Question about Konica Minolta DiALTA Di200 Copier
Paper jam in the upper chamber of a minolta Di351f
I just inherited a minolta Di351f and the screen says that there is a paper jam. I can find the sensor. Any help available for this would be greatly appreciated.
  • sam gerban
    sam gerban May 11, 2010
    in what area in the copier.?
    is it in the main body of the machine,right side.or the upper section {document feeder}
    Problem Solver:
  • 11 Answers
Assure there is no paper in paper path. torn pieces, etc.
there is a exit sensor in the fuser assy(hot section at exit) there are paper seps. at the roller - dont damage the roller. check to see if actuator is block / broken.
Posted on Jul 30, 2009
Minolta di351f software
Drivers for this printer are available here. However there does not seem to be any traditional software on offer for this printer.
Sep 13, 2012 | Minolta Di351F All-In-One Printer
Media jam upper tray. what does that mean?
Top draw has a paper jam media=paper or the bypass tray or where the paper exits
Oct 11, 2011 | Minolta magicolor 2200 DeskLaser Printer
I HAVE A MINOLTA Di200f/Di251f/Di351f ERROR CODE CO500
First check the right side cover where the image unit is located. Check the two latches that latch the door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
Jun 23, 2011 | Minolta - DI200F Printer
Error during 1st install of paper
konica minolta magicolor 1680mf service call 0094
Help me
May 30, 2010 | Konica Minolta magicolor 1680MF -...
Di351f. Can not print over the network.
I am confused. If you can see the printer via the web browser and you can print a window's test page you are all set up and ready to print. There should be no problem printing as long as you have that printer selected as the default printer and it is selected in whatever program you are printing from. What do you mean by "straight over the network"
Dec 22, 2009 | Minolta Di351F All-In-One Printer
Need to reset admin password
meter stop 00 stop 01 service mode. select adimastrator default is 12345678
May 06, 2009 | Minolta Di351F All-In-One Printer
I have a Minolta Di351f. It indicates code CO500. This occurred after a power outage last night. What should I do to restore proper operation?Thanks.
Look on the right side of the control panel, just in front of the display contrast slider adjustment, and you will see a small hole. Using a paper clip or similar pointy instrument, press the pushbutton switch in that hole.
The machine will go into warmup mode. When you see a small dot centered on the left side of the touchscreen display, press "3" on the keypad. This will take you to the initial mode screen, where you will see "Trouble Reset" on the touchscreen. Press it.
If the C0500 code comes back in about 60 seconds, it means that you do indeed actually have a problem with the heater lamp not coming on, possibly a blown lamp or thermal fuse.
Dec 10, 2008 | Konica Minolta DiALTA Di200 Copier
Di351f admin code reset
has to be 8 digit could be 00000000
Sep 03, 2008 | Minolta Office Equipment & Supplies
Konica Minolta DiALTA Di200 Copier Logo
280 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
