Question about Philips Magnavox 9P6034C 60" Rear Projection Television
The pitcher is blury and need to be ajusted , how do i do that
Its blury and the color is off , it to bright
  • Philips Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions the pitcher is blury and need to be ajusted , how - 2c07611.pnggence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screthe pitcher is blury and need to be ajusted , how - 578ba6c.jpgdull, red/orange, etc. You may even see halos around images.
the pitcher is blury and need to be ajusted , how - 65af323.jpga set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 12, 2009
I need to know how to adjust for the for clairty of the wording ( to blury to read it)
On the front side of your tv under the screen you have a box with little dials on it. This is your focus and brightness control. There should be six dials. 2 for each tube. Turn the one that says focus for each color slowly one direction or the other until the picture looks clearer.
May 18, 2012 | Hitachi Televison & Video
THE TRANSMISSION WILL SHIFT GOOD AND AT TIMES IT LOCKS AND WONT DRIVE OR REVERSE.
well first check transmitton fluid when the trans is at normal operating temps if that is normal
look at the color of the fluid it should be bright reddish color then if it is brownish or any other color than bright reddish or smells burnt you have an internal trans problem.
now if the color is reddish and does not smell burn there are numerous other things that can cause that such as clogged trans filter , shift linkage is loose or needs ajustment , or faulty shift sensors ,
or trans speed sensor that tells when to shift
May 05, 2011 | 1999 Kia Sephia
My tv is almost 6yrs old and all of a sudden the picture is blury almost showing double images. The color is also of at the top and bottom of the screen.
this is typic old projection tv, some tecnical ajust parameters have reset, so if you can adjust,this settings on service menu on tv, or ask for help on local repair store, to calibrate scren.
Nov 29, 2009 | Televison & Video
PICTURE NOT AS BRIGHT AS I WANT HAVE TRIED ALL . TV IS HD REAR PROJECTION . I HAVE TRIED ALL AJUSTMENTS,COLOR,TINT,FORMAT,SHARPNESS, BRIGHTNESS ETC. LAMP ONLY ONE YEAR OLD.
Unfortunately there are 2 IC's and a capacitor that can cause this set to be really dark. Without proper troubleshooting it is impossible to diagnose. Have a shop check it out for you. Thanks
Oct 27, 2009 | Hitachi 50UX58K 50" Rear Projection...
Picture djust
Put it in the custom mode.Put the contrast to the max.Put every things in middles may be colors for less.Now u have the desire ajustment u want?
Aug 19, 2009 | JVC AV-27530 27" TV
Magnovox 9P5531 C102
you need to change the coolant in the CRTs. Thats a common problem with the blue and green CRT in phillips magnavox rear projectionsIt makes the color and clarity as good as new after the coolant has been changed. If you need more info let me know, as there is a kit that has the coolant for all 3 tubes and CD with the step by step instructions with pictures available.
Jul 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
Sharp 32sf560 TV
Good day
You an adjust the screen brightness on the rear portion of your units flyback. Then the intensity of the color will change.
chris
Feb 02, 2008 | Sharp 32C241 TV
Need to find out how to adjust color
im curious why you think you need to ajust the color do you have red screen? or missaligned colors?
If your B&W images look okay (bright and dark areas), either films, ads,
or turing the color off, you shouldn't tinker with grayscale
adjustments. You'll really mess up your set. Haven't seen many
complaints about 'red push' with Pioneers, but that may be the problem.
A further check would be the decoder test on the Avia disc. Also visit
http://www.hometheaterspot.com/ and search the Pioneer section for
similar complaints.
Nov 16, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Blury pictures
change the resolution setting in setting. and also you can adjust diplay bright ness and contrast for bets view & pics .thsi will solve the problem. Thanks Sangita
Jul 08, 2007 | Samsung Digimax S500 Digital Camera
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
49 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
