<1e68368.1ue5k0p60mw1fN%{$ I think the shop is telling porkies. This problem is a purity error, and can have been caused by a strong external magnetic force, prehaps too strong for the internal degaussing circuitry, but this is rare. Other possibilities both point to the CRT, either poorly adjusted when built, or having suffered a knock at some time. Colours should be uniform across the screen, although slight variations in brightness levels are usually in manufacturers specs.
Show your appreciation by commenting on Discolouration of 17" Graphite Studio display:
Solution #2
posted on Aug 01, 2007
Charlie - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
My daughter's fiancee loves it as well, I've hooked up his Playstation to the composite and stereo inputs to allow him to share the clarity ;-) (is this sacrilege???)
Have you tried the 2nd hand market???
Yes they can be most of the time!!!
regards Bob W
Was this solution helpful? Show your Appreciation by rating it:
Solution #3
Beresford - usenet poster
I didn't buy direct from Apple, but they became involved because my original 17" was returned as a DOA ((Dead On Arrival) any Apple product returned with a defect within 2 weeks of receipt). They (Apples DOA department) eventually agreed that the problem was down to a defective tube, but I still don't know if that was the first or second Studio Display.
As far as geometry goes, I could get straight verticals over 2/3 of the screen with outrageous barrelling at either side. Try viewing a file in page view and check the curve on the sides of the rectangle that shows the page edge to see what I mean, it may not look much but I tried my G3 on a NEC C700 17" which I adjusted for a friend and vertical straights were perfect from one screen edge to the other.
Your dealer may not have knowledge of the discoloration problem, but Apple certainly should.
Regards Bob W
Solution #4
Reynolds - usenet poster
The bastards! I was willing to pay for one, but the sods have stopped making the blue one, which would have plugged straight into my G3, and now do only all-digital versions. This would involve me buying a video card to drive it, and the cost adds up to around a thousand quid.
I'd love one of the blue ones...
Bastards...
-- Peter
Solution #5
2Pansy - usenet poster
It took a bit of fiddling for me to get the genometry sorted out on mine too, actually on that score I'm begining to suspect comething odd within my walls as my current monitor, my new monitor and my widescreen TV all have the image skewed so that the right hand side is higher.
I shall complain but the probablem is that despite being painfully slow to do anything they are very friendly and seem to have no knowledge of this fault and seem to get strock in to order so they tend not to have anything to compare it to. The 3 weeks I waited whilst I believed they had sent it back to Apple were in fact spent with it sat there doing bugger all until an "engineer" decided to mess with the controls on the front and completely miss the actual problem so I'm begining to be less warm with them. Anyway did you actually buy from Apple? I did try ringing them to see if it was a known fault but gave up after 10 mintues in a queue. -- -> The email address in this message *IS* Valid <-
Solution #6
Bomber - usenet poster
I had a similar problem with 2 (YES TWO) 17" B/W studio displays, straight vertical lines were also a problem (couldn't adjust geometry to compensate [I'm no novice]). Apples line was that the original was within apple tolerances, the second was worse than the first not for geometry but for colour!!! I'm very happy with the third monitor i was provided with by Apple. It's a 15" LCD studio display (at no additional cost) :-) :-) :-) :-) All I can suggest is that you complain, complain and keep on complaining!!!
