Question about RIM BlackBerry Pearl 8100
Cannot browse from laptop with my bblackberry 7100
WHEN CONNECTED TO THE LAPTOP THE BLACKBERRY DOES NOT RECOGNISE THE LAPTOP. SEND TO ME THE USB SOFTWARE OR A RIM THAT WILL PERMIT BROWSING THROUGH THE LAPTOP. THE PHONE IS PRESENTLY CONNECTED.
  • 561 Answers
Try Solution - First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
Posted on Jan 16, 2010
How do I connect and link my HP office jet 4500 to my HP laptop? There were no instructions in the box. Thanks
You are probably needing install the driver software.
The driver and manuals are on the HP.com website.
HP Product Support
Jan 05, 2015 | HP Officejet 4500 Wireless All-in-One...
Why cant I get emails on my z 10 on my bt internet account it says doesnt recognise username or password
Try to reset your phone. Than on back. If still can't get emails than go for update using laptop or desktop connect your phone using USB cable and go to the website of blackberry......
Jun 16, 2014 | RIM BlackBerry Bold 9000 Smartphone
Sanei tablet 3it is not running on laptop pc hp
To connect up a tablet with a laptop you need to connect them with a USB cable.
On plugging in the cable with the tablet powered up, you should see two things.
1. A question on the tablet as to whether you want to use memory disc mode or diagnostic(ADB) mode. Choose Memory disc mode.
2. You should see on the PC laptop it recognise that an external device is connected, it may recognise it as a phone or a memory drive.
If neither of these things is happening it is probably the cable at fault.
The tablet should then start providing the pc laptop with the drivers it requires to be recognised. If this does not happen, then the fault is with the tablet and you have to consult your supplier.
You should end up with at least one memory drive which you can browse through with the PC's file manager. The data will be on the tablet.
Nov 30, 2013 | Tablets & eReaders
My Bold 2 9700 smartphone is showing blank screen with the message reload software 513. Also, the phone is not connecting to the desktop manager eith using the USB cable or through the Bluetooth.
Force a reset by loading version 5 desktop software on your laptop first and then connecting the BlackBerry to it. It may take some time for your pc to recognise that the BlackBerry is plugged in, so be patient!
When it connects, reload the firmware.
Oct 12, 2010 | RIM BlackBerry Bold 9700 Smartphone
My blackberry 7290 gives error 507 with a circle at the top
You will receive the following Java error 507 message on your BlackBerry smartphone while using the application loader tool to install or upgrade the BlackBerry Device Software.
Cause 1:
This might occurs while using the application loader tool to install BlackBerry Device Software, existing applications on the BlackBerry smartphone are erased, and new applications are not loaded.
To resolve this error you need to complete the following steps:
  1. Verify that you have the BlackBerry Device Software installed on your computer.
  2. If your BlackBerry smartphone is connected to a laptop computer in a docking station, disconnect the laptop computer from the docking station and connect the BlackBerry smartphone directly to the laptop computer.
  3. If a third-party program, such as a virus scanner, is using the same communications port (COM port) as BlackBerry® Desktop Manager, close the third-party program to free the COM port for use.
  4. If you are using a USB adapter to connect your BlackBerry smartphone to a serial port on your computer, temporarily connect your BlackBerry smartphone to a computer with a USB port.
  5. Open BlackBerry Desktop Manager and double-click the Application Loader icon.
  6. Use the application loader tool to install the BlackBerry Device Software.
Cause 2
This might occurs while all data and applications are removed when an incorrect password is typed ten times into the BlackBerry smartphone.
  1. Open BlackBerry Desktop Manager and double-click the Application Loader icon.
  2. Use the application loader tool to install the BlackBerry Device Software.
Cause 3:
This might occurs while the Power Management feature on the computer turns off the USB ports.
  1. On your computer, click Start > Settings > Control Panel.
  2. In the Control Panel, double-click the System icon. The System Properties window opens.
  3. Click the Hardware tab of the System Properties, and click Device Manager.
  4. In the Device Manager, double-click Universal Serial Bus Controllers.
  5. Right-click the first USB root hub, and click Properties.
  6. In the Properties window, click the Power Management tab.
  7. Clear the Allow the computer to turn off this device to save power check box.
  8. Repeat steps 5 to 7 for all other USB root hubs.
  9. Restart your computer.
Cause 4:
This might occurs while the BlackBerry smartphone is connected to a laptop computer using a docking station.
  1. Disconnect the docking station from the laptop computer and connect the BlackBerry smartphone directly to the laptop computer using a USB cable.
  2. Re-install the BlackBerry Device Software using the application loader tool.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Oct 21, 2009 | RIM BlackBerry 7290
Phone refuses to turn on. red light keeps blinking and can't connect to my pc
  1. Verify that BlackBerry Device Software is installed on the computer.
  2. If the BlackBerry smartphone is connected to a laptop computer using a docking station, disconnect the docking station from the laptop computer and connect the BlackBerry smartphone directly to the laptop computer.
  3. If a third-party application uses the same communications port as the BlackBerry Desktop Software, close the third-party application.
  4. If you use a USB adapter to connect the BlackBerry smartphone to a serial port, temporarily connect the BlackBerry smartphone to a USB port.
  5. In the BlackBerry Desktop Manager, double-click Application Loader.
  6. Follow the Application Loader tool prompts to install the BlackBerry Device Software.
Oct 19, 2009 | RIM BlackBerry Pearl Smartphone
Phone has error code 507 with a square and a triangle, and a line running trough it
Cause:
This error message can have the following causes:
While using the Application Loader tool to install BlackBerry Device Software, existing applications on the BlackBerry smartphone are erased, and new applications are not loaded.
All data and applications are removed when an incorrect password is typed ten times into the BlackBerry smartphone.
The Power Management feature on the computer turns off the USB ports.
The BlackBerry smartphone is connected to a laptop computer using a docking station.
Resolution
The following are possible resolutions for this issue.
Cause 1
Resolution 1
Complete the following steps:
Verify that you have the BlackBerry Device Software installed on your computer. For instructions, see KB03295.
Use the Application Loader tool to install the BlackBerry Device Software.
Cause 2
Resolution 2
Open BlackBerry® Desktop Manager and double-click the Application Loader icon.
Cause 3
Note: This resolution is for Windows® XP users only.
Resolution 3
Cause 4
Resolution 4
Re-install the BlackBerry Device Software using the Application Loader tool.
May 17, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Reload software 507
Cause:
Resolution
Cause 1
Resolution 1
Cause 2
Resolution 2
Cause 3
Resolution 3
Cause 4
Resolution 4
Feb 18, 2009 | RIM BlackBerry Bold 9000 Smartphone
RIM BlackBerry  Pearl  8100 Logo
44 people viewed this question
Top RIM Computers & Internet Experts
Andrew Wright
Trisha
Trisha
asber
asber
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
