Question about Sony Cyber-shot DSC-W30 Digital Camera
Camera goes bazerk, the E:91:01 keeps on flashing
I turn the camera on and these numbers are flashing, I know that I have not recorded anything, but I have tried to erase and can't do it. Help me to get the #s off of my screen.
  • Anonymous Mar 14, 2009
    I also have E91:01 flashing on my display and I cannot take any photos with the flash
  • mariaer Apr 08, 2009
    thank you sooo much. I am soo happy that my camera is now ready to take photos... ( :
Try re-initializing - it's been known to work with same problem.
Go to:
Menu
Setup
Setup 1
Initialize
OK
This will restart the camera. You will then be prompted to enter the date and time settings.
Posted on Apr 08, 2009
  • Sonyfreek Feb 22, 2011
    I had the same problem and did the re-initializing at least 10 times as the error message came back after a couple of pictures taken. Then I didn't touch the camera for a month and went to buy new camera and showed this errror message to the sales guy, did the re-initializing once more and the camera has worked perfectly since then! Have taken about 100 pics with different settings and it's still working. So don't give up on the re-initializing....
Red flashing light in the corner on canon rebel eos t3i
The flashing red light in the bottom right is the indicator that the camera is writing to the memory card. If you have shot in RAW this will take a little longer than recording a jpeg as the RAW files are larger. While this is happening the screen will go blank for a short time.
Jun 08, 2012 | Canon EOS 600D Rebel T3i Digital Camera
Recording disabled
This is just one of those problems that come associated with this type of camcorder. Try recovering the data by downloading the program at the following link and trying to fix this problem with it. Please let me know how this goes and if it doesn't work let me know as I would be glad to keep trying to get this fixed. I don't believe you did anything wrong but I would call Sony about this and see if they have any new suggestions for this. Personally I would return the player since the quality isn't as good as other cameras.
http://www.download.com/IsoBuster/3000-2248_4-10208087.html
good luck
May 28, 2008 | Sony Handycam DCR-DVD92 DVD Camcorder
I cannot record, in the corner where it says record, standby, it flashes the number C:31:40 I have a new TDK Hi 8 120 and it keeps flashing. Please help, thank cptaylor2000@yahoo.com
when problem occur while cam is operating, the self-diagnosis function starts working, and may display the service mode display code. in your case, C:31:40, pertains to a part of the cam tape compartment mechanism called the drum that doesn't start up. issues could prevent you from recording, playing back tapes, rewinding or fas forwarding. t/s steps are: try diff tapes esp. w/prev recordings, reset cam (press reset button while cam is on, located just below the menu button, in the panel where the lcd screen goes to), power reset (remove batt and ac adapter and leave cam w/ any power source for at least a minute). if issue persists, unit will require repair. hope this helps.tnx:)
Jul 21, 2010 | Sony Handycam DCR-TRV340 Digital Camcorder
Hi there ...I have the Kodak V803 Digital Camera..a week ago i left the camera in a -10 cold temperature in the glove box in my car..the problem is, when i try to take a shot, after the flash the screen...
1. Try to fully recharge the batteries, and then, use them in camera.
2. Keep your camera in warm environment (not too much close to hot surface) for 2-3 hours.
3. Now, check your camera performance.
please rate me if it helps..tc! :)
Jan 08, 2010 | Kodak V803 Digital Camera
"menu" button not working-wont record or play back tapes
when the light flashes it means that there is an error definetly.
turn the menu button on off position first and remove the battery.
reinsert battery and turn on recording mode.
Try to remove the tape and reinsert it and see if the operating light is clear.
let me know if the functionality is restored.
Oct 05, 2008 | Panasonic NV-DS65 Mini DV Digital...
Nokia N73 Music edition Camera flash adjustment
  1. Open your camera
  2. Select "options"
  3. Select "Restore camera settings"
  4. Click "yes"
That should fix the flash. If not format the phone:
Format the entire phone. This will delete everything on the phone, but so back up pics, videos, etc on the memory card.
To format:
1. Turn off phone
2. Hold the following keys down WHILE it's turning back on:
3. (3 + * + green call key)
4. Do not let go till it asks about your location
5. Let johnny_20 know how it goes :)
Jul 09, 2008 | Nokia N73 Cellular Phone
Sony cyber shot camera 2004
Perhaps you have set the camera to a record mode other than Auto. Twilight mode for example, does not activate flash so as to set the camera on a tripod and shoot dark landscapes.
Check your camera record mode, and use auto or portrait mode, which they usually activate flash when there is not enough light.
Hope this helps.
May 15, 2008 | Sony Cyber-Shot DSC-P92 Digital Camera
Sanyo Xacti VPC-HD1- doesn't do anything in record mode
As I have been writing on other HD1/2 problems, sometimes it can be the card which is an issue. If the card is too slow or perhaps corrupted then the device can find it difficult to record.
This and other soft faults (that are reperable by turning the power on and off, changing or reinserting the card, removing the battery) are often indicated by a flashing red recording light.
Apr 25, 2008 | Sanyo Xacti VPC-HD1000 Flash Media...
Olympus D-425 won't take pictures
donĀ“t try to do anything, that cameras are a pain for the service centre, i repaired some myself and sometimes after i replaced all the boards, just have 2, it would die, without any reason ate all. just send it to a service centre u have a 2 year warranty, use it
Jan 14, 2007 | Olympus Camedia D-425 / C-170 Digital...
Trays locked
Hi, I had the same problem and i found out that if you hold down the fast forward and the rewind buttons with the power on and off button it will reset. It took me a couple of goes but after a while it worked. When you do it keep all of the buttons held down and a series of numbers flash for about a minute then it will reset. Good luck, Jeff.
Nov 15, 2006 | Philips CDR796 2-Disc CD Recorder
Sony Cyber-shot DSC-W30 Digital Camera Logo
105 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
