Question about Canon P200-DHIII Calculator
Ink Roller Refill
What type of ink roller does the canon p200 printing calculator take?
  • 3 Answers
Just flip it out and you can order one at office max. It just clicks right in...
Check this url out...
http://www.officedepot.com/a/browse/p200-dhiii/N=5+325133/;jsessionid=00003njCXd20m6tI7ltdY3TGmWw:13ddq0tng
They are reasonably priced too...
cmhimg
Posted on Apr 21, 2009
How do you change the ink roller in a TI 5005 ii
Replacing the Ink Roller
  1. Press the OFF button.
  2. Remove the printer compartment cover.
  3. Remove the ink roller from the right side of the compartment. Insert your index finger, nail down, under the tab on top of the ink roller. Gently lift the ink roller out of the compartment.
  4. Lower the new ink roller (IR-21) into the compartment and align the hole in the ink roller with the pin in the compartment. Press down until it snaps into place.
  5. Replace the compartment cover.
Warning Never refill or moisten the old ink roller. This can damage the
printing mechanism and void the warranty.
The full manual can be found here:
http://www.retrevo.com/support/TI-TI-5006-II-Calculators-manual/id/426ci758/t/2/
Nov 18, 2013 | Texas Instruments Office Equipment &...
Replace ink cartridge
INK ROLLER REPLACEMENT
If printing is blurry even when the ink roller is in the proper
position, replace the roller.
Ink roller: Type EA-732R
WARNING
APPLYING INK TO WORN INK ROLLER OR USE OF
UNAPPROVED INK ROLLER MAY CAUSE SERIOUS
DAMAGE TO PRINTER.
1) Turn the power off.
2) Remove the printer cover. (Fig. 1)
3) Remove the ink roller by turning it counterclockwise and
pulling it upward. (Fig. 2)
4) Install the new ink roller and press it in the correct position.
Make sure that the ink roller is securely in place. (Fig. 3)
5) Put back the printer cover.
Jun 08, 2012 | Sharp EL-1611P Calculator
How do I replace the ink cartridge?
1. Press OFF.
Feb 04, 2011 | Texas Instruments TI-5006 II Calculator
WHAT INK ROLLER MODEL NUMBER FITS CANNON P23-DHV
Canon P23-DHVInk roller Part# IR40T
http://www.gorillapaper.com/ink-roller-ir40t-b-r.html
Thank you
Sep 30, 2010 | Canon P23-DHV Calculator
How to ink Casio FR 1211 Printing Calculator
I have a Casio FR-1211 Printing Calculator and I have the same problem. I removed the roller and tried inking the roller with "Sanford's Roll-On Stamp Pad Inker". It works beautifully ! I don't know how long it will last, but for now the print is dark and clear.
John
Apr 05, 2009 | Casio Office Equipment & Supplies
Where can I find an ink roller for my Canon P23-111 calcultor?
I recently purchased replacement ink roller for the Canon P23-DH 111 (2 pack) from Staples Business Depot.
It uses ink roller CP-13 .
Priced under $10
Nov 28, 2008 | Canon P23-DH Calculator
Changing Ink in the Canon P170-DH Printing Desk Top Calculator?
The manual for the Canon P170-DH calculator is found on the canon usa web site. It is 22 mg in size, but prints out to 4 pages in English, Spanish and French.
According to the manual: Use only Ink Roller CP-13.
There are four figures showing the steps, so you'll have to imagine it.
1. Turn power switch off.
2. Remove the printer cover (Figure1).
3. Hold the tab of the ink roller. Lift the ink roller out of the base (Figure2).
4. Insert the new ink roller into position. Push down on the center of the ink roller until it locks into place (Figure3).
5. Replace the printer cover (Figure4).
Print out the manual for yourself and put it in a safe place.
Nov 20, 2008 | Canon P170-DH Calculator
How do you install the ink roller in a canon p1 dh v
The instructions in the manual are (1) remove the printer cover by pressing down on the (triangle) mark. (2) Lift up the old ink roller and remove it (3) Insert the new ink roller by pressing it gently into position (Use Canon Ink Roller CP-16) (4) replace the printer cover. My roller has the term "Pull Up" on the left side of the roller.
Aug 12, 2008 | Canon P1-DHV Calculator
Ink rollers
Unless the ink roller that you installed was dried out, usually, the replacement rollers just snap in place and are good to go. Check to make sure there is ink on the roller by either pulling the ink roller out again, and touching it with your finger. If no ink on your finger, you might have received a dried out replacement roller. Also the roller should be somewhat like a sponge. If you push against the sponge and it doesnt spring back and it stays indented, then the roller might also be bad. If you happen to have a bottle of ink for an ink pad, you can try soaking the roller with the ink so the roller is wet, (but not DRIPPING WET) and try it again in the calculator. IF you get some image for a little while, then I would say try a new fresh ink roller.
Hope this helps.
Feb 04, 2008 | Sharp EL-2192Rll Calculator
Canon p170-dh
if you calculkator does not print at all try to move a switch to p or print, and you have a ink roller on the printer
Dec 08, 2007 | Canon P170-DH Calculator
Canon P200-DHIII Calculator Logo
701 people viewed this question
old marine
old marine
