Question about Dell Dimension 8200 PC Desktop
Pc wont turn on
The pci monitor plug ( the plug on the motherboard that the monitor plugs into ) was broke when i wiggled it i heard a pop and my pc turned off when i turned it back on the fans turned on but the hard disk didnt ......what popped thats keeping my computer from turning on please help motherboard L7VMM3
  • nipples291 Feb 12, 2009
    I just purchaced a video card i installed it the hard drive wont run. What do i check if the hard drive dont run? please any ideas
    Scholar:
  • 75 Answers
You will need to replace the motherboard if thats gonna be costly take it to a local repair shop and see if they can mend it.
Posted on Feb 11, 2009
  • ashish13
    ashish13 Feb 12, 2009
    mate it seems that ur motherboard was shot... can you access the BIOS at all ???
I figure I need a replacement graphics card. The PC worked fine yesterday. Turned it on today and no signal to monitor. Tried both DVI and HDMI with the same result. Monitor is Gateway LP2417.
try pulling the power cord out of the monitor and then wait 30 seconds and pull it back in to monitor . Are you dealing with a graphics card or a motherboard video chip. May have DVI and HDMI plugged into motherboard rather than PCI video card. Check Bios to see if conflict exists between motherboard video chip and PCI video card.
Dec 31, 2015 | Gateway GM5632E 2.4ghz Core 2 Quad 3GB Ram...
ASUS m2n68-am se2 and graphic card's problem
Sounds like the PCI slot is no longer working.
Jan 10, 2013 | ASUS M2N68-AM SE2 Motherboard
The video prt where you plug in the monitor cord is broke off. What can I do so my monitor works?
Is the port broke off the computer or the back of the monitor? If its off the computer and you have expansion slot available on the motherboard you can get a video card. Make sure you get the right type as a PCI video card will not fit in a PCI express or APG type slot.
Aug 08, 2011 | Computers & Internet
The monitor will not turn on. When i put a PCI Express slot video card do not come on and it do not beep but with the AGP video card in place i get a contentious beep and the monitor do not come...
It sounds like the placement of your video card on the motherboard is not correct. Try plugging out your motherboard of the casing and place it on top of the motherboard box with the black cover. Then plug in your video card and turn it on there and see what's going on.
If problem still persist, get an older pci video card. Then upgrade the cmos and try it again.
Jan 03, 2011 | Computers & Internet
I kicked my emichine computer and it broke. First the screen went slightly fuzzy and when i turned it off and turned it back on and it wouldnt show what the cpu was thinking on the screen.What could be...
I would check the components inside the case...sounds like something wiggled loose while you were kicking it. Open the case...first check that all the cards (pci/video/RAM) are properly seated in their slots. Next make sure the hard drive plugs havn't wiggled loose. Post back if it still doesn't work
Jul 18, 2010 | E-Machines eMachines Desktop PC
No display assus motherboard PSN73-AM ASUS MOTHERBOARD
When the PC starts up, do you get a BIOS display at all? Try fitting a graphics card into the board instead of using the built in port, if that works check the BIOS settings to see if the built in adapter has been disabled,
Mar 26, 2010 | ASUS P5N73-AM Motherboard
I get no video and the monitor is good. Need to
IT doesnt matter. If the Video Card is built into the Motherboard and has failed; you can get NEW Card that can plug into an Expansion Port on *********** board
Make sure your motherboard is compatible with the NEW video card. For example, PCI Express video cards won't work with motherboards designed only for AGP or PCI video cards, and vice versa. Tigerdirect.com has a good selection. Call their Customer Service Tech; they have great prices, sales and knowlegable Customre Service Tech to Check if it is the right Type of Card. Its probably PCI but check anyway.
Simply shut down unplug and open the computer side panel and go to the back of the Machine. If there is a separate Card (it will be obvious as it has a VGA port) Remove it and just install your new card in its place and plug in your Monitor to the new VGA port. If not then just POP OUT A FREE SLOT in the back of your Computer next to the Plug In Port so the VGA port that the monitor plugs into stick out the back and plug in your Monitor.
Close , plug in and INSTALL THE SOFTWARE THAT COMES WITH THE VIDEO CARD. Set all settings to DEFAULT or be creative :)
Cheers !
Aug 21, 2009 | HP Pavilion a1253w Notebook
I have an old computer with an asus motherboard, When I turn on the computer it boots up and goes to the windows xp window but then the monitor screen goes white and never goes any further thoug the...
It sounds like Windows might be loading a bad driver for your main PCI (assuming it's PCI) slot. Try plugging your monitor into the motherboard instead of the video card. Try re-installing your graphics card driver to the latest version, you can download these drivers through the company's website and looking for your video card's model. After re-installing the drivers, shut down your computer. Put your videocard in it's main slot and plug the monitor to it. This should do the trick.
Mar 25, 2009 | Computers & Internet
Component that the moniter plugs into is bent and broke off
Go and buy a new video card, but first you need to determine what kind you need, AGP, PCI, PCI Express, etc.
If you don't have the pin diagram for the vga connector you can ruin the motherboard.
I hope this helps.
Good Luck.
Mar 18, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 8200 PC Desktop Logo
85 people viewed this question
Alun Cox
