Question about IBM ThinkPad T40 2373 Notebook
Not able to type in network key for wireless
Hey there. I just formated my IBM t40 and after I run all the up-dates including service pack 2 I try to connect to my romemates wireless connection (secured connection). The problem is, that it tries to connect without asking for the network key, and it failes to connect. An error message appears saying, that "Windows is unable to connect to the selected network. The network may no longer be in range. Please refresh the list of available networks, and try to connect again." I have tried everything I can imagine also in the properties of the wireless network and have no idears left. Before formating the computer I had no problems connecting to the network. Do you maybe have any idea of the problem?
    Problem Solver:
  • 15 Answers
1) If you are using the Windows Default Wireless Network Connection. Open the windows where you you will see a list of all wi-fi connections near by your location. On the left panel(Related Tasks) click on "Change Advance Settings" >> Wireless Network Connection Properties >> Click "Wireless Network" Tab >> from the Preferred Networks: list, remove the wi-fi connection you are trying to connect. Once your W-Fi connection settings are removed. You can either add it manually clicking on the Add button and entering all informaiton manually, or from the wi-fi network list click the network name it will ask you to enter the netowkr key....
2) if you are using any other Wi-Fi connection application, like the Intel's, follow the same procedure. delete the settings and try connecting again.
Posted on Feb 11, 2009
I simply cannot find the wireless driver for my t40 2373 ibm thinkpad. please help. ive looked for hours, download things and nothing works.
at the following link you will find the possible drivers for the T40 serie. Look under the section Networking: Wireless.
Make sure to identify which wireless adapter you have in your current system.
Jan 11, 2011 | IBM ThinkPad T40 2373 Notebook
Wireless switch location on a ibm thinkpad t40?
just check for any small switch around your notebook if you cant find try fn+f5 :)
Jul 23, 2010 | IBM ThinkPad T40 2373 Notebook
IBM t40 think pad wireless won't turn on, I can see the light but will not connect
Try to restart the Services of Wireless Zero Configuration or Wireless Auto configuration in the Services Section. To open service, type "services.msc" in the run command.
May 03, 2010 | IBM ThinkPad T40 2373 Notebook
IBMThinkPad T40 Wont connect to wireless networks.
Hello, if you see a yellow exclamation mark it means device drivers are not installed or are incorrect.
below is the link for IBM/Lenovo site that lists all the drivers for Thinkpad T40/T41. Go to that linkand scroll down to " Wireless Networking" and select the appropriate drivers: eg: Make sure it under T40 section, and not T41 since they are listed side by side.
since i am not sure which exact wireless card your T40 has i am posting this main link where it lists all options.
I would start with "ThinkPad 802.11bg wireless LAN Mini PCI adapter" if this doesn't work try next one in the list.
here is the link:
I hope this helps, let me know if there is a problem.
Kind reagrds,
Amar Sondhi
Jan 22, 2010 | IBM ThinkPad T40 2373 Notebook
Can't connect to my router anymore (WEP encrypted).
Hi deray953,
First we need to remove the previous profile in your wireless network. I believe you know the SSID for wireless connection using WEP security. You can check this by going to;
Using Windows XP SP2/3
1. "Control Panel" > Switch control panel to classic view ( look at the upper left side ). > Double click "Network Connections" > Right click "Wireless Network Connections" > choose "Properties"> Click the Tab "Wireless Networks" ( middle tab) > go to the list of profiles and remove the Wireless name or SSID for your home connections. > click OK and Close the properties of wireless.
To reconnect again, you need to know your WEP key or network key for wireless connections if not, you can do this procedure...
1.Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing or in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
d. Click on the Wireless Settings under Setup.
e. take note of the KEY 1 ...that is your WEP key..take note of it.
Connecting Through Wireless Zero Configuration (Windows XP SP1 and SP2)
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then, click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
Connecting to a Wireless Network on Windows Vista:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network's name or SSID and click Connect.
d. It will ask you for a network key. Type in your wireless network key on the field provided. Then, click on Connect.
Apr 02, 2009 | NetGear RangeMax WPN824 Router
Home router won't exchange IP to set up wireless on laptop??
try resetting the router to factory settings, it may have been set to allow only 2 or 3 wireless connections, just take a pen and hold it in the reset hole on the back of the router till all the lights blink and it restarts
Dec 10, 2008 | IBM ThinkPad T40 2373 Notebook
Need Wireless Card on my T40 23734NU
if u ve usb slot and pci slot in ur laptop u can use wireless, there are may brands available in market like belkin , netgear , u can connect install the drivers come along with the wireless card install it and u ll go online wireless
Nov 18, 2008 | IBM ThinkPad T40 2373 Notebook
Ethernet driver
Can you please state the Brand and Complete Model of your Laptop.
Jun 11, 2008 | Belkin (F5D7010) 802.11a, 802.11g/b...
Ibm thinkpad t40
Follow this step
1.Click start-->Settings -->Network Connections
2.check to see that you have Wireless Network Connection
if no that mean you need to install driver for your Wirless.
Apr 20, 2008 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T40 2373 Notebook Logo
784 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
