Question about Roper RES7646KQ Electric Dryer
Dryer Belt Roper RES7646
I bought areplacement belt but can not find the pulley. I have taken off the top ( where I just lifted out the broken belt ) I have taken the front screws lose but the belt was across the back portion of drum. Is it in the front or back. And what has to be removed to get to the pulley ?
  • 2 more comments
  • cheryls_hous Feb 11, 2009
    So if I put the belt around the drum from the front I should just look under the drum to see the slots your talking about ? I was looking to route the belt through the pulley according the diagram that came with the belt.
  • Anonymous Feb 12, 2009
    belr seems to long
  • chuckshd419 Feb 12, 2009
    show diagram of belt and pulley
  • cheryls_hous Feb 15, 2009
    Mine was not like a typical pulley but more ike a flat piece of metal
    with a half pulley ( more like a guide than pulley ) on top. When I found it I thought it was a broken piece but that was it. I looped the end up and around the smaller pulley coming out of the motor and it worked out great !!
    Thank you guru !
    President:
  • 1,314 Answers
The front has to be removed to re place the belt lift the top takeout the two screws holding the front on unplug the door switch then kinda snap the door forward the drum should stay put and then but the belt on and you should find the pulley it fits in a slot in the bottom part of the drier put it in its slots pull it back to put tension it then let it back to keep tension on the belt
Posted on Feb 11, 2009
  • robert samples Feb 11, 2009
    pretty much you should see the marks on the drum where the old belt was running just look around tat area for the slots
Is thei a pulley I don't see
Posted on Feb 12, 2009
How to replace dryer belt
Under the top at the front right and left corners are two tabs.Push in with a flat object(butter knife).The top will pop open.lift it.Look at the top of the inside front.Take of the two bolts.Then take off the front.You will see the broken belt looped around a pulley.You will have to configure the new belt around the drum and pulley.This applies to most dryers.
Oct 19, 2013 | Roper Dryers
Roper gas dryer wont tumble
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else.
Leave the drum in the machine. Now, directly in front of the motor on the floor of the dryer you will see two slots. This is where the idler pulley will go. You'll notice on the pulley at the bottom of the bracket a piece of metal sticks downward. This will sit in the slot closest to the dryer wall, and the end of the bracket will slide into the other. You'll want to slide the end in first. Now with the pulley in place take the belt and put it around the drum tread side down. To hook the belt around the motor pulley you'll have to pull the idler pulley towards closest dryer wall and place the belt around the motor pulley. Slowly release the idler pulley and thats it. Put it together and your done.
Jun 03, 2012 | Roper Dryers
Belt is loose around the dryer drum
May 19, 2012 | Roper Dryers
Tumbler not turning
Hello, W/D here.
When you turn the dryer on, listen for the sound of the motor running. If you an hear the motor, the belt is probably broken.
Disconnect the power, and open the back. If the belt is broken, it should be obvious. Get a replacement belt from your local appliance parts store. Place the belt on the drum (you should be able to see where the old belt was running on the drum). Place it on the motor pulley. Lift the tensioner pulley past the belt, and slowly bring it back to the belt, placing it in tension. Roll the drum several turns by hand to get everything in alignment, and close the back up.
Best regards, --W/D--
Apr 01, 2011 | Roper Dryers
KitchenAid Electric Dryer KEYS700G turns on and heats up but drum won't spin.
You probably have a broken belt or your belt has slipped off of the idler pulley.
I will send you what works on a Whirlpool,Roper, and numerous dryers, maybe it will work for you.
http://www.applianceaid.com/images/belt-config.JPG
If you hear a loud bang while your dryer is working, and you notice that the
drum has stopped turning, chances are the drivebelt has snapped.
Fortunately, replacing the belt is a fairly straightforward operation that
can be handled with a few simple tools.
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Dec 31, 2010 | KitchenAid KEYS700LQ Electric Dryer
GOT A SQUEAK AND NEED TO REPLACE DOOR GASKET NEED TO LOOK AT BOOK ROPER DRYER MOD.REX4634JQO
The Roper is manufactured by Whirlpool. Your REX4634JQO should be identical to the Whirlpool LER 4634 J. Go to Roper's website at www.roperappliances.com/support to see about getting a manual. If you want to get at the problem without waiting for a manual, take a putty knife and slide it under the top of the dryer at the two retaining clips to pop it open and tilt the top back exposing the top of the drum. Then open the bottom panel and take the belt off the motor pulley. You should then be able to lift the drum out of the enclosure. Clean off the ball and socket at the back of the drum and apply fresh grease. Clean the lint off the idle rollers at the front of the enclosure and make sure they turn freely. Clean the surface where the belt rides and clean off the belt, then reassemble. If the belt is glazed, frayed, cracked, or shows any other wear or damage, do yourself a big favor and replace it now. I think the last one I bought was about $12 and will save you the trouble of doing all this again when the belt does finally fail.
Mar 04, 2009 | Roper REX4634KQ Electric Dryer
Repair book for Belt replacement Roper REX5634PQO
1. unplug dryer
2. popoff the top off
3. take front off (unscrew)
now you can get access to the belt look in bottom of dryer there is a giude wheel for the belt
4. place belt around drum and pulley make sure you add tenstion
5. replace front and top
Thank you for useing Fixya
Feb 12, 2009 | Roper REX5635E Dryer
Roper Dryer won't spin.
From what I understand, it sounds like the idler "pulley" is broken. Upon receiving power to the motor, the belt inter-connects and ultimately drives and rotates the pulley and drum. The pulley is designed to guide and give "tension" to the belt when connected to enable the drum to "rotate and tumble".
The pulley is relatively simple to replace and can be purchased from your local appliance dealer for about $10 - $15. Depending on your "handy" skills, I would take the following steps to check your belt and pulley;
1. Disconnect the Dryer
2. Access the dryer cabinet/pulley by removing the front door (If your pull and clean fileter from top, remove 2 screws near filter. You may need a putty type knife to "slide and pop" the dryer open)
3. You may see the dryer belt already broken or disconnected, but take a look at the pulley and check for broken wheel, metal, chips/cracks, etc. Sometimes you may need to replace the pulley all together, but you may only need to replace the wheel part depending on the model of your dryer.
-Maintuniverse
Feb 01, 2009 | Roper RGX4634KQ Gas Dryer
Where is belt on dryer and how to fix drum won't turn
The belt on a roper dryer is inside the body, accessed and changed as follows
  • unplug dryer(220v is Not Fun)
  • remove lint screen
  • undo screws inside lint screen holder, screwing it to case lid (so lid can tilt up)
  • with putty knife or other blunt blade, release spring catches under front corners of case lid
  • raise case lid
  • remove screws 1/3 way down front corners of body holding front panel on
  • remove door switch cable from door switch
  • lift door off set aside
  1. drum motor felts and bearings are now accessible.
  2. lift drum and withdraw fully forwards
  3. with drum removed check support rollers for free movement, check drum slides and/or drum felts for wear, easier to replace now, if worn, than have bearings or slides cause belt to break again.
  4. loop belt loosely around drum at wear marks from prior installation
  5. reinsert drum onto rollers bearings slides felts as installed.
  6. loop belt around motor pulley
  7. pull tensioner pulley against spring to end of its travel
  8. loop belt around tensioner pulley
  9. relax tensioner pulley to tighten belt
  10. rotate drum by hand to ensure belt is aligned
reassemble case in reverse order.
Notes
There are not many belt, felt, support roller sizes the local parts guy will have a belt, felt, roller to fit,
Tensioner pulley may not be in place, breaking belts often pull them out of their mounts, the pulley and spring will be lying on the case floor, there is only one way they fit in to their mounts so they are easy to reinstall
tensioner sketch is approximate, pulley may be on top run pulling down, or bottom run pushing up
the repair is easy, it takes longer to type or read this than it does to repair the dryer
Belts ~$14 Support Rollers ~$14/pair, felts/slides upto ~$25
New dryer +$200 - its a good repair
May 07, 2008 | Roper REX4634KQ Electric Dryer
DRUM WON't TURN on my Roper Dryer
you can put the back back on, remove the 2 screws under the lint filter( if ones mounted to top of machine ), then the top tips back revealing 2 5/16 screws holding the front panel on. lift off hte panel and string new belt arond drum and hook ove rht e motro pulley , first passing the belt through the idler tension pulley. belt number is a 341241
Mar 12, 2008 | Roper RES7646KQ Electric Dryer
Roper RES7646KQ Electric Dryer Logo
209 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
