Question about Creative Labs ZEN Vision:M Digital Media Player
Creative Zen Vision M won't charge it's battery.
I can only grt it to work off mains power - it doesn't work while plugged into my PC, unkess its plugged into the mains charger at the same time.
Any suggestions? Need a new battery perhaps?
  • Anonymous Mar 10, 2009
    same as the person who can only use thier player when electrically plugged. it does recoginze it on the PC. Battery does not keep it on. It turns off.
  • sharvesh Mar 29, 2009
    battery doesn't seem to charge. Works only on mains supply.
Check your usb cable...i had the same problem...
I have a usb cable that came with it ( or some other mp3 player i bought), but it is way too short, so i bought a cheap ($1) and longer usb cable. The computer recognizes the mp3 when connected, but it wont charge with the long and cheap cable.
Maybe you also have a long (or short) cheap usb cable...or maybe your usb cable is plain broke...
Posted on Mar 28, 2009
Hi . look at the top of your player when you connect it to the computer. if there is a flashing blue light (you should look to the switch which turns the player on) wait for a few hours (player should be connected only to the computer not an external charger).
Posted on Apr 05, 2009
My zen vision m 30 gig only comes on when plugged into the mains
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 01, 2012 | Creative Labs Zen Vision Digital Media...
My creative zen vision m works (power on) when i use my wall charger and shows "power plug" icon a but when i turn it off it doesn't indicate charging or blue light. i haven't use it for 2...
if you are only getting the power plug symbol on the player when you are trying to charge it that means there is something wrong with the battery or something is wrong with the main board and cannot see that the battery is connected. Even though you just replaced the battery that could still be the issue again
If you need any more help, parts or your player repaired you can go to my repair service web page and e-mial me, call me or contact me threw my Ebay user name at from my web page at firehouse7777.weebly.com Thanks
Dec 01, 2010 | Creative Labs ZEN Vision:M Digital Media...
My creative zen works when plugged in but doesnt charge
Your battery could be worn out and need replaced. You can find a replacement battery on google and dis-assembly instructions here http://www.anythingbutipod.com/archives/2006/02/how-to-disassemble-the-creative-zen-vision-m.php
Jun 25, 2009 | Creative Labs ZEN Vision:M Digital Media...
Vision: M won't charge
The battery not charging,
I hat the same probleam. Solution reset the unit while is plugged on the Ac charge, turn off and on. will work.
ciao Enzo
May 10, 2009 | Creative Labs ZEN Vision:M Digital Media...
Zen wont work on battery
The battery is bad or the charging circuit is flaking out. Try plugging it in and from the wall side of the charger, unplug and plug it in several times. Sometimes on the Zen players that will shock it back into charging. I have seen that same charging issue on several models of Creative players.
Cheers
Jan 04, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen 8gb wont switch on or recharge
I had the same problem. Tried recharging from both PC and mains recharger. Tried re-setting and re-charging. All I got was the blue charging light pulsing on and off. The ZEN would not charge. Eventually I tried a Software re-set. (Slide the on/off button to the On position and hold it there whilst hitting the re-set button). I then tried re-charging and everything was fine. (It did take about 10 - 15 mins recharing from the PC before the device did actually respond, but that is normal after it is fully discharged)
Cannot guarantee the above will work every time or for everyone, but it saved me returning it to Creative and an eight week wait.
Apr 28, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative ZEN Vision M
Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize
If that doesn't fix it try the USB cable
Screen Doesn’t come on anymore
http://www.anythingbutipod.com/forum/showthread.php?t=18859
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Feb 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative zen vision won't turn on
Q. Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
also try this if above doesnt work
Feb 02, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative not charging
there seems to be a problem with the batteries for the Zen. I have just sent mine in for warranty work as it will work if you have it plugged into an AC adapter but it won't work as soon as it's unplugged even after charging all night. The USB will not charge it either. Creative has sent a replacement unit, but there is a serious problem with the battery.
Dec 24, 2007 | Creative Labs ZEN Vision:M Digital Media...
Lemon?
return it while u have u receipt in sight
Apr 28, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
1,029 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
