Question about Black & Decker Pivot Plus Cordless Drill/Screwdriver
Bit problem how do i change the bit on the pivot plus. i have tried everything and it wont budge.
  • 2,176 Answers
Just read part of the manual and it says hold tool upright and pull down on the collar and "simply" remove the accessory. If this is not the case on yours I would have to think that the shank on the bit may be twisted and then you would have to find another method to remove it. Let me know if the second opinion is correct. Good luck
Posted on Feb 11, 2009
Pivot Plus PD600 drill bit problems
pull the very front bit back that holds the drill Re: Jeff
Apr 10, 2012 | Black & Decker Pivot Plus Cordless...
Pivot Plus. Cannot remove screwdriver bit
use soe WD40 and a pair of pliers, i take it that it has been left in it for a while. put it in the lock position when you are trying to get it out. if you do not have wd 40 then use some light oil, it is probably rusted in position.
cheers
iain
Apr 30, 2011 | Black & Decker Pivot Plus Cordless...
How do i change the bit?
It just pulls out if its a screwdriver and if it has a quick release chuck then pull chuck back towards drill body and pull bit out.
Feb 02, 2011 | Black & Decker Pivot Plus Cordless...
It's stuck....
i have had some cheaper bits get lodged in, try and use pliars to turn the bit opposite of the direction it was in when it was last used.....
Jun 27, 2009 | Black & Decker Pivot Plus Cordless...
PD600 Pivot plus B&D drill.
Mine gets stuck sometimes too, I grab the inserted tool in the vise or with pliers and a twisting back and forth while pulling gets it out.
actually I just threw mine out when the trigger switch quit
Mar 21, 2009 | Black & Decker Pivot Plus Cordless...
Changing bits
Without a model number I am guessing but you should have to either pull back on the outer collar or push forward to release the bit in the hex driver. If this doesn't work give me the brand and model number and I will find a user manual to look at and let you know where you can get it.
Feb 09, 2009 | Black & Decker Pivot Plus Cordless...
How to change drill bit on black & decker plus pivot cordless drill How to change the bit on a Skil cordless screwdriver 2362 with a keyless check?
Grab the end of the chuck in one hand, and the outer ring of the chuck nearer the motor, and twist the chuck end. try both directions until it loosens.
Jan 28, 2009 | Drills
Black & decker pivot plus bits are stuck
I had this problem too, an unfortunately, there's no manual on the black & decker site for this product.
I figured it out though! You have to push down (towards the motor) the chuck collar (cyllindrical black part which holds the bit). If you've tried this already, try harder - it can get really stuck and require a lot of force to push down.
Anyways, if you apply enough force, it will give and allow you to remove whatever bit is inside.
Hope this helps.
Dec 23, 2008 | Black & Decker Pivot Plus Cordless...
Trying to change LG side-by-side fridge filter
try removing hte kick plate first. and slightly push in as you turn counter clockwise 90 degrees. it'll come. ive hadsome stick but never break on me
Mar 12, 2008 | LG LRSC21935 Side by Side Refrigerator
Black & Decker Pivot Plus Cordless Drill/Screwdriver Logo
513 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
