Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Xerox XD 100 has L 6 appearing Nothing in the book about it.
Can this be fixed easy Love this machine just bought two toner cartiages for machine want to be able to use them
  • 2,072 Answers
L6 indicates a problem with the laser. Ususlly the problem is a worn out motor that rotates the mirrors in the laser.
I have seen a couple of times, the ribbon cable that connects to the main board from the laser just have poor connection. You can take the back off the machine and reset the connectors on the main board. But more than likely the laser will need to be replaced.I looked it up, and there are 2 different lasers for that machine. The prices are between $300 and $400. Wish I had better news for you. It is also not an easy replacement.
Posted on Feb 12, 2009
Can you reset toner level in Xerox DocuColor 260?
Usualy what i did i use toner chip (100%) fix it to toner cartridge then insert to machine, check the amount if 100% then pull out the toner cartridge and replace old chip insert back to the machine, check it will be 75%.
Sep 05, 2014 | Xerox DocuColor 242-252-260 PS
I have a xerox xd 100 work center laser printer...i have a constant paper jam problem...the paper feeds and it does not go into the black gadget in the machine that gets hot....i have blown out the machine...
I have seen this more times than I can count. The problem you have is definately a broken fuser drive gear. The fuser unit is the black unit you refer to that gets hot. It has 2 fuser rollers that heat up and fix the toner onto the paper. One of the rollers has a drive gear on it that goes bad and breaks after a time. You just need to have someone replace the gear. I have included a link to the part that has a picture of the part. Also keep in mind that your machine is made by Sharp and is nearly identicle to a Sharp AL1000 model which may make it easier to find a local person that can install the part.
Good Luck and Thank You for using Fixya.
Sep 29, 2010 | Xerox Office Equipment & Supplies
Xerox XD 100
I would first try opening the right side cover and inspecting the corotron. There is a small opening where there is a very small wire. Check for a small piece of paper in there. It would block the transfer corotron voltage and cause that line.
Then remove the toner and drum. Look at the toner cartridge and see if you can determine if its out of ink in that area. Then look inthe machine with the drum and toner out. Locate the laser and see if it the glass **** is dirty in that ares or blocked.
By the way. if there is no paper in the transfer wire, take some alcohol and clean it with a q tip to remove contamination.
Nov 09, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
How to refill the cartiage of a xerox work center m20i
You have to pop the top cover off the cartridge and empty the new ink into it.
I doubt though that the metering blade that dispences the ink onto the roller will last another toner cartridge cycle. But good luck.
Jul 20, 2008 | Xerox Office Equipment & Supplies
Xerox 7750 issues
Did I not erspond to this ? Seems like i had but getting this question back. Let me know please.
Mar 12, 2008 | Xerox Phaser 7750DN Laser Printer
New cartiage/not reconized
It says there is no cartridge, or does it say that the cartridge is empty?
First, you must realize there are two cartridges. A drum and a toner. If you bought a new toner, pulled out the drum and put the new toner in, you have pulled a DOH! You can't just put the toner in. You have to take your old drum cartridge, remove the toner portion and install the new toner into your old drum and then install the entire assembly back into the machine. I hope you didn't throw your drum out thinking it was all one cartridge (I've seen it happen). This is where reading the owner's manual helps.
If not, then one of the contacts must have been damaged. Remove the cartridge and look inside the machine. See if you can find any of the metal contacts on the side of the inner chamber that is bent or damaged and try to bend it back.
Check the drum and make sure none of the contacts are damaged.
If the unit is still saying Toner Empty, try this. On the left side of the toner there will be a while lever in a semi-circular notch.
Unplug the unit, use a small screwdriver or a key to push that white lever back to the front of the notch. Put the drum and toner back into the machine and plug the power back in.
Nov 29, 2007 | Brother IntelliFax-2820 Laser Fax
Do you have the operators manual? Run it through a cleaning cycle. Also Xerox's website will guide you through some maintenance steps. If you are using generic wax, you may have clogged the jets.
Aug 02, 2007 | Xerox Phaser 8500/DN Printer
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
145 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
