Question about SanDisk Sansa Clip MP3 Player
Sansa mp3 can not connect device
  • 8,596 Answers
Make sure that the hold/lock switch was not accidentally engaged. Also, make sure you ran the installation CD. If you have lost the CD, get the needed software from Sandisk's website.
-Tha Mp3 Doctor
Posted on Feb 13, 2009
Sansa pmp recovery tool
The Sansa Connect Recovery Tool can be used to reformat and install firmware version 1.2.0.53385 to a Sansa Connect. This version is used in the current selling Sansa Connect products.
If for some reason device becomes unstable and resetting and erasing content doesn't resolve the issue, the Sansa Connect Recovery Tool would clean up your device and restore it to factory settings
2 things to check before starting the Recovery Mode and to use the Recovery Tool:
- First, charge the Sansa Connect for at least 20 minutes using the AC charger to ensure this is not a battery depletion problem.
- Second, hold the power button for 8-10 seconds to ensure the device is turned OFF.
After these steps, you can put the Sansa Connect into Recovery Mode and use the Recovery Tool.
Sep 16, 2012 | SanDisk Sansa e260 MP3 Player
I just got my sansa mp3 off of amazon and it does not work what do i do
STEP 1 - Connect the device to the computer 1. Remove the battery from the player’s battery compartment. 2. Put the hold/lock switch to lock. 3. Plug in your device to the computer.
STEP 2 - Format the device 1. Double-click My Computer. 2. Right-click on the player, which might show up as a Removable Drive, select Format. 3. Click Start. 4. Click OK when a "Format Complete" dialog appears. 5. Click Close.
How To Download MP3's To My Player.
Sansa Mp3 player frozen? How to reset and...
Sansa View: is not recognized by my...
Solve your MP3 Player Connection Problem.
Check out these tips posted here I think they are the best ones for MP3 players.
Mar 19, 2010 | SanDisk Sansa m250 MP3 Player
Empty sansa 4gb mp3, no software on device
How to use the Sansa Recovery Tool for Sans Connect:
http://kb.sandisk.com/app/answers/detail/a_id/863/kw/RECOVERY/r_id/101834
Check
direct to the download Sansa Recovery Tool [66 MB]
direct to the download How To pdf file [420 kB]
Sep 22, 2009 | SanDisk Sansa Connect MP3 Player
Sansa device is not displayed on my computer
If it is connected to the PC, then this is normal.
If it is not connected to the PC, reset the device.
Here is a link to your user's manual: which shows you the reset:
http://www.sandisk.com/sansa/assets/English/products/c200/c200_userguide_en.pdf
-Tha Mp3 Doctor
Mar 23, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa SanDisk mp3 out of power
Try these:
SOLUTION 1 - Reset the device.
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
SOLUTION 2 - Power cycle the device.
STEP 1 - Remove the battery
STEP 2 - Power cycle the player
1. Connect the device to the PC.
2. Leave the device connected for about 2 minutes.
STEP 3 - Turn on the device
1. Disconnect the player from the PC.
2. Insert a fresh AAA battery into the player.
3. Turn on the player.
Jan 25, 2009 | SanDisk Sansa m240 MP3 Player
Sansa MP3 not working
Try these steps:
Jan 18, 2009 | SanDisk Sansa m240 MP3 Player
My sansa e250 won't stay connected to the computer.
If it is flashing constantly, go into Start --> Control Panel --> Printers/Othe Hardware --> System --> Hardware --> Device Manager --> and uninstall either the Sansa or the MTP device. Disconnect the Sansa from the computer, and reinstall the software that came with the mp3 player.
-Tha Mp3 Doctor
Jan 17, 2009 | SanDisk Sansa e250 MP3 Player
My sansa e250 keeps connecting and disconnecting from the computer. every time i plug it into the computer, it keeps saying that it's connected and disconnected to the computer. this switches repeatidly...
If it is flashing constantly, go into Start --> Control Panel --> Printers/Other Hardware --> System --> Hardware --> Device Manager --> and uninstall either the Sansa or the MTP device. Disconnect the Sansa from the computer, and reinstall the software that came with the mp3 player.
-Tha Mp3 Doctor
Sansa c240
Sansa c200 series – Computer/OS Not Recognizing
Connect the device to the PC in MSC Mode
View/c200: Turn on then press and hold the rewind button while plugging to the PC
If that fails, unplug the Sansa from the computer. Uninstall all the Sansa software in the add/remove programs section of Control Panel. Reinstall the clean version of the software from Sandisk’s website – make sure you get the files for the c200 series. Then replug the Sansa and try again. The root of the problem is that Sansa has one set of drivers and Windows has another. If you plug the mp3 player into the computer before installing the Sansa drivers, the Windows drivers will trump the Sansa’s.
Here is a helpful link from Sandisk on the problem with extra information on Vista operating systems:
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=42&p_created=1221328944&p_sid=8VPwlRmj&p_brand=sansa&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzQsNzQmcF9wcm9kcz00JnBfY2F0cz0mcF9wdj0xLjQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jMjAw&p_li=&p_topview=1
-Tha Mp3 Doctor
Jul 29, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Computer won't read mp3 player
First, reset.
If that fails, then try to download the Sansa Connect Recovery Tool from:
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
If that still fails, upgrade the firmware from the Sansa website
If that fails, uninstall the software from the installation CD and reinstall it from the Sansa website.
Feb 10, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
24 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
