
    Sync the player with the appropriate software program (for example, Windows Media Player) for the MP3 player. Connect the player to the computer as described in the previous step. Open the software program and click the "Sync" tab at the top or side of the program. If necessary, click "Start Sync" underneath the tab. The name of the player appears under the "Sync" tab if the player has synced successfully. Try turning the player on once it has synced with the program.
    Press the small "Reset" button on the MP3 player. This hard reset shuts the player down completely. Use a pin, tack or thin nail to press down the very small "Reset" button on the side or back of the MP3 player to reset the player. Then, try to turn the player on.
    Oct 03, 2010 | BenQ Joybee 125 MP3 Player
    I ahve a no name mpe player and try to sart it and it just comes up with the loading symbol but will not go any further
    Hi there
    Sep 16, 2010 | Jwin MP3 Player
    I bought a refurbished insignia NS-DV2G and it didn't come with the software CD. Where can I get the required software?
    Hi
    Let the battery of the MP3 player die. A frozen MP3 player is technically still running, and thus the battery for that player is being drained. Wait until the battery is fully dead before you can unfreeze it
    Sep 16, 2010 | Insignia NS-DV2G MP3 Player
    My philips wont turn on and i reseted
    mine does the same thing!!! can anyone help??? i can't find a new one otherwise i'd replace it. it's the best mp3 player i've ever had, and trust me when i say i've had a lot!!!!
    Jul 01, 2009 | Philips SA5125/37 MP3 Player
    Won't turn on
    Take a paperclip and insert in the "reset" hole on the back of the MP3 player . After resetting press the center button on the front to start.
    Jul 03, 2008 | RCA S2001 MP3 Player
    Philips GoGear HDD6330 MP3 Player Logo
    Top Philips Audio Players & Recorders Experts
    Gyula Lacz
    Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
