Question about Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
ReddyHeater shuts off
I have a 65-85-100,000 var. heater. When it heats up the unit can not be touched or bumped. If you drop a hammer within 10 ft of it, it will shut down. It is very sensitive. I checked for loose wires and replaced the regulator and temp probe. It made no change. I took it to a shop and they had it for a week and could not fix it. It has about 50 hrs of run time on it. My guess now is a bad safty valve. Any ideas?
  • 1 more comment
  • jj32 Feb 12, 2009
    What I have found is if I by-pass the thermal switch it runs fine. This in not the thermocouple. It must heat up and be close to overheat and a little bump sets it off. If it was changed in the shop it could be a bad switch or its limit is to close for this unit. I will order a new thermal switch and find out.
  • Mark Egan May 11, 2010
    Let us know if that fixed it.
    It sounds like whatever triggers the safety shut-off circuit is to sensitive.
    I am not certain on this unit, but is the sensor a part of the gas valve?
  • 137 Answers
That would be my guess as well.
Posted on Feb 12, 2009
I have a reddyheater 125T yr. 2006 hsi multifuel unit. It will light but after a few minutes it will shut off. I have cleaned the photocell and filters. But the heater still has the same problem. please...
Have you checked the pump pressure? The HSI heaters are super temperamental, by design, to correct pump pressure and correct flame color. Depending on usage over a winter the nozzle could be worn to a point where the fuel cone is a spray rather than a fog, therefore the flame is burning rich (off-color) and the photocell shuts the unit down.
You are wasting your time if you don't check the pump pressure 1st!
Read these tips
Nov 17, 2010 | Heating & Cooling
The heater starts up but then heat shuts off within a couple minutes
i would look a a high limit problem.check for obstruction between heat exchanger and top of unit or plugged heat exchanger.remove top and look straight down and you should see burner flames between heat exch fins. depending on which ignition you have,could also be flame sensor problem.ususally with flame sensor problem burner shuts off within 20 seconds.hope this helps.
Aug 24, 2009 | Pool & Spa
I need the wattage on a GE microwave WES1450DMBB
Product Features
  • Electronic controls are easy to operate and offer one-touch operation
  • 1.4 cu. ft. capacity accommodates everything from small snacks to family size meals
  • 1150 watts of cooking power and 10 cooking power levels allow you to reheat and defrost quickly
  • 5 sensor cooking options automatically monitor cooking progress and adjust time and temperature for delicious results; sensor options include beverage, reheat, popcorn, potatoes and vegetables
  • Auto and time defrost functions make it easy to thaw food quickly
  • Express cook control with 1-6 minute intervals for cooking or reheating leftovers
  • Add 30 seconds option
  • 12-5/8" glass recessed turntable provides ample cooking space for oversized and oblong-shaped dishes
  • Clock and countdown timer allow you to conveniently coordinate meal times; reminder signals let you know when cooking is complete
  • Black finish adds a touch of style to your kitchen
try{ var divArr = document.getElementsByTagName('div'); var rpDiv = document.getElementById('tabbed-overview'); var spDiv = document.getElementById('saleprice'); var rp = getRegPrice(rpDiv); var cp = getCurrPrice(spDiv); if(rp!='none'&&cp!='sale'){ spDiv.parentNode.insertBefore(ocRegPrice(rp,cp,'pdp'),spDiv); } }catch(e){}1150 WATTS
May 10, 2009 | General Electric Microwave Oven
Very loud knocking noise that can be felt if touching the unit.
If the heater has a heat sink with a brass non-return valve then this could have a fault creating a hammering noise that resonates through the heater.
Mar 30, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Will light and run for about ten minutes then shut down
the home heating fuel will gel thus the heater will shut down
Jan 16, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Troubleshooting reddy heater 115,000btu
Remove the nozzle and clean it. Clean the photo cell also. Check the fuel pump pressure it should be 5.1 #.
Feb 26, 2008 | Desa International ReddyHeater® R115DT...
Reddyheater r100
the fan must be hitting th upper cowling. see that the fan bracket is fully seated in the cutouts in the lower half of the unit.
Dec 15, 2007 | Desa International ReddyHeater® R115DT...
Heating & Cooling Logo
54 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
