Question about Linksys (WRT54GC) Router
Red Internet Light
My linksys WAG200G will often lose connection and display a red light instead of the usual green internet light. The problem can be temporarily fixed by reseting the router but it just happens again an hour later. Any ideas...?
Check your username and password from the subscriber
Posted on Feb 26, 2009
    Problem Solver:
  • 8 Answers
While it is possible it could be the router, it may also be a bad ethernet cable/coax cable.
Is your router connected to a modem by ethernet? or directly to the wall outlet via ethernet or coax (pls specify which)
Sometimes it is simplest to replace that ethernet/coax that brings the internet to the router.
Posted on Feb 17, 2009
All lights on WAG200G is light up green, but when trying to go on internet, nothing happened. why?
Most probably you will need to upload the new firmware on your WAG200G as this issue is due to a corrupt firmware, reset the unit for 1 minute and then try to upload the latest firmware on the unit.
Mar 22, 2010 | Linksys WAG200G Router
The light indicator for internet showing red light, meanwhile light indicator for dsl is ok. What does it mean? Thanks
go to the website and go through the manual for this issue. You really need to do this so if you have any issue's in the futyre you can take care of them
http://www.linksysbycisco.com/APAC/en/support/WAG200G/download
Feb 20, 2010 | Linksys WAG200G Router
Problems moving the router and getting the internet.
your bedroom cable phone plug has issue.
These is not dial tone or low voltage problem in line.
So just replaced that phone cable and jack .then check.
Aug 07, 2009 | Linksys WAG200G Router
Linksys router's internet led always red
if your not able to connect then id try rebooting it all start with the modem then the router and your pc see if that helps and if nothing works it very well could be the modem
May 20, 2009 | Linksys WAG200G Router
Linksys WAG200G doesn't have a green light with the internet.
Try unplugging the WAG200 ADSL Home Gateway, leave it off for a minute, then plug it back in. Sounds too simple, but it works more than half the time.
Apr 14, 2009 | Linksys WAG200G Router
Internet cutting on and off
If you haven't done a firmware upgrade I think doing so will be of a benefit to your problem! Just remember to backup your router settings beforehand! Hope this helps!
--Joshua79
Apr 05, 2009 | Linksys Wireless-G WRT54GS Router...
Red led
When the internet light is red it means that the connection to the ISP failed.
To check the settings on your gateway, use your internet browser and type 192.168.1.1 in the address bar.
By default, the username and password is admin.
If you have a cable internet connection:
Under the setup page, select Obtain IP address automatically (DHCP) for the internet connection type (encapsulation). Save the settings. Then go the status tab and check if there is an WAN IP address. If none, power cycle the modem.
If you have DSL connection with PPPoE:
Under the setup page> Internet connection type (encapsulation) select RFC 2516 PPPoE.
Multiplexing should be VC.
Under PPPoE settings, you need to enter the username and password that your ISP gave you. Then save the settings. Go to the status tab,
click the connect button. You should be able to get online.
Jan 23, 2009 | Linksys WAG200G Router
I have just connected to the internet using the modem provided by my ISP. It is not wireless and so I have just tried to connect my linksys WAG200G and can't seem to get it to work. The internet light is...
Check if the IP address of your machine is within the network as assigned by the DHCP server of your modem/router. You might need to reconfigure your network settings to "automatically obtain IP address" and "...DNS". You can verify this by opening a command prompt and type "ipconfig /all"
Sep 25, 2008 | Computers & Internet
Internet Light Stays Red on WAG54GS Wireless Router
If your router's internet light is red it means to say that there's no connection. You really have to call Tesco.
Aug 21, 2008 | Linksys (WRT54GC) Router
Zoom X6 internet light constantly red
the internet light, is usually a blinking green, showing that it's seeing the internet signal. The only reason it's red, is cause there's no net signal..double check the phone line going into the back of your router, and change it if you need to.
check your computers warranty here 4 FREE
Mar 16, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Open Questions:
Linksys (WRT54GC) Router Logo
797 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
