Question about Energizer ER-HM650 UPS System
Battery back up supply
My 600VA Microtek inverter is delvering Battery back-up supply instead of main supply when inverter switch is made ON.
    New Friend:
Fan is not work in his inverter output bt any outher supply presents when fan is work..
Posted on Oct 22, 2013
    Guru:
  • 290 Answers
It is possible that the fuse for the input of power is broken or bad
Posted on Feb 27, 2010
I need okaya inverter battery where i can buy.
Hello sandy you are looking batteries at cheap prices there many places and store that sell okaya battery but i suggest you the place where you buy okaya inverter battery. Visit on batterybhai.com a largest place of okaya brand and its prices are best instead other.
Oct 03, 2013 | Computers & Internet
Microtek ups (HGE600AZ) battery not charging
7008757961 I want to resale my preown ups Microtek Heritage 600VA HGE600AZ
Jan 21, 2013 | TriPro Power : UPS Pro 650VA (PSTP06) UPS...
In my home using 100AH battery for inverter , want to know wht happens if the baterry is not connected to inverter ? Is battery life decreases..? or WHAT ELSE WILL HAPPENS TO BATTERY ..? plz give an...
It depends upon the type of UPS.
A true UPS requires a battery to be connected to the inverter at all times. Mains power is used to charge the battery constantly and battery is required to continually supply power to the inverter which then converts the voltage to mains supply voltage.
A lower powered and cheaper type UPS areswitch-over types, when the mains supply fails, the UPS switches over to thebatteries and the inverter in milli-seconds which then supplies mains power to thecomputer and peripherals.
This type UPS may operate without a battery, but it depends upon the design of the UPS and the battery error detection system In most cases I doubt it can operate without a battery. You can try the UPS without a battery, make sure the battery terminals do not short against each other.
Dec 21, 2011 | Televison & Video
Hi, I have Microtek 810 Inverter, it is charging properly, problem starts when mains goes off and inverter is in Battery mode, then output of inverter shows no voltage, even i conected multimeter to...
Good day!
You have to do is:
Check the battery if it is leak.Use a voltmeter to test the output voltage of the battery.If your battery had a low supply voltage even you charge it for 3 hours and above.Replace the battery immediately.
Thank you and good luck.
Apr 21, 2011 | Vacuums
Last week i was out of my home for a week so all the load was off. but when i returned i noticed that my Electricity meter was advanced by 25.2 Units and my 600VA Microtek Inverter was indicating the...
Please dont vote me down as I'm speculating at a guess. Please repost your question if i cant help you.
Do you live in an area with ice, water or snow. Do you have a power cord connected to it laying anywhere near those. You may have a short on any device. Batteries do lose charge though i'm not sure how much "units" means as a value. Power transformers generally have diodes, so you may have a problem with that to ground.
So check for shorts. Unplug everything, turn off charge power and see how much is lost over a day to test your batteries.
Jan 20, 2011 | Kitchen Ranges
Can i have all the basic details of UPS system
UPS come in two types, lower powered cheaper types are usually switch over power.
These units senses a power outage and then switch over to the battery power to generate mains supply. The switch over occurs in milli-secs and does not affect the computer.
True UPS types constantly run off battery power to generate mains supply so there is no switch over time lag. These units are higher powered and higher costs units.
Both type of UPS have the same components.
Battery charger.
Batteries
Inverter that converts battery voltage to mains voltage
Electronic controls
Dec 16, 2010 | Emerson PowerSure Personal 500VA...
When UPS is shut down the lights go out on front pannel but power remains on plugs. It is coming from the AC side not the battery.
The UPS has a fauly/problem.
If your UPS is approx. 600VA, then it is not a true UPS unit but a switch over type. When the mains power fails the UPS switches over to the battery and inverter in milli-secs to provide mains power.
If you turn off the mains supply and shut down your UPS, but you are still getting mains power, then there is a fault with the switch over circuit.
You need to get this unit serviced.
Oct 12, 2009 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
Dead appearing ups/inverter
keep on your main switch. off all the lights fan and other electrical items, let that inverter get charge first
Jun 18, 2009 | APC Back-UPS CS 500VA UPS System
Energizer ER-HM650 UPS System Logo
372 people viewed this question
Top Energizer Computers & Internet Experts
Tom Chichester
Michel Laprise Sr
Are you an Energizer Computer and Internet Expert? Answer questions, earn points and help others
