Question about Yamaha Electric Guitar
On power up there is a loud humming even with volume at 0
I have a Yamaha G100-212Guitar Amplifier. It didnt work when I first got it. I replaced both of the power output transisters.Powered up and played the guitar for about 5 minutes. Then I turned it off and I turned it on again there is this loud humming noise.
I have the schematics. Any suggestions whats causing the noise?
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Check same transistors again and driver transistor in amplifier section.
On power up my kurzweil micro piano has no audio out and loud hum
Posted on May 21, 2010
I would also be inclined to check all the larger electrolytic capacitors in the power circuits as well for AC bleed.
Posted on Feb 24, 2009
Yamaha emx 88s
amplifier module faulty, it may even damage your speakers if it had dc on the speaker terminals. have a qualified technician to check and confirm all components.
Dec 11, 2014 | Yamaha Music
I have a Technics PR-305 Digital Piano. I was playing a couple of songs on it., then about 5 days later. around the beginning of November I went to turn it on it made a loud humming sound from the sp
Yes it can.....but you will need the schematics and some test gear in order to do it.....and a soldering iron....what do you mean by no surround on the speaker?? Can you post a pic??
Nov 25, 2014 | Music
After hooking up the PA for practice, I heard a loud "pop," then followed by a burn smell, from my Mackie SRM 450 speaker, which I use as a monitor. No sound comes through but static and crackling. Is the...
The pop itself isn't necessarily a bad thing, but a burn smell and the fact that it's only outputting a crackle likely means that the built-in amplifier circuitry has been overloaded. This can happen a few ways:
1) Faulty power, either a bad cord or a bad outlet
2) Plugging the output of a power amplifier into this speaker - because it has a built in amplifier, this speaker only wants a non-powered line input
3) If the Thru output is (accidentally) plugged into anything that provides phantom power, that could overload the circuitry.
4) A short due to liquid or moisture contact - these cabinets are most certainly not waterproof
In any case, the amplifier part of the circuitry IS replaceable. If you're not comfortable buying one and replacing it yourself (I'd recommend eBay), take it to any shop that sells similar items. If you're extremely lucky, it was just a fuse that needs to be replaced, but chances are you'll need to replace the whole amp.
Aug 19, 2013 | Music
Hum when volume at 0
with or with out a guitar plugged in
Mar 08, 2013 | Fender Hot Rod Deluxe Guitar Combo...
I left my fender frontman 65r on for over a year and yesterday a gentle hum for a few seconds then a loud hum for a few seconds more then no more power to the unit. I opened it and troubleshooted it around...
Why was it on for over a year :D Has anyone replaced the fuse? In the service manual I found it has to be only 2 Amps! Okay let's solve the problem. The power transformer was overloaded which caused the broken winding. It is still overloaded what can be heard by the hum sound. First thought was to check main capacitors or better just replace them! If the hum gets louder, they might also become warm. Check voltages after bridge rectifier and smoothing circuit. They should be +/-42 V (TP3, TP4) and +/- 16 V (TP5, TP6) Let me know which of them is faulty Cheers
Feb 11, 2013 | Fender Frontman 65R 65W 1x12 Guitar Combo...
My amp makes a loud foghorn type noise whenever turned on. Even if i have the volume turned all the way down and the guitar unplugged it still hums. I'm not sure if its an amp or speaker prolem. I took...
Likelly the TDA7293 chip in the power amp has failed. It shorts to one power rail and drags the power down where it hums... this CAN damage the speaker if left on. Verify the problem and replace the chip. Slight chance there are bad electrolytic filter caps but those are easily spotted.
Aug 06, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
I bought a factory refurbished xga-3000 gemini amplifier and conected it to my behringer mixer expecting a thump. but it barely sounded like a sound of earphone at maximum volume. I read power supply to...
A large amp like this likely has protection circuit (probably a relay) that doesn't connect the speakers until the amp is stable and balanced. You relly need the schematics for the amp.
Jun 21, 2011 | Gemini Sound Products GEMINI XGA 3000 3000...
Useing a Peavey XR 800F Powered PA Mixer/Amp which develops distortion on output after around 60 minutes. Also had gear linked to all inputs at the time, three mics, 2 guitars and keyboard. Any ideas...
First of all confirm if the speaker impedance is not lower then the recommended Ohms at the back of the Mixer speaker socket.You can use an 8 Ohms speaker on a 4 Ohms amplifier but not vise versa .
Next see if the fan on the mixer works. If not the Amp is getting very hot and this will lead to unwanted distortion. You can confirm if its a heat related issue by playing the mixer at low volumes for more than an hour and see if it distorts.
Apr 26, 2011 | Peavey Pv 2600 Power Amplifier
Aux1 and 2 are not working...what is the fix on the emx5016cf yamaha board
You are NOT trying to drive speakers from the aux outputs are you? These are LINE outputs that should be using TRS balanced lines to either powered speakers or amplifiers. Often these are used for monitors. The monitoors MUST be powered versions or use external amplifier if the speakers are passive..
Apr 26, 2011 | Yamaha Emx 5016cf 16 Ch 2x500w Powerd...
How do I hook up two powered 15's and two passive 15's to this mixer(1202-VLZ3)?
You connect the powered 15's using balanced cables. The passive speakers you will have to get an amplifier for as the mixer does NOT have a powered output, only line-level audio outputs.
The powered speakers MAY have audio line level outputs to continue to other powered speakers or, as in your case, external amplifiers to drive your passive speakers.
Remember to power ALL interconnected equipment from the same receptacle or source to avoid ground bounce faults that can destroy sensitive circuits in your equipment.
Mar 05, 2011 | Mackie 1202vlz3 12 Channel Mixer
Yamaha Electric Guitar Logo
589 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
