Question about Brother Sewing Machines
Yamata FY7568 only stiches ----------
I bought my machine brand new and it worked fine for a bit, i tested different stiches and they then started to get worse and worse, unitil all the different stiches came out -------- . now my machine only stiches a line. please please help.
thanks tom
    Scholar:
  • 69 Answers
Have you changed your needle? If you have a dull or bent needle it can cause the machine to not lock the stitches together and the result is a straight stitch on every pattern. Also, check your stitch width selector and make sure that it did not get accidently moved.
Posted on Feb 12, 2009
I have a second hand Yamata FY7568 sewing machine, and the bobbin tension is too tight. The instruction book says it is factory set and does not need to be altered. What can I do, please?
I was also looking for yamata manual can:t get it on internet but got it from Ricoma you can mail them on service@ricoma.us and the will send u the pdf file may be a fee if you didn:t purchases the machine from one of there dealers
May 08, 2017 | Yamata Sewing Machines
The stiches become loose after few seconds after i start sewing
I had a problem similar to this-- when sewing, tons of thread was bunching and looping out of the stitches instead of a nice neat stitch. I finally figured out that this old metal bobbin I put in was incompatible. I switched to a plastic bobbin (the kind like that which came with the sewing machine) and the stitches looked fine.
May 21, 2014 | Yamata FY812 Mechanical Sewing Machine
Yamata FY 920: Lost the manual. Can't figure out
Stitch length dial on the front.
Mar 05, 2010 | Yamata FY920
Yamata FY14U4AD
The easiest way to get your threads adjusted and learn which thread does what is to thread the machine with 4 different colors. Set your tension dials at 4,3,2,1 from left to right. This is the starting point. Sew on a test strip and look at the threads. You can then adjust the correct tension dial according to the thread color. This is a great way to get the machine set back to correct tensions as well as a learning tool to figure out what each thread looks like so you can adjust later when using all one color.
Feb 25, 2009 | Yamata FY14U4AD
Yamata FY7568 Machine not sewing
Make sure the correct needle is installed on the machine. Domestic needles will have one flat and one rounded side on the shaft. Make sure the flat side of the needle is on the back and the groove on the needle also being to the back.
You might also want to make sure the tip of the needle is not broken.
Other than that, your machine could be out of timing.
Jun 19, 2008 | Sewing Machines
Yamata FY811 sewing machine: looking for the English manual instruction
You can find the FY811 manual directly from their website at http://www.feiyueusa.com/Manual/FY811.pdf. Hope this helps.
Nov 19, 2007 | Yamata FY811 Mechanical Sewing Machine
Sewing Machines Logo
190 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
