Question about Konica Minolta bizhub C250 All-In-One Laser Printer
ERROR CODE SC45-20 MINOLTA 500
BIZHUBPRO C500 ERROR CODE SCB45-20
Transfet belt off alignment
Posted on Mar 11, 2010
Color registration problem Restart copier and leave the front door open,will bypass the error code page.Press HELP,then press KEY OPERATOR MODE, scroll down to 21 EXECUTE ADJUST OPERATION, select COLOR REGIST AUTO ADJUSTMENT, then press OK, PREVIOUS SCREEN. After adjusting, it will back to normal. If the code number back on again, then it was the transfet belt off alignment. If you know how to pull the transfer back to center position, problem solve, if not, call technician.
Posted on Mar 27, 2009
Bizhub 211 error code c500
ihave error code c5oo c501 in bizhub 211
Jan 16, 2013 | Toshiba E-Studio167 Copier
I have konica Minolta bizhub pro c500 when i power on this machine the lcd shows massage sc41-03 please assist. Thank You Very Much
The 41-04 is a failed cyan write unit, or a failed suction/ exhaust fan. You can test fans m43,m44,m45,m46. In 47 mode, code 42, multi code 6.
Good luck
Jun 15, 2012 | Konica Minolta Bizhub Pro C500
Konica minolta bizhub pro c500 error code sc29-19
check, the drums, no scratches, if good the surface of the drum, interchanges the drum, for example, move the drum cyan to the drum yellow.
Jun 07, 2012 | Konica Minolta Bizhub Pro C500
Porque sale error c0500 en la dialta 470
plz chek the thermostate heater unit fuse and heater lamp and clear truble button and relase this code c500
May 28, 2010 | Konica Minolta DiALTA Di200 Copier
Error code C0500
C500 is a fuser code, the hot part of the machine, the fuser fuses the toner to the paper, so that the toner does not smear off. But to solve this must have the model number. As each series of machine has a different way to reset machine
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 21, 2009 | Konica Minolta DiALTA Di200 Copier
ERROR CODE SC45-20
HAVING A REPORT CODE SC 45-20 HOW TO SOLVE IMMEDIATELY FOR PRINTER/COPIER BIZHUBPRO C500
Feb 11, 2009 | Konica Minolta bizhub C250 All-In-One...
Minolta Dialta620 copier error code c-0000
Code C0000 if a fuser motor failure.
Check to see if anything is damaged in the fuser (the thing that gets hot).
Also, check for a jammed transparency (if you use them).
Feb 10, 2008 | Minolta DiALTA Di620 All-In-One Laser...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
2,275 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
