Question about Konica Minolta DiALTA Di200 Copier
Toner cartridge on our Minolta Di200 will not go in all the way
Toner has been replaced before with no problem. The toner is the correct replacement number. Will not go in up to the black line...stops about a quarter inch or less out. Tried working with the empty cartridge to see what was wrong and could get that one in any farther.
  • 547 Answers
It must be wrong replacement part take it with you and get the exact same one
Posted on Feb 11, 2009
I have a konica minolta 130f and it's telling me to replace toner when there is still toner. infact I refilled not quite long. what do I do
Did you replace the electronic chip on the toner cartridge? if not then the copier still think your cartridge is dead replace the cartridge with the correct OEM cartridge do not use third party or do it your self
Nov 07, 2016 | Konica Minolta Office Equipment & Supplies
Minolta ep 6001 cf 0072
Sir/Mam,
open the front door and close it , wait a sec
Power off the machine
Take the toner bottle out!
power on the machine NO TONER BOTTLE IN IT
when the machine ask for toner put it in properly if the nub on the bottle is damage replace it that is how the bottle is turned bye the machine so ensure it is not damaged and install the correct bottle and correct TONER. The code is a problem with toner motor system.
Aug 09, 2014 | Konica Minolta Toner Cartridge Black 50000...
STARTS TO PRINT,THEN STOPS AND CODE C1300 POPS UP.
print head is bad replace it if you can find one that is a legacy Minolta machine, Now Konica Minolta, try this site for a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Feb 13, 2014 | Konica Minolta Di200 Di200f Di250 Di250f...
Konica minolta bizhub c250 error C-2AO3
magenta toner cartridge EEPROM access error, cleaned the connection between the toner cartridge and the machine once cleaned if the issue persists remove the toner cartridge and put back in again if again the error persists replace the toner cartridge with a new one and last resort if the issue is still not fixed then replace the mechanical control board.
Oct 04, 2012 | Konica Minolta Minolta Konica Bizhub C250...
Error code C0F32
This error means Imaging Unit ATDC (automatic toner density control) failure. Open and close the right side door where the imaging unit is. If the code comes back you are going to need Imaging Unit service or possible Imaging Unit replacement. The best option and the cheapest is to locate a new imaging unit and replace it yourself. These units are very easy to change and similar to replaceing a toner cartridge in any laser printer. Just do a search for Di200 Imaging Unit.
Good Luck and Thank You for using Fixya.
Apr 14, 2010 | Konica Minolta DiALTA Di200 Copier
Cannot revolve cartridges
Doing a complete power off/on and following the notes on Konica/Minolta website for changing cartridge
Jan 27, 2009 | Konica Minolta magicolor 2430 DL Laser...
Can't find toner collection box
So which is it, a Di200 or a Di520?
A Di200 has no toner collection box - the waste toner is recycled.
The toner collection box on a Di520 is located in the rear of the machine - just remove the main rear cover and it is obvious.
Nov 18, 2008 | Konica Minolta DiALTA Di200 Copier
Toner
Di200 [Subject] "Please Add Toner" is displayed even though the toner bottle is full. The ATDC circuits have been checked and the main and sub hopper motors are good. [Description] "Please Add Toner" is displayed even though the toner bottle is full. The ATDC circuits have been checked and the main and sub hopper motors are good.
[Solution]
CAUSE: Inside the sub hopper, the magnet (P/N 9326-2900-06) may be catching on the inside of the hopper, preventing proper actuation of the Sub Hopper Toner Empty switch.
SOLUTION: Make sure that the actuator can move freely up and down when no toner is in the sub hopper.
Dec 21, 2007 | Konica Minolta DiALTA Di200 Copier
Konica Minolta DiALTA Di200 Copier Logo
43 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
