Question about Canon PIXMA MP460 All-In-One InkJet Printer
My MP460 printer wont grab paper and feed through
My printer grabs the paper crooked and then it says error paper jam. How can I fix this
  • 2 more comments
  • aussie237 Feb 16, 2009
    canon mp460
    the paper starts to feed but gets jammed on the right hand side causing it to pull to one side.the printer gives a message of a paper jam or no paper.The printer is only a year old and only gets used sparingly
  • jenna_rogers Feb 17, 2009
    How do you replace them?
  • Randall  Trahan
    Randall Trahan May 11, 2010
    This happened to me last week so I'll take a stab at it and see if it is the same situation. Look on the back of the printer and see if there is a back panel you can take off. Sometimes paper gets jammed in the back and is not indicated as paper jam but it makes the print crooked on the paper..
  • avinerseiler Jul 20, 2014
    That didn't help at all!
    Sergeant:
    Champion:
  • 237 Answers
It sounds like the pickup rollers are worn or damaged and would need to be replaced
Posted on Feb 11, 2009
Jam in duplex area
Its is trick..If its more then two pages print, printer grabs second page even first page in duplex unit., here its confusion. Check with simplex single print, see any paper mismatch error? or printer throwing paper in output bin after successful print?. No.. check fuser out sensor or paper out roller.
Print only two pages matter in duplex, check where paper struck? if paper our roller not grabbing paper back properly in time (slipping while grabbing back) gets jam error.
Always ensure that select proper paper size in printer.Other than this it may major issue, need technical knowledge..& possibilities are less to judge the exact problem..
Keep update us to resolve the issue.
Aug 22, 2014 | HP Color LaserJet Professional CP5225dn...
Error paper jam
Hello Cassandra,
It sounds like you are having phantom paper jams. When the printer starts a print job and tries to pull a piece of paper but can't grab it the printer thinks there is a jam but there really is not. If the paper pickup rollers are worn down they are not able to grab the paper correctly to feed it into the printer which causes this type of error. The rollers are considered user installable and come in a kit with the rollers and the paper separation pad which keeps more than one paper from being pickup up at the same time. Installing the paper feed kit should clear up your paper feed problems. The paper feed kit is available here: http://www.ccl-la.com/catalog/product_info.php?products_id=342
I hope this helps.
BuddyMc
Aug 06, 2013 | HP CP3525N Color LaserJet Printer
I have a Canon MP495 printer. It grabs the paper crooked and then it jams. I use regular copy paper for my print jobs. I took the paper out of the printer, and it grabbed and jammed. How can I fix my...
Same problem. Turned out to be a small nut lodged in the array of small rollers, just behind the ink cartridges. Managed to lift the roller bar at one corner, and shake it out.
Oct 15, 2012 | Lexmark X73 All-In-One InkJet Printer
Epson RX680 Scanner Error msg and noise
If you only purchased it on the 8/9/09 then it is still under guarantee so the cheapest fix is return it for replacement.
Aug 24, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Canon ip2600 keeps grabbing the paper wrong, only grabs it on the right side so it feeds in crooked and jams.
you need to see the left roller and determine if broken or needs cleaned. to clean use an eraser,thats the best way. if broken i suggest new printer. have a great day and please rate bama46, thanks.
Aug 18, 2009 | Canon PIXMA iP2000 InkJet Printer
Every time I try to print, the printer grabs the paper crooked.
There's a leaver where the paper comes out, make certain it's to the left when printing with paper and to the right for envelopes.
Jun 14, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Feeder grabing the paper crooked causing jams and paper unable to go through the feeder smoothly. it stops once the feeder grabs the paper.
set the paper tray size to the size of the paper...if this is ok...clean the pick upo roller with damp cloth and soap water...if this doesnt help ...change the pick up roller..
keep me posted
May 04, 2009 | Computers & Internet
Paper goes crooked the jams
both wheels are not grabbing , they need to be cleaned
Oct 15, 2008 | Lexmark X1150 All-In-One InkJet Printer
Canon MP460 "np paper"
Canon PIXMA MP460 error code 5010
Sep 04, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Paper keeps getting jammed in MP460
I had the same paper feed grabbing problem on pixma MP 610 printers - take a flashlight and look down into the feed rollers inside - deep - I found a paperclip in one and a hair clip in another - you need a pair of very fine pincer pliers to extract so you dont damage the roller assembly's made of plastic - and voila no more misfeeds and grabbing on the right side - hint - dont put anything on top of the printers because when you lift the scanner cover, it nicely slides anyting on top into the paper feed assembly and results in a jam
Steve
Aug 02, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
896 people viewed this question
old marine
old marine
