Question about Everex StepNote VA4103M Notebook
Keyboard J, U, and spacebar not working
I have no clue why, what can I do to try to fix this?
  • 70 Answers
The keyboard may need cleaning or is broken.
To clean it, you could get a can of canned air, tip the laptop on it's side or upside down (carefully!) and blow out under the keys using small shots of air.
If that doesn't do it, you can try hooking up a regular PC keyboard using a regular PS/2 Keyboard or a USB keyboard and see if that will work for you.
You may be able to find a replacement keyboard online, but they can be tricky to replace.
Posted on Feb 11, 2009
My spacebar is not working how can i fix this
If on a Desktop, it's best to buy a new keyboard. On a laptop, where the kb is fastened to the case, try blowing out from under the spacebar with compressed air. That kb can be replaced too, but it's a hassle.
Mar 18, 2014 | Computers & Internet
Logitech DInovo edge spacebar not working
try to remove dust in your keyboard by using paint brush or compressed air.
Nov 05, 2013 | Logitech diNovo Edge 9676850403 Keyboard
Why does the space bar only have a centre touch point
The reason for this happening is that the metal bar under your spacebar is not properly attached. It's time consuming to properly fix it, but it's an easy fix at that.
All you need to do is remove your spacebar and metal bar (shaped somewhat like a tall C, if held sideways). On the bottom of the spacebar will be approximately 2-3 small clips in which the metal bar will snap into. Once snapped into place, you will want to look at the area where the spacebar goes. There should be two small clips at each end. With the metal bar clipped into the spacebar, you want to place the "ends" of the metal bar under the clips on the keyboard and very carefully place the spacebar into the hole on the keyboard and snap it into place. Now test it out and it should work fine. If not, it's likely that the metal bar came out from under the keyboard clips. The annoying part is snapping the spacebar into place without having the metal piece come out from under those clips, so you may need to perform this task a few times.
Here's an example image...
Jul 22, 2013 | Asus Systems Asus X501A Notebook
Hi my keyboard started working erratically a few days ago. it's an A4tech keyboard. and at first while using photoshop the spacebar stops working then I would have to reset it to have it start working...
It sounds like the keyboard is starting to you can try a different keyboard if you have one and it that works your keyboard is bad. If your other keyboard doesn't work to your port were your keyboard is plugged into maybe going bad, let me now if any of this helps.
Aug 02, 2011 | Compaq Keyboard
Spacebar on my Microsoft Natural Ergonomic Keyboard 4000 is sticking in the down position.
Take out the space bar button and change the position of the "sway bar" shown in http://www.paulstravelpictures.com/MS-Natural-Ergo-Keyboard-Sticky-Spacebar-Fix/index.html
There are 3 positions you can keep the sway bar - The middle positions worked for me and probably will work for you too.
Sumesh K
Jun 14, 2011 | Microsoft Natural Ergonomic Desktop 7000...
Keyboard Spacebar does not work
you will change the space bar button
Jan 10, 2010 | Dell F3534 Touchpad
Dell inspiron 6400 faulty spacebar?
You need to have the keyboard replaced. If you can't get it fixed locally, contact me for shipping information, I fix these kinds of problems a lot.
Jan 05, 2010 | Dell Inspiron 6400 Notebook
Frustrating problem with spacebar causing skip
did you tried to clean the inside of the keyboard coz sometimes the dust is the cause why some characters not working properly.
Sep 16, 2009 | Computers & Internet
Keyboard Failure
Buy a new one.not worth fixing.RICHARDM69
Aug 31, 2009 | E-Machines AAFQ50400000K0 Keyboard
Spacebar-quit-working-after-cleaning-the-gunk-underneath-----now-it-does-not-work-at-all? it-is-a-vaio-keyboard-with-media-center-controls-at-the-top...........
Have you tried applying pressure gently until it snaps back in place? That could be the issue, is that the spacebar unsnapped itself when you were cleaning it. If you were using compressed air (canned air) then you may have blown something underneath it and it jammed itself in there. Trying turning the keyboard upside down and gently tapping it on a hard surface to see if anything else comes out.
Feb 18, 2009 | Logitech 967437-0403 Keyboard
Everex StepNote VA4103M Notebook Logo
176 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
