Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
F1 code on fisher&paykel DD603 dishwasher
The lid assembly isnt sealing, I can only assume the lid actuators are bad, but how do I test them to make sure its not something else like a problem in the control panel?
    President:
  • Fisher and P... Master
  • 2,651 Answers
If you remove the lower drawer assembly, there is a pretty helpful techsheet/trouble shooter, that will get you intotest mode for the lid actuators. a quick way (in my experience, is color.. they now preoduce a black set of actuators that have a REAL low failure rate,,if i see that your actuators are white'off white in color, i generally reccomned replacing them with the newest set
Posted on Feb 12, 2009
I have a Fisher & Paykel Model #DD603 double dishwasher it is coming on with a code F1 with a little wrench Whats going on ?
An F1 fault means that the Mains Filter board on the bottom pan has detected water, a leak. There are, unfortunately, a few possibilities of the cause of this. Most likely it is bad lid motors (the motors that lift and pull down the lid to seal the drawers) or a broken Link Support. This is the plastic piece that hold all the hoses and wiring out of the way when you open and shut the drawers. A portion of this Link breaks free and gets lodged in between the drawer and the lid causing water to pour out into the lower pan when the unit is running. You'll need to have a Tech out to take a look at it, if you can find one. Good luck.
Apr 22, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Can anyone help me with my fisher and paykel DD603 the top draw is showing F1. fault 1. thanks
When F1 is showing up then there is a leak. The leak is causing by the top lid seal not close down tightly to the opening tube surface groove. Pull out the tube, put in tower in the bottom housing accessing from the left side. Only this side you can have room to put your hand in drying out the bottom. Do the same thing with the bottom drawer since the floor sensor is at the bottom and when it detects water then there is some water at the bottom housing of lower tube also. After Drying it out you can use You can use the lower tube wile ordering parts for the upper tube. Need to order 2 upper actuators and a lid seal with YOKE, if you want to do it yourself. Otherwise, have a F&P serviceman come in and diagnose the problem, not any handyman since the F&P dishwasher is not like others.
Dec 27, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Flashing F1 code, how do I fix
F1 code is water leaking. 1- Dry out the bottom housing to make the F1 disappear. 2- Replace Actuators and the lid seal to prevent this happens again. The actuators is pulling down from the left and right sides to hold the top lid against the top surface of the tube groove to seal water from coming out during the wash cycle. When actuators are bad, they can not hold the lid down or make the lid tilted to one side hence the leak is coming. When the lid is tilted for a long time the seal is distorted then it has to be replaced since it is out of tube groove shape
Dec 11, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
Fisher Paykel DD603 Problem. Top drawer shows F1 and pump runs continuously. Lower drawer does nothing, no display. I think the Electronic Controller in lower drawer is fried and maybe the Mains Filter...
Yup, definately the bottom drawer controller, for some reason you can run a DD603 with no board in the top, so long as you have a board in the bottom, but not the other way around. This is the fault you get, constant F1 from the top drawer. If you are stuck try removing the display cable from the bottom controller, this may help, so long as you leave the chassis harness in.
Sep 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 Error on Fisher & Paykel Nautilus
It leaked before leading to this.
1- Unplug the power.
2- Dry out the leak.
3- Before taking off the lid seal, check if Lid actuator working by going to diagnostic mode. 4- Select LD.
5-Pull the drawer half way out so you can see the lid going down or not when you turn on by pressing lock button.
6- Press the lock button again to release the Lid.
7- Most the time it is a Lid actuator problem and your seal look good, then you replace the Lid actuator only.
8- If it is a problem with the Lid actuator and your seal look bad then replace all .
Jun 21, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer stuck, lid lock motor bad and guide bars, if white guides , need to replace with black. Tech said $580 for Fisher Paykel DD603-SS Motors and guides
That's right you will need New Black lid Actuators fitted top and bottom also new retro link supports if you still have the factory plastic ones and maybe a new RFI module if you'd had a F1 fault. Sounds like you've been told this, so now all you need is to get quotes for all these parts to be fitted at a cheaper price. cheers
May 06, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher Paykel DD603
The top drawer on our DD603 top lid doesn't seal allowing water to spray out and down the sides.
Aug 10, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
786 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
