Question about Whirlpool LEQ8611L Electric Dryer
Whirlpool electric dryer LEQ8611LG1 not drying on sensor dry.
Clothes are still very wet when use sensor dry and the dryer does not turn off at the end of the sensor dry cycle it just does right into the Wrinkle Shield cycle. Time drying takes long than use to. I have to ususally put the clothes on for 70 minutes and then for about 50 more.
    President:
  • 1,902 Answers
Check your lint trap and the vent. make sure that there are no obstructions in either of them. Then take a look at your timer to since it is not stopping when you tell it too.
Posted on Feb 11, 2009
My duet whirpool electric dryer keeps stoping before my clothes are dry
Make sure you are not using a timed drying setting. Use one of the pre programmed functions on the dial. These settings are meant to use a sensor and stop when the clothes are dry. If the problem continues on one of these settings, there is likely a problem with the sensor or your heating element
Sep 15, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Tip
Dryer Dry Time Appears to Jump or Stall During Auto Dry Cycles
The operation of dryers during the Auto Dry Cycles is based on the moisture content of the clothes as they cycle over the moisture sensor. At the start of the cycle, the default estimated time is displayed depending on the cycle selected. The moisture sensor feeds information to the control based on the "wetness' of the clothes during the first 5 minutes of the cycle. The control then calculates and display a new estimated time making the time appear to "jump".
Recalculation happens again based on the reduction in the "wetness" of the clothes when the Estimated Time Remaining is between 15 to 5 minutes. The control will extend the cycle and display the Estimated Time Remaining unchanged if it "sees" no significant reduction in the wetness level of the clothes. The dryer will run longer than initially projected and give the appearance that the displayed time has "stalled".
Clean the sensor bars for any films or dirt build up to make sure it sends accurate information to the control. Level the dryer front to back and side to side to ensure the clothing will tumble properly and making good and proper contact with the moisture sensor bars. Check the dryer vent duct for any restriction to ensure a good air flow as the operation of the Auto Dry Cycles is based primarily on the air flow condition.
It is highly recommended to clean the lint filter before every load and make sure the dryer is grounded at the wall plug.
on May 17, 2010 | Whirlpool WED9200SQ Electric Dryer
Amana electric dryer timer doesn't advance during
If this is one of the electronic models: Clean the sensor strips located inside the drying area. As wet clothes rub against these the control monitors the resistance changes and knows the clothes are still wet therefore it continues to operate. When buildup from dryer sheets and fab softener get on them strips a barrier is formed that repels dampness. Therefore the control does not know the clothes are wet and goes to the end thinking all is Kosher. Clean them sensor strips with Windex and party on!
Jun 18, 2012 | Dryers
I have a Kenmore 500 series dryer, model number 110.79522800 that will note completely dry clothes. It seems like it doesn't run long enough, heat high enough or a combination of both. What can I do to...
Your Sensor that senses the clothes are wet or dry is shorted out. The dryer works likes this so the dryer heaters dont stay on while the clothes are dry. When the sensor senses the clothes are damp or wet, the heater stays on, when they start drying the sensor senses it and starts to turn down the heaters
http://tlc.howstuffworks.com/home/dryer6.htm
Mar 10, 2011 | Dryers
Dryer pauses several times and takes 6 hours or more to dry it does not heat.
so it is drying clothes but is taking forever:
http://www.applianceaid.com/dryertip.html
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
so the dryer is not heating:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
these should fix the problem Good Luck Tim
Feb 19, 2011 | Danby DCD5505W Electric Dryer
My dryer does not dry clothes
i would start by checking the thermal fuse and then the heating element itself.
Jul 28, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool duet dryer - when using the settings that automatically sense if the clothing is dry the dryer is saying the clothes are dry but the clothing is still damp
Easy fix: Look inside the drum below where the filter goes in. You will see two metal strips. They sense the wetness. Now get this: the dryer sheets rub against them and a thin wax buildup on them prevents the controls from properly determining wetness. The control has no clue the clothes are still damp and thinks everything is kosher; so it advances to the end. Solution. Clean the stuff off of the sensors so that they can sense the true wetness once again.
May 22, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer keeps drying and getting too hot
Check the dryer vent .The vent is stopped up,in the vent,or in the inside of dryer,in the lint hopper.Clean it out and unstop the dryer,and the vent.
Oct 10, 2009 | Whirlpool LER5636P Electric Dryer
Machine drys fine on timed cycles but shuts off before clothes are dry on automatic cycle.
First try cleaning the moisture sensors with rubbing alcohol, these are two silver colored strips located inside the drier just below the lint cleanout
Oct 31, 2008 | Whirlpool GEW9250 Electric Dryer
Kenmore Elite HE4 Electric Dryer - heat but not drying
you have thermistor failure/ located inside machine reason for premature heat
Oct 07, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool LEQ8611L Electric Dryer Logo
348 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
