Question about Whirlpool Duet GHW9150P Front Load Washer
F11 start wash cycle it runs a while then says f11
    Master:
  • 623 Answers
These error codes are not specific FDL can mean door latch failure .it can also mean the ccu board has failed also F11 can mean mean anything from motor to motor control board to ccu board to wiring harness connecting ccu to mcu to motor. if you do not know how to diagnose with out error code you may end up buying wrong part. sometimes doorlatch is not problem central control board CCU is
Posted on Feb 11, 2009
Error F11 during the wash cycle
The error means that the controller is not talking to the other components. It is very expensive to repair,. If you want to run tests on it, there is a tech sheet behind the kick panel under the door.
Feb 09, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whash machine
The symptoms are pretty specific for the F11 code on the Whirlpool Duet front loaders and clones (Kenmore Elite and KitchenAid):
If the washer starts to fill but the drum NEVER moves, your MCU is bad
If the washer runs through most of a cycle and then gives the F11 before (or during) a rinse or spin cycle, then you have the CCU relay problem.
If you are interested in having me repair your CCU for you, I offer that service on eBay (website coming soon). My username there is "jhagner"
Thanks
Feb 04, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Washer code F11??? I have a Kenmore Elite front loader
F11 Serial communication error
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
Possible causes/procedure:
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
Service manual and more HERE
Aug 22, 2011 | Kenmore Washing Machines
I keeg getting the dreaded F11 anf DL code!
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
F11 code on kenmore frontload washer HE3t
My f11 code is repaired! I got a clamp from Home Depot put it on the ccu unit on the right side tightened it shut and haven't got the stinking f11 code ever since. No more banging it again! I can finally do my wash without the horror beeping sound going off every time.
May 23, 2010 | Kenmore Washing Machines
Kenmore Elite HE3T washing machine code F11
Kenmore Elite HE3T washing machine error code F28, what does this mean?
Jun 26, 2009 | Kenmore Elite 45986 Front Load Washer
Getting F11 code r8ght after starting,then flashes and stops
usually if this is a kenmore frontloader f11 is a communication error between the door lock and the ccu board. usually you'll hear a clicking sound before it fails. If so you need a central electric board. It is located directly under the top lid in the back. you can't miss it it's the only thing that has a lot of wires going to it.
Jan 02, 2009 | Kenmore Elite 45986 Front Load Washer
Duet GHW9160PW0 F11 Issue
not related to shake, issue, but hte f111 and dl issue def sounds as if the connection between the 2 has been compromisdd, in my experience it has been a faulty CCU, losing communitcationsd with the door latch thus the f11
Dec 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F11 Error
probably bad control bd remove top control mounts to rear rail ck all wiring to control first just f11 usually indicates internal control failure
Nov 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error F11
Plug off the wall. Shaking & vibration of your washer causes circuit board connections to become loose; due to faulty manufacture. Remove the 3 or 4 screws from the back & take off the top cover to secure the connections, make sure they are tight. This applies for the F11 & F dl codes. Works for certain machines, dont see why it wont for yours.
Dec 10, 2007 | Kenmore 46462 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
325 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
