Question about Dell 3110cn Laser Printer
Dell 3115cn cyan cartridge still shows as empty after replacing
I replaced the cartridge and it still shows as empty and won't print.
  • Anonymous Feb 18, 2009
    says "replace cartridge", but I just did! Still won't work
  • 217 Answers
I'm assuming that the cartridge is a remanufactured item (or a home refilled item.
The chip on the cartridge probably hasn't been changed.
Posted on Aug 30, 2009
When you print from the computer there is a blue line on one edge of the paper What should I do
You can run a cleaning page but you will probably have to replace the Cyan (blue) cartridge
Jan 10, 2015 | Dell 3115CN
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
I have a dell 2130cn, the cyan cartridge needs to be replaced, why can't I print
It appears on some forums that this is a common issue with this printer, and looks to be a limitation of the unit. It will not print with one of the toners empty until you replace that empty toner.
Mar 07, 2011 | Dell Office Equipment & Supplies
"009-362 Printer, Restart Printer, Reseat c cart., contact support"
The Cyan Toner Cartridge is either not seated correctly or the cartridge is bad. Open the front of the printer, pull out the Cyan Toner Cartridge, reseat making sure it fits all the way to the back.
If the problem is not resolved replace the Cyan Toner Cartridge.
Oct 21, 2010 | Dell Printers:Dell MFP Color Laser 3115cn
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Minolta 2430dl, cyan, magenta, and yellow toner cartridges all show empty. Black shows 42% remaining. How do I get printer to print?
Some printers will refuse to print _anything_, until you replace/refill _all_ of the empty toner cartridges. So, replace/refill.
Dec 30, 2009 | Konica Minolta Office Equipment & Supplies
My cyan cartridge shows as empty. My black
No. You need all the cartridges installed with functioning chips for your printer to work. The reason why you need all the colors when all you print is black is because a small amount of color prints when you print black. The manufacturers want to make up their R&D costs on the printers by selling lots of expensive ink.
Nov 25, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
HP C6280 Error: Ink Cartridges Empty
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
Aug 20, 2009 | HP Photosmart C6280 Printer
Cyan Cartridge not working
Show empty or not recognized (cross sign)? Check connector at chip and at head carriage. Do replacement procedure form status monitor (how to..). Do replacement ink tank one by one with cyan ink first.
Jul 25, 2009 | Epson Stylus RX425 Multifunction...
Hi I have a dell laser printer 3115cn, I changed the cyan cartridge and now I have small blue dots on one side of my copy. What should I do? Thanks Dora
Its probably a faulty, or badly remanufactured cartridge. If you still have the old cartridge, provided it wasn't fully used (according to the cartridge 'chip'), put it back in and if printing is OK, it IS the 'new' cartridge.
Jan 12, 2009 | Dell 3100cn Laser Printer
Dell 3110cn Laser Printer Logo
647 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
