Question about Sony BRAVIA KDL52XBR2 Television
Theres no picture on my sony bravia KDL-40S4100
When i press power on my remote, the green light at the bottom of the tv,(the light display "center")comes on but i have no picture whatsoever... i cant do anything with the remote as far as pressing buttons etc. the only button that works is the power button...
  • Anonymous Feb 24, 2009
    same TV and sounds like the same problem, I'm taking mine back to Best Buy. I called SONY to ask about the problem and I got a very unhelpful guy that sounded stoned I'm buying a Samsung.
  • 121 Answers
Try pressing the TV/Video button. The problem could be that the TV is set to an input with no source.
Posted on Feb 25, 2009
Sony bravia KDL 40S4100 No picture
If you wish to get some details; check the site linked here. Pull up older posts.
Troubleshooting procedure for No-Picture is given in detail.
Sep 06, 2016 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony Bravia KDL-40S4100. When powered on I get solid green light, no sound or picture. When I remove the small 5 pin cable located on the left side of the main board (S040FHD 07452-3) the back light...
It sounds that the panel is faulty. A plain green screen denotes it. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window. Defective screen shots to LCD TVs are given by illustrations. You can compare it to that of your TVs' and can make confirm.
Nov 01, 2013 | Sony Bravia KDL-40S4100 40 in. LCD TV
SONY KDL-40S4100 flashes 5 times
try to force on the tv un plug and use remote when tv iv completly off. and press display 5 vol+ then power and see if tv stays on and in service menu look for eror code .if tv stays on if it cutts off then one of lamp in screen is defective. its mean screen defective
Mar 01, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
My sony bravia 40'' TV video in 1 and 2 is showing lock, how can i go about it.
try to reset tv from service menu sony service menu display 5 vol+ power from remote and see the reset menu and reset whole tv functions.
Dec 27, 2011 | Sony Bravia KDL-40S4100 40 in. LCD TV
KDL-40s4100 power light on, black screen
Main PCB is bad . I just got the information from a Sony authorize servicer price for the part only $504.87
Nov 27, 2011 | Sony Bravia KDL-40S4100 40 in. LCD TV
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Apr 05, 2017 | Sony KDL-46XBR5 46 in. LCD HDTV
Sony BRAVIA KDL-40S4100 Television 40 inch picture stopped...
If the green light stay's on but no picture, meaning black screen! Then you have a bad back light inverter. You can order this at www.shopjimmy.com, select sony then your model number.
If you are somewhat handy you could do it yourself! but it requirestaken tv fully apart. There are a lot of screws that should be baggedseparate as you go along. To ensure tv can be reassembled. follow thesesteps or have a expert do it!
1) remove shell (casing)
2) remove second layer, this will have your signal boards on it (a/v etc...)
3the back light inverter has a metal cover over it, with very tinyscrews. Also you will see multiple wire plugs going into it. Usuallywhite/pink or white/blue.
If this sounds to confusing Irecommend having an expert do this work! If you have found this helpful. Good luck!!
Part is $89.95
Sony Back Light Inverter SSB400W20S01 KDL-40S4100 or Check ebay!!
Feb 11, 2009 | Sony BRAVIA KDL52XBR2 Television
Sony Bravia 40inch how do I remove input icon
Press " i " (info) button on TV remote and on-screen display will disappear.
Jan 26, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
No Picture on TV when Power is on
This seet should provide some diagnostic help. The standby light should be blinking a repeated count with a pause. Post that count here. Also, is there sound?
The above info will indicate the problem circuit which will then suggest the remedy.
Thanks,
Dan
Jan 19, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony BRAVIA KDL52XBR2 Television Logo
373 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
