Question about Toshiba Satellite Computers & Internet
BIOS NVRAM checking - not passed
I have a problem on a Toshiba Sattelite L40-15G. This boot up stop at NVRAM checking. I already replace the RAM modules but the problem still the same. I cannot get the laptop to boot so that I can flash the BIOS. I've tried the "boot block" method but the system don't access the cd or usb. Please help.
    Sergeant:
  • 305 Answers
I have had even new sticks of ram not work in one machine, but are fine in another. Put the old ram back in and make sure everything works like you want, then try the ram again. If they are still giving problems, unfortunately it looks like even more ram is your solution.
Posted on Dec 23, 2017
  • 163 Answers
SOURCE: Toshiba EA60 laptop wont go in boot sequance, its stop after toshiba logo and gives a black screen with blinking curser in top lef corner
Its probably not the BIOS but the board warping beneath the CPU Socket or similar.. Dont flash it (BIOS) or it will probably kill the chip. Let me look up the model number...
Posted on Feb 12, 2008
  • 7 Answers
SOURCE: BIOS Battery Location of Toshiba Sattelite A15-S127
1. Remove the battery (side latch release) and hard drive. The only screw that holds it down is marked F-4 on the cover. (look for the panel with the 2" circle, that is the HD)
Use the white pull tab to move it left then upwards. It should move with little effort. Be careful not to loose the screw from the HD panel.
2.Remove all screws annotated F6 from the bottom bezel with a Pt. 2 screwdriver. (from my count there was less that a 15 )
Depending on the screwdriver, there are times where you might have to push the screwdriver down a bit to get in contact with the thread. Just be careful not to strip the threading.
3.Remove the "B25" screw located near the heat sink-fan vent. Somewhat carefully take your hand, and lift the bottom bezel up enought to disconnect (about 1-2 inches from surface) the battery with your index and midde finger. Look at they way the battery is run, and seated in the plasic clips.
With the bottom semi-open, plug in the replacement battery, and re-seat it in underneath the white ribbon cable, and clips on the housing per the original.
4. Replace all screws (less than a ton).
5. Re-seat the hard drive, by sliding it in first with the metal tab under the plastic housing, to the left, then puling it to the right. Replace the panel with the one, shorter, F-4 screw. Reseat the battery.
6. Return your model car with reciept. If a reciept cannot be found, use it for store credit.
If you wish to test the battery, simply unplug it and remove the battery for 30 minutes. Then power it on with only the A/C adapter. If no CMOS screen appears, you are good to go.
http://www.tomshardware.com/forum/247842-30-replace-cmos-battery-toshiba-satellite
Posted on May 06, 2009
  • 1481 Answers
SOURCE: Bios stuck on my toshiba L305D-S5934 it not doing
u can re-set the BIOS by removing the BIOS battery, the BIOS battery(wrist watch cell) is the size of a Dime inside the laptop, so you need to open the laptop, i suggets you visit a technician to do this.
Try doing the following also.
remove the power adaptor and remove the battery from the notebook, keep pressing the power button for 3 - 4 mins. Refit the battery / power and re-start.
Posted on Dec 07, 2009
SOURCE: ERROR 0175: Bad CRC1, stop POST task
You obviously didn't read the problem carefully. The machine won't boot, so there is no command line. I have the same problem with a T23. It might be the CMOS battery that needs to be replaced.
Posted on Feb 10, 2010
  • 693 Answers
SOURCE: i'm trying to help a friend install
After "Fast Boot" has been enabled, you cannot access the BIOS setup during power on . The machine will bypass "Press F2 to access Setup Utiltiy and F12 for Boot Menu" prompt.
This is a bigger issue if the hard drive crashes and access to Windows is not possible OR
Fast Boot can be enabled or disabled in the BIOS setup, or in HW Setup under Windows.
If you have Fast Boot enabled and you want to get into the BIOS setup. Hold down the F2 key, then power on. That will get you into the BIOS setup Utility.
You can disable the Fast Boot Option here. You will need to disable Fast Boot if you want to use the F12 / Boot menu.
Posted on Aug 26, 2011
Don't pass NVRAM Checking at boot in Toshiba L40-15G.
If the RAM is not the original RAM that came with the Toshiba then the RAM maybe incompatible.
Apr 17, 2013 | Computers & Internet
How do i reset boot bios password for my toshiba sattelite a350?
Follow these steps:
  • Remove Laptop Battery
  • Remove Memory Cover
  • Spread spring clips to outside and
  • pull out RAM memory
  • Remove clear vinyl label opposite RAM memory slots
  • In the upper left corner you will see JOPEN1 with a white silkscreen square
Inside the square you will see what looks like the letter T over a U. Using a metal paper clip short the U to the Silver 1/4"post connecting the motherboard to the laptop case and hold it for 25 -30 seconds. Place back your RAM memory, put in the laptop battery and test start laptop. you should see a selection of F1 or F2 for setup. Using the F2 gets you into the Bios menu where you reset the time and date. Then Tab over to the SECURITY setting tab and change your passwords. Then hit F10 key
Nov 14, 2010 | Toshiba Satellite A135-S4527 Notebook
I turn on my compaq and the first thing come on screen is CPU=AMD-K6(tm)/300 00000640K SYSTEM RAM PASSED 00064512K EXTENDED RAM PASSED 0512K CACHE SRAM MOUSE INITIALIZED FIXED DISK 0:FUJITSU...
above 06 lines are related with system information, Go to the BIOS check the startup sequence, if everything is ok save and exit from BIOS.
Apr 01, 2010 | Computers & Internet
Bios stuck on my toshiba L305D-S5934 it not doing nothin when pressing F2 or F12 but CTRL/ALT/DELETE then it just restarts.. i took out RAM, then computer will not boot up replace ram one at a time bios...
Dec 07, 2009 | Toshiba Satellite L305D-S5934 Notebook
Booting problem
Do you know how to get into the BIOS setup? You can set it up for default in the BIOS settings. If it isn't saving them after restarting your computer, you should replace the battery to the motherboard.
Jan 28, 2009 | EliteGroup P4VMM2 Motherboard
Toshiba Satellite A50
When the system boots hit the BIOS key F2 and in the setup select boot from CDROM and press F10 and exit, Insert the bootable CD and boot the system
Jan 06, 2009 | Toshiba Sattelite A105-S2071 Notebook
Hi, I have a toshiba sattelite a55-s106 laptop that I recently upgraded from xp to vista home prem. After that I decide to add more ram. The system is supposed to be able to handle 2gb of ram max. If I...
Vista will not be the culprit here. The beep most likely meens that thee is a problem with the memory stick itself, especially if it boots normally when you take it out again. Motherboards are mostly designed to take identical sticks of RAM in pairs (Same brand, same model, same amount of memory) and sometimes, you will find that different manufacturer's RAM will not work in some systems.
Check to see if the RAM stick you are putting in is the same brand/model as the one already in. Also check to make sure it has the same amount of RAM on it. It could also be defective.
I hope that helps
Jul 09, 2008 | Toshiba Computers & Internet
Toshiba sattelite A135-S2246
Hard Drive Issues most likely, Try booting to your Bios Setup utility Page...
Hold the f2 key (or delete key)(some are also f12)Check to see if your HD shows up in there, then reboot and hold the F8 key to try and get to the SAFE MODE options screen... there ya can boot it into safe mode if able to get to it..
Jun 04, 2008 | Computers & Internet
Computers & Internet Logo
100 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
