Question about Akai LCT2060 Television
No signal just bought an akai 2060 and I can not get a signal from my dish network setup. I have it on channel 73 just like the old tv but all I have is a blue screen. Can you help?
  • 335 Answers
Call Dish and ask them is there any firmware you need for your tv....they should provide it for you.
Posted on Feb 11, 2009
Hi, my Phillips was hooked up and working fine directly to the DISH receiver using the HDMI 1. I moved and had to put the DISH receiver in another room and ran a coax cable to where the TV is now using...
Hey murphypat321,
Sounds like the TV may need to be on ch 73 cable rather than 60 air. Try switching the TV to 73, if it goes to 69 then put back on 60, if goes to 73 good. Once you have that set go to your TV1 and bring up the menu. Go to System Setup (6) -> Installation (1) -> Modulator Setup (5) and change the TV2 setup to either cable if on 73 or air if on 60 and the picture should come in if everything's hooked up.
Hope that helped! You can email me at if the problem persists.
Tommy Faust
DISH Network
Mar 09, 2011 | Philips 42PFL5332D 42 in. LCD Television
Our new vizio tv is hooked up just like our old tv, (satellite provider being dish network) and it says no signal with a blue screen
Hello. This is usually an easy issue to fix. To get the DISH Network back on the screen, i have included a few steps:
If you are at TV1, where the receiver box is located, the tv needs to be on channel 3 or 4. Depending on the cable that is running between the receiver and the tv, the tv may need to be on an input, such as video 1 or 2. If you are at the TV2 location, where there is no receiver, then the tv needs to be on channel 60 or 73.
If you are using an HDMI cable, then the TV will need to be on an HDMI input
If you are using Component cables, your TV will need to be on a component input. (Usually Comp 1 or 2)
If you are using RCA cables, then the TV will need to be on a VIDEO input (Usually Video 1 or 2)
If you are using COAX cables, then the tv needs to be on channel 3 or 4 (If you are at TV2, then the TV needs to be on channel 60 or 73)
Becki Barned
DISH Network Customer Service
Feb 26, 2011 | Vizio VX32L Television
I bought a new TV for my #2, but is says I'm not getting a signal when I hook it up to the cable. I have it on channel 60
You can go to TV 1 to make sure TV 2 is suppose to be set to channel 60. Did you run the auto setup on your TV? If you have already run the auto setup on your TV, unplug the receiver from the electrical outlet for 10 seconds and then plug it back in. This will make the receiver reboot and re-acquire satellite signal. Then see if you get a picture on your TV 2. If not, the last thing you can try is changing the channel from 60 to 73 through the receiver.
With your DISH remote at TV 1, press the Menu button - Main Menu will display on the TV 1. Then press 6 (System Setup), 1 (Installation), and 5 (Modulator Setup). On the Modulator Setup screen, move over to TV 2 Out and select Cable, then press select on the remote. This will automatically change the channel from 60 to 73. Highlight Done on the right and press select. Cancel out of each screen till you get back to the TV screen. Go to TV 2 and put the TV on channel 73. You should get a picture. I hope this helps.
Ray Calo
DISH Network
Feb 16, 2011 | DISH Network ViP622 DVR DTV Receiver /...
Trying to setup tv 2, just upgraded the tv from an old school analog set to a brand new phillips 40pfl3705d/f7. can't get a signal on the tv and have tried both "air" and "cable"...
Hi carltonmarcumy name is Mike Houston of DISH Network and for the TV2 you want the Modularset to cable and channel 73, and then make sure the TV itself is set to channel73. After you have the modular set to channel 73 and the TV set to channel 73and you do not see a DISH Network picture you will then make sure theconnections from the wall to the TV are tight as well as from the receiver tothe wall. Then you will want to unplug the receiver for 10 seconds and plug itback in it will power up and acquire the signal and once you see that check TV2and you should see the same thing on the screen. I will send a link that will helpout with these steps.
Feb 13, 2011 | DISH Network ViP622 DVR DTV Receiver /...
New jensen jdtv-1020 won't see either air or cable signal as TV2 with Dish DVR 625. An older Emerson color TV sees cable 100 but the new jensen does not see it during auto detect.
Hello, Matthew Gonzales with DISH Network customer service here. First thing to try is putting the TV on channel 73. At TV1, press menu on the remote, followed by 6-1-5 (system setup-installation-modulator setup), make sure that TV2 out is on cable mode, which should default to channel 73. If you're still not getting a picture, try performing a hard reset on the receiver. To perform a hard reset, unplug the receiver from its power outlet, wait 15 seconds, then plug it back in. The receiver reboots (which can take about 5 minutes), then check TV2 again. If there is still no picture, make sure all of the cabling is secure, and bypass any other devices (VCR, DVD player, etc.). If this does not fix the problem, please feel free to email me at and I will make sure we get this taken care of for you.
Dec 27, 2010 | DISH Network DVR-625 DTV Receiver /...
Need to change channel to 73 so my dish tv will work, it seems the highest channel tv set will go is 69
We would be happy to help with that. Some TV's do not havethe ability to go as high as channel 73; this may be the case for your (enterbrand here). We would recommend changing the channel that your DISH Networkreceiver outputs the picture for your TV2. Start by pressing the"Menu" button, from the main menu press 6 for "SystemSetup", then 1 for "Installation", and then 5 for"Modulator Setup". Under TV2 we are going to change the mode to"Air", the channel displayed beside it should change to 60, selectdone on the right side of the screen to save the changes. Now change thechannel of your TV2 to 60 and you should get the DISH Network programming. Wehope this helps. Thanks so much for being a valued DISH Network customer! Phillip Chang DISH Network Customer Service Representative
Nov 30, 2010 | RCA 27F530T 27" TV
I need to get to channel 73 to connect to Satellite Dish network, but it keeps telling me there is no channel in list ???? what do i do..Thanks
We would be happy to help with that. Some TV's are not ableto go as high as channel 73. This sounds like you're having an issue with yourTV2, this would be the TV located in a different room than your DISH Networkreceiver. Go to the main TV by the receiver, press the menu button located onthe top left of your DISH remote. Once in the main menu, press the numbers6-1-5, this will take you to the "Modulator Setup" screen. Once there we want to highlight the "Air"option located below "TV2 Out" then press the select button. TheChannel should change from 73 to 60. Change the channel of the TV you arehaving an issue with to channel 60; you should get the DISH Network programmingat that point. We hope these steps help you get that fixed. Thank you for beinga valued DISH Network customer!
Phillip Chang
Oct 16, 2010 | Haier HTF20 20" TV
Unable to to get cable channels in modulator. Set to cable, channels 73/75 but "connection" grayed out. Cable signal strong. Able to read Digital channels on Local set up with same i/p.
The connection button is not utilized from the "Modulator Setup" screen. When changing the channel for TV 2, you can arrow over to either air or cable and pressing select. This will select that option and change the channel to either 60 for air or 73 for cable. Once this selection is made then you would move to the "Done" button and press select. You will return to the "Installation" menu, then cancel out till you are back to the TV screen. I hope this helps.
Ray Calo
DISH Network
Dec 16, 2009 | DISH Network ViP622 DVR DTV Receiver /...
I accidently changed the channel that I receive satalite tv on, dishnetwork can't solve the problem. TV will not take more than one number & dish tells me the channel should be 60 or 73 help
Is this a tv2 off of the primary reciver from another room?
If so there is a 2 step process to help you fox this.
Generally yes it is 60 or 73 but some installers do change it.
If it is on 60 The it will be on 60 AIR not 60 CABLE , if it is on 73 then is will be on 73 CABLE not 73 AIR..
To simplify this for you go into your tv's menu and select your air/cable type to air and have the tv do a channel scan. once complete use your remote and go up and down the channels in air mode it may find more than one. check and see if any of them are your dish box. If not then go back into the tv menu and select your air/cable setting to cable and repeat a channel scan. again once complete use the tv remote to go up and down channels untill you locate your dish box. If you do both of these and still do not have your signal verify that there is no VCR or DVD player "ON" at that location. They can be hooked up, just not on. Also some tv's have an antenna A and antenna B on the back of them , if your does make sure you test with both antenna connections. If you go thru all of this and still cannot get a signal then a line may have gotten cut or dissconnected and they need to send a tech out.
Sep 24, 2009 | Akai 20" TV
Akai LCT2060 Television Logo
146 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
