Question about Acer Computers & Internet
How do I make changes in the screen adjustments for a P244W LCD
I hit MENU and go to the first choice which is Picture. How to I get over to the actual things to change, ie brightness, contrast? Every time I hit the left or right arrow keys on the monitor it just takes me to the next category..
  • wronyack Mar 26, 2009
    exactly as described above
    Sergeant:
    Champion:
  • 237 Answers
Is there an ok key that you can use or select or even try to hit the menue button again
Posted on Feb 11, 2009
Remove wide screen
In order to change the picture settings that affect picture size use the button on your remote marked aspect. If you want to change picture settings such as color, brightness, etc., use the menu button and select Picture, then hit Ok to enter that menu.
Feb 08, 2015 | Panasonic Viera TX-32LX70 32 in. LCD TV
Need to change tint, color on screen using the remote of course
Since you do not provide the make and model number of the TV so we can look for the user manual for you to read on how to make adjustment to your TV.
You just have to get to the MENU button on the remote for the ON screen setup menu and look for Picture adjustment set up to adjust the Pictures.
It should show Brightness, Contrast, Tint, Color adjustment choices.
Jan 03, 2011 | Televison & Video
Need help adjusting the color. It is really dark.
Have you used the menu button on the remote to select the factory choices like Standard Vivid or whatever this set calls the easiest video selections?
Hit menu to see what comes on screen and use the up down or left right buttons usually in the center of the remote.
Then in the ctenter of them hit enter or select to see f the picture changes.
The same can be done for Audio and others.
Oct 19, 2010 | Vizio VA26L 26 in. LCD HDTV
Bought a 19inch LCD Insignia TV yesterday at Best Buy. Everthing works fine except the picture won't fill out the whole screen. Can't find anything in the menu to adjust this.
On you remote control or panel buttons press the menu button. Using you on screen menu, use the up and down arrows to find the Settings Function, use right arrow to enter sub-menu. Use the up and down arrows to find the aspect ratio setting. Use the right arrow to enter the sub-menu.From here you can change the picture setting to : Normal wide 1: Wide 2 : Zoom: Cinema. Once you found your preferred viewing picture, set you choice with the enter button. Then use the menu or escape buttons to close the on screen menu. I hope this helps you with your problem.
May 15, 2009 | Insignia LCDTV26 26 in. Television
What is "OPC"? It comes up and goes away.
OPC_ Optical Picture Control
Automatically adjust the brightness of the screen.
You can change the settings in the menu option.
It's in Menu, then picture, then OPC.
OFF- The brightness is fixed at the value set in "Backlight"
ON- Automatically adjusts
ON: DISPLAY- Displays the OPC effect on the screen while adjusting the brightness of the screen.
If you don't want the silly display from popping up all the time, go into to menu and change the setting to ON; instead of ON: DISPLAY
Apr 20, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Need manual for nokia 447za computer monitor
It sounds like the edges of the video displayed are looking like they are curved in/out? I'm racking my brain trying to remember the terms used on CRT monitors and all I can come up with is elliptical? It has been awhile since I have messed with one. In any event, start pressing the buttons on the display working from left to right. You should hit the Main Menu right away. Generally speaking, there should be a factory reset function as a last choice. If you see that, highlight it and hit the accept button (it's the one you pressed to get to that screen). In the event you don't come across that, look for a Positioning choice and enter that screen. Your choices are generally a + or - for each setting. Press away on each choice increasing or decreasing until you find the correct settings you're looking for. If you're unsure of how to get out of a choice, do nothing for a few seconds and the screen will default back. Let me know if I need to clarify anything or you need a little more help. Grandkids are pesky but I've always found them worth it!
Feb 13, 2009 | Nokia Computers & Internet
Westinghouse LCD TX47F430S
I had the same problem on my 42 inch from westinghouse and all i had to do was hit the FIT button on the menu and/or remote and the screen adjusted to fit screen. hope this helps
Jun 19, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Locked up factory settings on My Olevia
On the remote, hit the "Menu" button and then press the down arrow until you see "Picture," then hit enter, now hit the down arrow until you see "mode" and hit enter again. You should then see "power up" displayed. Hit enter again to get to the setting choices where you can change the mode back to "home" (hitting enter one more time) then exit the set-up menu.
Jun 07, 2008 | Olevia LT32HVM 32 in. LCD Television
Poor picture quality from 130 degree viewing angle on my LCD tv
It is unfortunate but "off angle" viewing will compromise the picture especially on larger TV's and LCD. Off angle viewing can come from the vertical axis or the horizontal, as you described. This is clearly illustrated with a laptop computer. Adjust the screen forward and back (vertical plane) and you will see very clearly that you get the brightest picture in a very small amount of range of the screen. Likewise, viewing from the side compromises picture as well.
I also don't believe that the delay is indicative of any problems.
Apr 10, 2008 | Televison & Video
Computers & Internet Logo
547 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
