Question about HP PAVILION A6230N DESKTOP PC
No signal to monitor
I have an emachine running Windows 2000 that has been hooked up to our HD television as its monitor. I am trying to use a traditional envision LCD #EN7410E monitor with the system. all cables are properly connected but when the system boots up, the monitor displays "no signal." Suggestions?
  • 1 more comment
  • bsabrio Feb 11, 2009
    I'm connecting through an SVGA port
    I tried another monitor and received the same error message.
  • Rob
    Rob May 11, 2010
    I need more information please. What connection are you using on the LCD?
  • 423 Answers
Have you tried booting into safe mode? If so, do you still get no signal? Also, do you have a video card, or is it on the board?
Posted on Feb 12, 2009
    Genius:
  • 1,226 Answers
Try go to bios setup and then try resetting bios by selecting the bios default setting. and then look up for the configuration regarding your monitor setting or try to enabled that setting.
You can manipulate the bios setting ...don't forget to save the setting.
then try rebooting the system.
melnavz
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
My emachine w3115 runs but there is no video signal on my screen
try hooking it up to an external monitor through your vga jack and see if the sceen appears on the external monitor first. if so then its most likely a bad back light on your laptop screen or inverter
Jun 23, 2011 | eMachines W3115 PC Desktop
Does my hd 1080 series tv have the capability of running my computer through it?
Yes,u can used ur LCD tv as a computer monitor.Used a HDMI cable to hook it up or a computer VGA signal cable to hook it up.Process is pretty simple,read ur LCD tv instruntional owner manual how.
Nov 22, 2010 | Mitsubishi Televison & Video
What is Monitor Out on 42'' Hitachi plasma TV (42HDT50)
Monitor Out connects audio and video signals to an external monitor with corresponding inputs as noted in the document.
Mar 07, 2017 | Hitachi 42HDT50 42 in. HD-Ready Plasma...
I have hooked everything up and the monitor shows " no signal".
are you using the onboard? video... or a seperate vid card? if it was working and then suddenly quit? the onboard vid chip is out! cant replace that either try adding a seperate vid card and reboot
Jan 13, 2010 | E-Machines eMachines Desktop PC
Trying to hook my sanyo 32in up as a monitor for my computer running on windows xp when I hook it up it gets sound and acknowledges the cord is connected(the no signal sign goes away) but the screen just...
Your computer may be sending out a video signal that's too high of a resolution for your TV to display. Try reducing the resolution of the computer video signal.
May 13, 2009 | Sanyo DP32648 32 in. LCD TV
Emachine monitor with a HP computer
i am trying to hook up a emachine monitor to my compac computer but the monitor will not come on there is another wire coming off the part that hooks in the compac but there is nowhere to hook it can you help me?
Oct 12, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
My monitor says no signal
You'll need to check the cable connections and the computer that it is attached to. The monitor may be going into standby mode because the computer went into Suspended/Hibernate mode. Try restarting the computer. If you're unable to do this, try a hard power off and then try to turn it back on.
Sep 17, 2008 | E-Machines eMachines Monitor E15T4
Trying to connect PC to Philips LCD HDTV
While the tv is on the right input, and the computer is running, try unhooking the cable and hooking it back in. That's the only way I can get my Philips to detect the HDMI signal from my pc. I haven't found a fix for it though.
Jan 29, 2008 | Philips 37PF9996 37 in. HD-Ready LCD...
HP PAVILION A6230N DESKTOP PC Logo
178 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
