Question about Nikon N60 35mm SLR Camera
Choice of film speed
I haven't used my N60 in a couple years and I'd like to get it back out and start to use it after I have my baby. I enjoy photographing in B&W and Im not sure what the best brand and speed of film to use that would work best in photographing my new baby without using flash. Help!
    Problem Solver:
  • 6 Answers
ISO400 is probably the film you want to go, as higher speed film costs more and have more grain...
Posted on Feb 15, 2009
My Nikon N60 wont load film. I load the film but it doesnt wind the film, but when i take a picture it rewinds it. I dont know what im doing wrong
Hi. Pay careful attention to the way the end of the film fits through the take-up reel. Open the back (empty) and give the wind knob a few twists. That will tell you which way it is turning. Put the end of your film through the slot in the take-up reel so itd winds onto itself as it advances. There's usually enough extra unexposed wound onto the factory reel that it won't cost you and pix at the end of it. Pull enough out of the cassette to be sure your winding-load position is really going to hold when you advance. Good luck.
Oct 30, 2016 | Nikon N60 35mm SLR Camera
What type of film does a n60 slr camera use
The N60 uses standard 35mm film (also known as 135). 35mm film usually comes in 12, 24, or 36 exposure rolls, any of which will work. 35mm film is available in black-and-white, color transparency (color slides), and color negative (color prints). It's also available in infrared, both color and black-and-white, but the N60 will not work with infrared film.
35mm film is available online and at any camera shop. Many department stores, drugstores, and even supermarkets also carry film, though not as wide a selection as a decent camera shop.
Oct 11, 2014 | Nikon N60 35mm SLR Camera
How to open banla format for nokia c2 00
While my phone if power ON. Press the *7780# code, this code is usually used for the N60 series phone but this code is not working for nokia 5310. And I tried also another procedure again by doing this process:
Your phone must be power off, press the "*" + "3? + "green call key" but nothings happen again I haven't format my phone.
What should I do for this phone, this is able to recognize in the computer and cannot format to hard boot formatting.
My last choice is to find a flash utility cable suits in my phone and the software to re-program it and putting some IMEI codes.
Oct 09, 2012 | Nokia mobile C2-00 Dual SIMbiosis
Pano ko po irereformat ang cp ko, nd ko ma open..
Oct 09, 2012 | Nokia 5130 Cellular Phone
I purchased a Nikon N60 used. The film will not automatcally load therefore not shoot
Please follow these instructions: 1. Open the camera back 2. Pull the film leader across the red film index mark (red line) 3. Check to ensure film is properly positioned with no slack, then close camera back 4. Fully depress shutter release button to advance to frame 1. Check the rewind lever if it turns counter clockwise when you depress the shutter release button.
Keep on trying this procedure until you get it right. Most of the time, the error is in not pulling the film leader enough to reach the red film index mark.
If you're still having a problem with this, the next best option is to have the camera checked by a competent camera technician.
Mar 25, 2011 | Nikon N60 35mm SLR Camera
How do i rewind the film on the nikon n60?
The camera should rewind the film when it reaches the end of the roll. If it doesn't, or to force a rewind in the middle of a roll, press the mid-roll rewind button with a pointed object. The button is on the bottom of the camera, toward the left end (away from the handgrip), and marked with a roll of film.
Sep 04, 2010 | Nikon N60 35mm SLR Camera
How do i load up my film?
Turn on the main switch, then open the camera back and insert the film. Pull film leader out to the red index mark. Gently close the camera back until the lock release snaps closed. Film automatically advances to the first frame.
For full details, including illustrations, refer to the manual. If you don't have one, you can download it from
http://butkus.org/chinon/nikon/nikon_n60/nikon_n60.htm
Aug 16, 2010 | Nikon N60 35mm SLR Camera
I have a Nikon N60 35mm camera its displaying F3 3 in the viewfinder what does it mean and how do I fix it
It's not clear from your question that this is actually a problem as you haven't said what the display is doing to cause you problems actually using the camera.
What is certain is that it's supposed to display a F number in the viewfinder. Along the bottom of the display will be a number (shutter speed), an F number (aperture setting, when in auto or shutter priority modes this may not exactly match what's set on the lens), and moving bar + - scale too indicate over (+) or under (-) exposure.
If you really don't know what the F number is nor what it's for then you need to read both a good photography for beginners guide and also the camera manual. Explaining the relationship between shutter speeds, aperture settings and film speeds in any truly meaningful way here is beyond the limited scope of FixYa as whole books are devoted to the subject, but you only need a few pages and pictures from the available publications to get a good idea.
You can download a free user guide for your camera at the address below. It's for a Nikon F60, but it's identical to the your camera which was called the N60 in North America to distinguish it from unofficial imports.
http://www.devicemanuals.com/guide/Cameras/Nikon/Nikon-F60-N60-Instruction-Manual-TmpNMU5qUT.html
I hope that I've helped and if so ask only that you return the favour by rating my answer. If I haven't helped then please add a comment to explain more about your problem and I'll try to give further assistance. Please note that I'm in the UK and will be unavailable for most of Sunday so please allow for the time difference and scheduling whilst awaiting any further replies from me.
Oct 24, 2009 | Nikon N60 35mm SLR Camera
Shutter Speed
If your shutter speeds are off you can compensate by changing the film speed setting,
quicker ( than should be ) shutter speeds require you to set the film speed to slower ASA .. KC
Sep 01, 2008 | Canon EOS-AE-1 35mm SLR Camera
Nikon N60 35mm SLR Camera Logo
78 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
