FixYa.com
Tags:
Mackie SWA1501 Subwoofer
Mackie swa1501 bass output problem with srm450
By kcw573 - usenet poster
I have two active mackie srm450's connected to two active mackie
swa1501 underneath. We run the bass guitar and kick drum through this
setup. I have the volume on the back of the bass bins at 3o'clock and
the tops at 12o'clock. We still can't get adequate bass output from the
subs. More seems to comes from the tops. What are we doing wrong? Is
the active crossover adjustable? All cabling is new and we use the
cfx12 mixer. Bassist's amp/cab is miked with sm57, as is the kick drum.
Any advice most welcome.
Thanks,
Jeff
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 01, 2007
Helpful (85)
Powe33
Powe33 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
On 22 Aug 2005 08:49:18 -0700, wrote:
Yes, I have one..it is a nice box, especially for the $
I did a little test the other night by just plugging the BDI21
straight into my EP1500 power amp to see if it would provide a strong
enough signal to drive the amp to a usable volume and it did. I'm
considering getting a second one to keep in the van with the gear so I
can leave the other in the studio at home.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Helpful (85)
Cornish
Cornish - usenet poster
Rating: 0%, 0 votes
I would suggest that the problem is nothing to do with your speaker setup,
but to do with your choice of microphone. The SM57 is not really suited to
kick and bass cab mic'ing due to it being a small diaphragm dynamic. Go out
and get yourself a decent kick and bass microphone, such as a Sure Beta 52,
AKG D112, Audix D6, Sennheiser E602 (I use the Audix D6 which is fantastic
for kick)
Have you checked your speaker system on its own away from the band setup?
Hook up a CD player to the desk and play some music you are familiar with
and which has a good bass line. You should be able to get an idea as to
what is lacking (or isn't!) in your system and fine-tune any adjustments.
Let us know how you get on.
Dan
Solution #3
Not Rated (0)
Cato
Cato - usenet poster
Rating: 0%, 0 votes
Guys,
Thanks for your great replies.
I'm going to try the DI approach. The bassists amp and cab are awful,
so will use it as a stage monitior only. I've spotted the Behringer
V-Tone Bass BDI21 DI box at a very cheap price, appears to be a copy of
the more expensive Tech21 Sansamp model. Anyone had success with the
Behringer in a live application for bass guitar?
Solution #4
Not Rated (0)
Melissa
Melissa - usenet poster
Rating: 0%, 0 votes
Along with what the others have suggested, you should consider using a
DI box on the bass and not mic the cabinet. The other issue is that it
could simply be you don't have enough subs for the amount of low end
you desire. The 1501 is an ok box, but it does not get that loud or go
very low. You may need to double your inventory to get more punch. One
thing to try that can net you a little more output and even coverage
for your current setup would be to put the subs together at center
stage so they couple. This can reduce interference and give more even
coverage then having them split on each side of the stage, giving more
apparent output. You will need stands for the 450's if you were using
poles in the subs before. This may be all you need to help the
situation after you get correct mics and a DI.
Rupert
Solution #5
Not Rated (0)
man1
man1 - usenet poster
Rating: 0%, 0 votes
Make sure you haven't got one of the subs out of phase with the other.
Place both subs together and disconnect one of them. If they are out of
phase, reconnecting the other will result in less overall bass than the one
on its own.
Gareth.
Solution #6
Not Rated (0)
maartenw
maartenw - usenet poster
Rating: 0%, 0 votes
I fully agree with Dan but have one remark, just to be sure:
Check if the srm450 is connected to the SWA1501's
"High Pass output" and not via the "full-range output".
-Reijer-
Can you Help with these Home Theater Speakers and Subwoofers problems?
sts96 speaker wire
speaker wire's not long enough Answer This...
Refund money back to Best Buy...
I placed an online order last... Answer This...
turning off the speakers on my...
Iwant to turn off my speakers... Answer This...
Popping sound
Sub has an auto off when not... Answer This...
Sub-Woofer Magnavox MRD-200
El sub-woofer dejo de funcionar... Answer This...
Repair Service
Find Home Theater Spe. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
