Question about Acer TravelMate 341T Notebook
Acer travelmate 4650, after bios flashing, no display.thanks.
Removing cmos battery for 20 minutes did not solve problem.
  • macleannana Feb 26, 2009
    i flashed my bios with a lower version of file 2.20 and the system shows light but does not display
  • ashish13
    ashish13 May 11, 2010
    what is the problem exactly cuz all i can make out is that you flashed ur BIOS... please post the details mate :-)
  • Acer Master
  • 4,806 Answers
HI there
Sounds like the bios flash has failed, the only thing you can do now is try to flash again, make sure you have the right bios update for that model machine, suggest you get a USB floppy drive so you are able to re-flash the bios, if it still doesn't work then the machine is rendered useless.
Good luck and thanks for using Fixya!!!
Posted on Feb 11, 2009
WHAT IS THE MASTER PASSWORD TO BYPASS THE BIOS PASSWORD
No such creature. Best way to resolve the issue is to locate the cmos battery and remove it for a few minutes after disconnecting the power wire and removing the battery. Also jump the cmos clear jumper - usually around the battery. After five minutes or so, the default bios will be there with no bios password.
Apr 27, 2014 | Acer TravelMate 4740
Reset bios password acer Travelmate 2410
I know some methods to reset bios password.
1. The best and easiest method: Close OS and shut down the electricity power of computer. Open your computer box, take out the cmos battery from the mainboard. Then the bios password will be reset to blank. Put it back after a few minutes.
2. Follow some tutorials. For example the tutorials:
Reset ACER Aspire 3610 BIOS Password - Only 8 Steps
Top 3 methods to crack bios password!
3. Use the bios password recovery tool , but that is not free!
So I would suggest you the 1st method. Hope it helps.
Jan 09, 2011 | Computers & Internet
How to Disable Acer Travelmate 240 BIOS Password?
To disable the bios password on your laptop, you will need to remove the cmos battery on your laptop for some minutes and insert back, the cmos battery is located on the motherboard of your laptop, once the cmos battery is removed from the motherboard for some minutes, the bios password will be reset, and the bios password will be disable.
Take care.
Nov 19, 2010 | Acer TravelMate 240 Notebook
How can I remove BIOS Password from Acer TravelMate 230/280 MS2132 laptop?
Use a Backdoor Password
  • 1
    Go to the Technibble website and locate the manufacturer of the BIOS for your computer. Write down the backdoor passwords that are listed.
  • 2
    Restart the computer and press the "F2" key to access the BIOS.
  • 3
    Enter one of the backdoor passwords to see if you can access the BIOS. Repeat this step until you find a password that works--but keep in mind, sometimes three wrong guesses will cause the computer to lock up.
  • 4
    Change the password for the BIOS to something else, then exit and restart the computer.
  • Remove the CMOS Battery
  • 1
    Unplug the computer from the wall outlet or power strip. Remove the screws on the back of the case that secure the side panel. Slide the side panel off and then locate the round CMOS battery that is attached to the motherboard.
  • 2
    Examine the battery to see how it is attached to the motherboard. Pull on the latch to release the battery and then remove it from the motherboard.
  • 3
    Wait about 20 to 30 minutes for the electricity in the capacitors on the motherboard to discharge or dissipate.
  • 4
    Set the CMOS battery back in the motherboard. Set the side panel back in place and the plug the power cord back in.
  • 5
  • Nov 09, 2010 | Acer TravelMate 2303LCi Notebook
    Acer 4650 Travelmate Black screen
    Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
    Feb 21, 2010 | Acer TravelMate 3260-4874 Notebook
    I cant remember the start up password for my old acer 520 travelmate how do i boot my laptop please
    The older Acer computers stored their passwords in the CMOS, so all you have to do is remove the CMOS battery for 30 minutes. Here is the proper procedure to do it correctly.
    Disconnect the ac power adapter and remove the laptop battery. Push the power button for 10 secinds to drain any residual power. Remove the CMOS (RTC) battery for approx. 30 minutes. Replace the CMOS battery and attach the AC power adapter only, leave the main laptop battery out for right now. Power the laptop up and let it post. If it still asks for a password, leave it blank and try hitting enter. If it accepts the blank entry and posts, then you can enter the BIOS and change your settings.
    Below is the link for your service manual to assist you in the removal and tear down of components for your system.
    http://tim.id.au/laptops/acer/travelmate%20520.pdf
    Nov 26, 2009 | Office Equipment & Supplies
    Same problem but have got acer travelmate 4150
    Check on motherbord again you can find cmos cell it is look like round battery cell.
    Then pull it for 10 minutes so all bios settings are defaults.
    Also you can clear bios with jumper find jumper on motherbord it has 3 -pin 1-2-3 right now jumper is in 1-2 position set it to 2-3 position so your bios is clear.Then again set it to it's original position.
    then it not ask for password.
    Let me know if you need more assistance.
    Thanks.
    Sep 29, 2009 | Acer TravelMate 240 Notebook
    Where is the cmos battery for an acer aspire 1690 laptop
    CMOS is usally on the back side of the laptop. you might have to take the back panel off. The bios is flashed onto the board its really not a chip that is interchangeable it is just there to hold the info for your bios
    Feb 12, 2009 | Acer TravelMate 2300 Notebook
    Bios password problem
    try this,
    members have reported that they were able to remove their Acer BIOS passwords by simply opening their notebooks and removing the CMOS batteries for 30 minutes.
    Once your BIOS password is removed, you will need to press the <F2> key during POST (Power On Self Test) to enter the Acer BIOS setup.
    if that don't work, acer support charges 100.00 to reset the password, What a rip-off.
    Jul 12, 2008 | Acer TravelMate 2500 Notebook
    Acer TravelMate 341T Notebook Logo
    1,026 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
