Question about Motorola Mobility Moto Q
Moto Q Sprint Phone wont turn on
It will bring up the charging screen when i plug it into the charger but once i hit the power button it wont go past my sprint screen..... what do i do i need an answer asap
please and thank you
  • 35 Answers
3 ways to solve it:
1.) Take out and put battery back in.
2.) Plug into a wall or car charger but not a PC USB charger. This does not work with PC USB connection for some reason.
3.) Hold red on/off button to force a reset.
4.) The big battery icon should appear on screen.
5.) Let charge until mostly or fully charged.
7.) Turn on phone. It should boot.
2 - Hard Reset
To perform the hard reset, hold down the center select button in the middle of the D-pad/joypad (the raised silver one.) Then, continuing to hold it for at least five seconds, press the power button to allow the device to power up. Continue to hold the select button until you get a screen which asks if you want to perform the master reset. Let go of the select button, and press the appropriate soft action key to respond yes.
REMEMBER! A hard reset erases ALL of your data!!! This is why the Backup is so important.
You could get Sprite Backup. In addition, install it to your Storage Card and save your backups there as well. That way you can restore on the road without a PC.
3 - Update your phone's firmware
Posted on Feb 11, 2009
Motorola wont turn back on
Moto G phone? Plug in the charger.......wait 15 mins. Hold the power button down for up to 2 mins. Phone should power up and charge.
Mar 20, 2015 | Motorola Cell Phones
Moto g wont turn on
Try holding down the power key for 30 seconds. You should see a white indicator light blink. If not then plug it into a charger that you know works. If your not using the original charger it may not be getting enough power. You may need to charge it for a couple of hours and then attempt to turn it on while on the charger by holding down the power button for atleast 30 secs or untill it turns on.
Sep 20, 2014 | Motorola Mobility Moto G - Verizon Prepaid...
Why wont my new Motorola phone charge?
Does it give you any light while charging the phone?
Try by pressing the Volume Down and the Power key together for 3 minutes with the phone unplug, after that plug the phone to the charger and see if it respond.
Jun 29, 2014 | Motorola MOTO Cell Phones
Cut off by itself and wont cut back on
After charging it up fully, attempt to turn it on without being plugged into the charger. If it will not turn on, try turning it on while on the charger. If it does not power up and there is nothing wrong with the charger you have a phone issue. If it does power on, you need a new battery.
Mar 27, 2010 | Sprint BlackBerry 8703e Phone
My samsung instinct is not charging properly. I plug it in with my charger and the charging screen appears for less than a 30 seconds then goes to my background display. I have tried using my car charger...
look inside the charge port to see if there is anything from the charger inside that my have broken off by accident. that is very common with the instinct and the m300 as they use the same style charger. you may need to just replace the charger. and if the phone is in fact broken, sprint has an insurance plan that will get you a new one for free or for 50 bucks depending on the policy
Sep 25, 2009 | Samsung Instinct Cell Phone
I have a motorola q and it does not load up past the part that says windows mobile it stays stuck on that screen and wont load up how do i fix it
A hard resset should solve your problem
Sprint Moto Q
ATT
1. Turn the device off.
2. Press and hold the "E" and "Z" keys.
3. Press the Power button once.
4. When screen comes on, let go of "E" and "Z"
5. Press Power button once again.
6. Message that the phone has been reset.
7. Takes a few mins to reset.
Apr 20, 2009 | Motorola Mobility Q9h Smartphone
Blue On G1
ok i had this isssue and figure out what to do. this is all afterm you know that you have a good charger and or battery.
1. completely turn of phone unplug charger.
2. take and put battery back in phone and plug charger.
3. hold hit camera button and power buton. phone will come on if the update was washed it will come straight on. if not you will see the blue LED dont worry yet. just keep holding for 15 sec.
4. while phone blue LED is still on hit and hold (drum Role) menu and track ball for 15 sec.
5. now unplug charger and take out battery. wait 10 sec
6. now put battery back in and leave charger off. and turn on. unless you was in middle of update and hardware failed this WILL bring your G1 back up and running.
hope this helps everyone . MIll$tronics signing out.
Mar 05, 2009 | HTC G1
Phone shut off
Plug it into your walloutlet usb charger rather then the one connected to your pc. once your battery is so low it wont even have enough juice to show the charge battery screen if your chargeing through the low voltage pc active sync cable.
Feb 11, 2008 | Motorola Mobility Moto Q
Motorola flash mode
Have you tried a Master Re-set when the phone is off? Hold the center key and the power button for at least a FULL minute to a minute and a half. You will see the provider's splash screen, but hang tough.
This works best with the device on a flat surface rather than holding it.
Sep 16, 2007 | Motorola Mobility Moto Q
Moto Q won't turn on
Hold down the center nav key and power up the unit. This will restore any files that may have been corrupted and put them to original. If you loaded a 3 party app or something prior to this may be the cause of the issue. Don't use that app.
Aug 10, 2007 | Motorola Mobility Moto Q
Open Questions:
boot_c_03.08.00r_mpap Paul Sager from FixYa has posted a solution for this problem previousley (as below). I have tried the Motorola and Verizon sites (tried the store as well) and the software is not available to flash the phone. Do you know of a site that would still have it available? Or can this question be sent to Paul to further comment on it? All I want to do is recover the phone numbers, notes and calandar from the phone via Activesync or Windows. Paul Sager 2335 Solutions July 14, 2010 I can help you with your Motorola Moto Q. What has happened is that the firmware of your phone has become corrupted. When this happens your phone will no longer finish its boot sequence. This is a very common situation with many phones: in fact, much of what I do here at Fixya is explain how people can fix their MP3 players, GPS and phones by reflashing the firmware. The good news is that if you take your phone into your carrier's store, they can reflash it for you right there (if they have a competent tech handy.) If you are comfortable with computers etc, you can also do it yourself. Your computer will communicate with and fix your phone, even though it doesn't seem to recognize it right now - I've seen this many many times. My only warning for you is that if you are going to flash your phone yourself, you need to get the correct firmware from motorola's site for your carrier. I just downloaded the Verizon firmware as an example - Motorola's website has about ten different carrier firmwares for their MotoQ phone. I hope that helps.
Oct 09, 2012 | Motorola Mobility Moto Q
See all Motorola Mobility Moto Q Questions
Motorola Mobility Moto Q Logo
183 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
