Question about Frigidaire FTF2140ES King Size Front-Load Energy Star Washer w/ Tumble Action
When drum spins it makes alot of noise.
I checked the springs and shocks they are fine
    President:
  • 1,902 Answers
Check the main bearing and the pulley to make sure that they are both working properly if the bearing is bad it will make the drum bounce all over, if the pulley is bent it will make kind of a grinding noise along with things jumping everywhere
Posted on Feb 11, 2009
How do I check the belts or springs holding the washer tub
to check the belt or Air shock , its easy to remove the rear access panel , you can have a look for shock and motor & belt but there are a lot of reason for your complaint for doesn't spin out water and noisy when spinning it may be have kinked in the drain hose or the spin start before pumping water out properly leads to load unevenly distributed in the movement of the drum, so i believe that your problem in pumping the water out. Alaa Refaei
Mar 04, 2014 | Frigidaire ATF6000ES Front Load Washer
Loud Bearing Noise During Spin Cycle- MAH4000AWW
I don't know these front loaders so well but, here's a couple of things to look for.
1) If belt driven, look for the spring loaded tensioner. Once tension is released, check the pully & see if it has excessive play.
2) Check the gasket on front panel & see if drum has rubbed thru it in order to make metal to metal contact.
3) There is alot of pressure on that rear bearing...make sure it's not egg shaped or scored on the inside.
If all else fails, shotgun it (in other words, replace those moving parts you suspect:)
Nov 15, 2013 | Maytag Washing Machines
I have a ge frontload washer and it recently started making a really loud noise when in spin mode. It sometimes bangs the side also. What's going on?
It could be a few things that could be wrong with it. With the washer empty does the wash drum sit centered within the door? Also the drum should be level and not sag down or up. If it does, then it could mean the the springs or shocks are broken. You can check shocks by removing the two screws on the front bottom access panel. There are two shocks, and are mounted on the bottom of the the drum.
If the drum sits level and centered in the door, turn the drum by hand and feel how it spins. It should spin true and quietly without any kind of thumping or scaping noise. If it makes a thumping or scraping noise, or it wobbles as it spins this could mean the the spider arms that support the wash drum are broken. If it does not make any abrupt noise when you spin it by hand but when the machine is in a spin cycle, it spins with a loud roar like a jet plane is landing in your laundry room, then the bearings are gone.
It can be very expensive to have these machines servied since the machines needs to be taken apart to get the drum/bearing assembly. If you are handy, you can replace the bearing and seal for less than $100 in parts, but, if the spider assembly is broken, the parts alone can cost as much as a new washer.
Apr 19, 2011 | GE WSXH208A Front Load Washer
Washer makes noise and jump around
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Aug 08, 2010 | Hotpoint Aquarius WD640 Front Load...
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
Wont spin and makes alot of noise
You could check if its drum by removing the belt turn drum by hand if its okay no noise check motor pulley ....is motor ok ?
Nov 17, 2009 | GE Profile Prodigy WPSE4200A
Machine making a knocking noise during spin cycle. The drum shaft has alot of free play front to rear and I suspect that is where the problem resides.
If your machine is making louder than normal noise during spin it could be the failure of the basket. Mine is just under three years old and the basket became looser than normal in the tub. I diassembled the machine...a lot of work...and found the aluminum casting around the shaft and bolted to the basket had rotted away. It looks like it was attacked by the bleach since I had my water checked and its pH is fine. It is likely the root of the smell we have experienced with our clothes when they sit too long in the machine. I spoke with GE and they gladly agreed to replace the parts needed but it is a ton of work to install them. I plan to treat the new part with some zinc chromate if I can get some before the parts arrive. See the picture if it attached correctly.
cid:07d1be63-2d47-407a-89ca-6090b4131d58
Nov 16, 2009 | GE WSXH208A Front Load Washer
Bangs in Spin Cycle even Empty
alot of people don't level there machine properley pull out a level and level the machine what it is when the machine gets up to speed the drum is not level
Feb 12, 2009 | GE Energy Star WCVH6260F Front Load Washer
Open Questions:
See all Frigidaire FTF2140ES King Size Front-Load Energy Questions
Washing Machines Logo
158 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
