Question about Sony RMV210 Remote Control
Sony rm-v210 remote problem
I have a rca hd tv and direct tv. We purchased the sony rm-v210 remote to use. We went through every code but it still wont program. I called the number they give you for technical support and got no help...does anyone know how to program this remote with direct tv?
  • kathimontgom Feb 11, 2009
    we purchased the sony rm-v210 remote for our direct tv. we have an rca hd tv ...went through all the codes but it still won't program. we called for technical support but received nothing. it clearly states that this universal remote will work with our tv and direct tv...any help or advice?
  • Sony Master
  • 19,396 Answers
On the manual below codes for RCA Tvs are not provided.
Manual : RM-V210
To program the remote you have two choices.
1 Call the Sony Customer Support Helpline at 1-800-822-2217.
2 Follow the Searching for code procedure illustrated in the manual and below:
"1 Press SET more than two seconds. The SET indicator lights up.
2 Press the Component Select button for the desired component.
3 Press CH + or CH – and POWER in turn until the component
reacts as follows:
TV, DVD Home Theater: Powers off
Other components: Powers on
Press CH + to go to the next code number.
Press CH – to go back to the previous code number.
The SET indicator flashes once after the numbers have turned one
cycle.
One cycle means, for example, that the commander finishes
searching all the component code numbers allocated to the
component.
4 Press ENTER.
The SET indicator and the Component button turn off.
If the SET indicator flashes five times before turning off, it means
that the setup is incomplete. Start over from Step 3.
If the component does not operate properly, repeat steps 1 to 4 and
search for another code."
Please leave me feedback on this.
Thanks.
Posted on Feb 12, 2009
    President:
  • 2,110 Answers
Turn the DVD on, and then on the RMV210 Remote you press Set until the light comes on (2 seconds), the DVD key, and then I kept pressing the Channel Up (+) key followed by the Power key -repeating as quickly as I could- until the DVD went off, and then I pressed the Enter key. It only took a little while, 20 or less tries I'd guess. Good luck
Posted on Feb 11, 2009
  • Sony Master
  • 4,806 Answers
Hi there
Use the code search :
Searching for the Correct Code
You can find a code number available for a
component that doesn’t have one in the
supplied “Component code numbers.”
Before starting the Search function
Set each component to the following status so
that the Search function works effectively.
TV, DVD Home Theater: Power-on
Other components: Power-off
* If any of these components are assigned to any
of the Component Select buttons, you can set a
component code using the Search function.
reacts as follows:
cycle.
component.
4 Press ENTER.
If the component does not operate properly, repeat steps 1 to 4 and search for another code.
Good luck and thanks for using Fixya!!!
    Top Expert:
  • Sony Master
  • 77,514 Answers
Did you use the code search feature of the remote? check the instructions, this code search is for just such a problem as yours.
  • Sony Master
  • 13,433 Answers
Hi
if you have gone over all the codes available the remote wont function with the spesific tv and I would suggest trying another remote.
Sony, RM-V210. need code for Electrohome TV.
This remote control have no setup codes to Electrohome TV. If you wish to get more codes and other details check:
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/ It has setup code list, and setup procedure to many popular brand remote controls. View the site in 'Mosaic'. It will make search easy. If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability.
Jan 03, 2014 | Televison & Video
I have a TV remote control sony RM-V210 but I do not have the code to set it up in a toshiba tv
Hi there. The codes you are looking for are written in the manual of the remote controller and here they are:
8205, 8014, 8052, 8060
Jul 16, 2010 | Sony RM-V201 Remote Control
Lost manuel owner for sony rm-v210.....I need codes for tv electrohome
go to sony.com they should have an online manual for your remote. look under support
Apr 26, 2010 | Sony RM-V201 Remote Control
Sony rm-v210 codes
According to the manual it is 8083.
You can download the manual on this link. You don't need to put in your email address to download, I didn't.
http://www.retrevo.com/support/Sony-RM-V210-Universal-Remotes-manual/id/7048bh151/t/2/
Just click on get manual then follow the download instructions minus your email, but you have to put in the numbers just above start download. These number keep computers from automatically downloading and crashing sites.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
I try to provide the best FixYa experience.
May 10, 2009 | Televison & Video
Olevia 232t remote code
Go to Best Buy and buy the DirectTV Universal Remote Control Model RC64 ($20). It will control both the Satellite Receiver and the Olevia TV (Everything on the Olevia except the A-B-C-D Guide buttons). The Remote Control User Guide lists the control codes, four for the Olevia. The codes are:
Satellite Receiver: 00392
Olevia 235-T12: 11610 (last of the four codes listed for Olevia)
Enjoy!
Nick from Ft Myers
Dec 21, 2007 | Directed 434MHZ Remote Control
Sony RMV210 Remote Control Logo
61 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
