Question about Hobart H600 Stand Mixer
Hobart H600 wont shut off
Hobart H600 runs right away when plugged in. The contactor is not stuck shut but is energized as soon as you plug it in. Person who used it last few times said at first they had to hold in on the start button to make mixer work. Soon as they let go of the start button the mixer shut off. Next, they used a broom stick to keep the start button pushed in while mixing the dough and when done just pulled the stick out to stop the machine. The problem that I have now is that the machine will not shut off unless we unplug it or hold in on the stop button. If we just push in the stop button the mixers contactor opens and mixer will stop only if we keep the stop button pressed in. If we let the stop button go the mixer continues to run. I suspect that the start switch is bad but could sure use some help from someone familiar with this mixer.
Thank You!!!!!
  • 6 more comments
  • bfrasier Feb 13, 2009
    Since posting my problem last night I have a bit more info that may help those trying to help me. First, this mixer is a 3 phase unit with seperate "start", "stop" buttons and a "timer" located on front of unit. There is a 3 pole contactor and 3 pole heater mounted to rear of the unit inside cover (remote). The contacts in the start and stop switches, as well as, the conacts in the contactor are working normally and not welded shut. The side switch on the contactor is also working normally. Today, I had to unhook the timer because it threw sparks out around adjustment stem. After cutting the leads to the timer motor and unhooking the wires from the timer contacts I was looking at the wiring diagram to see how I could eliminate the timer and discovered that a wire coming off the stop switch was wired to the wrong terminal on the start switch. When I changed the wire to the correct position on the start switch I found that the mixer does not run all the time when plugged in. Now when I plug in the mixer I have to keep the start button pressed in for it to run. When I let go of the start button the contactor opens and mixer shuts off but the motor brake solenoid is not energized. If I hold in on the start button to keep the mixer running and then press the stop button simultaneously, the contactor de-energizes and motor brake solenoid energizes shutting the mixer off normally. The rest of the wiring looks to be correct now but I am unsure of how to wire around the timer. I just capped both leads to the timer motor but am not sure of where to run leads from the othe 3 timer terminals which amounts to a switch with a common terminal and (2) NO contacts. Is there a diagram out there anywhere that I can refer to? We also have 3 other Hobart H600 mixers and all of them use different components and motors so I need to find out about wiring for this model with these components and without a timer. Thanks again for those who are trying to help me along. Your time spent on my problem is greatly appreciated :)
    Mixer Model # H600
    Serial # 11-279-690
    M L # 19306
    200 volts, 3 ph
    When you say "latching circuit" do you mean like a "hold in" circuit that when the side switch closes it sends power to the contactor to keep it "held in"? Right now the side switch is wired to common and the n.o. set of contacts. If you eliminate the electro mechanical timer from the mixer is it possible to rewire this machine to just use the start and stop buttons. I suspect now that the switch side of the timer created a hold in circuit (for lack of a better or proper term) and since these are unhooked now I have lost what ever circuit would have held in the contactor when the start button was pressed. There is a diagram on this unit but it includes a wiring diagram using this timer so Im not really sure of how to just wire around it properly.
  • bfrasier Feb 14, 2009
    The timer used on this mixer was an electro mechanical timer. It had 2 wires powering the timer motor and 3 wires coming off the switch part of timer. The timer switch had a "common" terminal (#1) and 2 n.o. sets of contacts, #2 and #3. I believe one motor lead was on terminal #3, terminal #2 went back to the side switch on the contactor and terminal #1 went to the start switch. I am not at the same location as the mixer now but am pretty sure that was how it was wired. So far I have been unable to find a correct diagram but am still searching. Thanks so much for your help!
  • bfrasier Feb 15, 2009
    There is a side switch located on the left side of the contactor. The side switch closes everytime the contactor pulls in because there is a metal piece fitted into the side of the contactor that physically pushes the side switch closed everytime the contactor closes. When the contactor is de-energized the contactor opens and the metal piece that pushed in on the side switch springs back and allows the side switch to open. One wire off the top of the side switch went right over to one side of the contactor coil (terminal #C1) where it was hooked to another wire that Im not sure where it ran to. Either the bottom or top wire on the side switch went back to terminal #2 (n.o. switch) on the timer. It is just taped off now since the timer has been unhooked. Im am going to stop back and check the voltage across the side switch tomorrow to make sure it actually closing and opening and will also make a diagram of the control circuit so I can give you a better answer on where things are ran to. Does the side switch create a hold in circuit when the start switch is pressed, and then hold in is circuit is opened by pressing the stop button? If I better knew what the job of the side switch was I might have a better idea of how it should work in the control circuit. Please remember that I had to unhook timer because the timer motor was out and terminal #1 (common) on the timer switch fell out. Im sure that the leads that went to the timer switch (#1 common, #2 n.o., #3 n.o) have a lot to do with why it isnt running right now but Im not sure how to wire around the timer altogether. Again I thank you so much for the time you have given and will let you know tomorrow how the side switch is wired in and if the switch is actually opening and closing.
  • bfrasier Feb 19, 2009
    problem was in the latching circuit made by the side switch on contactor. Was able to eliminate the timer and rewire around the timer switch using the side switch to hold circuit in. THANK YOU to all who spent time on my problem and help me better understand the componets inteneded use. Mixer is now working very well!!!!!!!!!
  • Mark Egan May 11, 2010
    How many wires connect from the timer to the control circuit? 3, or 4?
    Is the timer a spring wound type, or powered type?
    At least 2 of the wires connect to the timer switch. One of those 2 may also connect to the timer motor, unless it is a spring wound timer.
    I've looked for a copy of the wiring diagram, but have not found yet. If you have found one on the Internet, please send the link.
    Is this a 1 or 3 phase powered unit?
    Is there both a start-stop switch and contactor/starter in one box, or a start-stop switch and remote mounted contactor/starter?
    President:
  • 1,214 Answers
Sounds like the side switch is the latching switch for the circuit, and you are right about it's operation. I strongly suspect where the wire comes off that slide switch and goes to the coil, there would be 2 wires at that connection, where the other one leads to one side of the start switch.
Looking forward to your reply. It will be easier to email the schematic that you come up with to me. Be sure and tell the the starter manufacturer that is installed as well.
stewartswitch@yahoo.com
Posted on Feb 15, 2009
  • 640 Answers
Sounds to me like the start switch contacts are welded shut.If you have a multimeter set it to ohms,remove 1 wire from the switch,put your meter leads across the switch and if you get a reading that switch is bad.If you dont get a reading i would check the side switch on the contactor.Im a hobartt tech and repair these mixers alot.Let me know.
Posted on Feb 12, 2009
  • 1 more comment
  • anthony james
    anthony james Feb 13, 2009
    The latching circuit is not working and this is were the side switch on the contactor comes into play---you should have wires on the side switch as follows---1 on common,1 on n.o. (normally open).I'll post later with a diagram.I need a m.l. # located on the data plate.
  • anthony james
    anthony james Feb 14, 2009
    Before we get into the wiring diagram,if you look at the contactor when the mixer is running can you see that the side switch contacts close? Is a side switch on the contactor?If you cant see it close then well step through the diagram,if you see it closes then theres another issue.Can you take a voltage reading on the side switch with a meter?If so put your meter on ac volts and 1 lead on the common side and the other lead on the n.o. side.Turn the mixer on (get someone to hold in the start switch) and if you read any volts the side switch is bad.
  • anthony james
    anthony james Feb 15, 2009
    Yes the side switch on the contactor is the latching (holding) switch for the circuit.I'll wait for your reply.Do you want to bypass the timer all together?
Hobart h600 shuts off after running for a minute and then thermal resets
Check and see if your Vents are Open, you are overheating it and shutting down to protect your machine,. If it is not overheating then your Sensor is going bad. Clean it up and there is a better than average chance it will work much better...
Apr 09, 2013 | Hobart H600 Stand Mixer
What oil can you use for the hobart h600
on the hobart h600 we use 120 oz of 140 weight gear oil.
Mar 04, 2011 | Hobart H600 Stand Mixer
My h 600 will only run when i hold the start button as soon as i let go it stops
If it has a bowl guard on it then the problem could be either the bowl height switch or the side switch on the contactor. If it does not have a bowl guard then the side switch on the contactor is the problem. If it has a bowl guard, make sure the bowl lift is operating the bowl height switch. The bowl must be all the way up to operate the bowl height switch.
Jun 09, 2010 | Hobart H600 Stand Mixer
How do you change or add oil to a Hobart H600 mixer
there are two oils to change. one for the trans. and one for the planetary.the drain plug for the trans. oil should be in back of the planetary take out plug let oil drain ,remove top cover take outstand off where front screw to top cover threads into put new oil in there till you hit line in sight glass on right side of mixer.
Jan 02, 2010 | Hobart H600 Stand Mixer
Seemingly well maintained H600 mixer only runs in reverse...
whoever wired the mixer in , hopefully 3-phase made a mistake on the incoming pwr to term block or the contactor switch any 2 leads this should reverse rotation of the mixer
Nov 04, 2009 | Hobart H600 Stand Mixer
Howdy, We have a Hobart H600 mixer and it looks like it needs oil. Where do I add the oil and what type should be used? Wesley McMenamins Pubs & Breweries
take off top cover, where the front screw on top cover threaded into is the fill plug for the trans.drain oil replace drain plug , also ck. sight glass if dark or cloudy replace,@this time.trans. oil can be bought @ any hobartoffice the part# for the trans. oil is102973-66 that will come in a 128 oz bottle you will not need all of it. pour a little @ a time till oil hits line on sight glass. please vote thanks
Oct 16, 2009 | Hobart H600 Stand Mixer
Electrical connection of hobart h600
it requires 3 phase with ground it is a four wire system
Jul 24, 2009 | Hobart H600 Stand Mixer
Need part for H 600T mixer
I dont think the button is the problem.I suspect the side switch on the contactor is bad.Give me a little more info like when the problem started.
Mar 23, 2009 | Hobart H600 Stand Mixer
I need to change gear oil in Hobart H600 mixer.
Take the top cover off,where the front screw on the cover goes in that long shft has to be unscrewed,get a funnel and add oil.
Feb 19, 2009 | Hobart H600 Stand Mixer
Hobart H600 Stand Mixer Logo
525 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
