Question about NetGear RangeMax WPN824 Router
I keep losing my wireless connection.
The orange no service light randomly comes on and off. I can pick up other neighborhood router, but not my netgear WPN824. Even if I hit repair, it works for a little while then disconnects.
  • 1 more comment
  • Anonymous Mar 02, 2009
    I purchased this (netgear WPN824) one month age and it has been working great. All of a
    sudden, it won't connect. All I have is one laptop connected to a DSL
    line and modem. What happened?
  • bhatiainc Mar 08, 2009
    I'm having the same issue. I have to disconnect power and reconnect it to get it back. How do i prevent this from happening?
  • Anonymous Apr 02, 2009
    Same thing here exactly, except on a Linksys router and a Dell M1530
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Apr 12, 2009
My Sony bravia tv keeps losing connection to the Media server (computer) I can reconnect but it keeps happening randomly daily Please help
Hi there.
I assume that you are connecting wirelessly. The most common problem is that the TV is at the outermost range of the wireless signal from your router/AP. try moving the router/AP closer to the TV. However I would recommend that you use a lan cable rather as this is a more reliable connection. You will also need to check your network settings. To keep the network connection more stable make sure both the TV and media server have static IPs, especially the server.
Feb 03, 2015 | Sony Televison & Video
Intermittent signal. Keep having to reset router because losing signal.
This can be caused by a lot of issues that do not mean the router is bad. Are your lights green? Do you have a good signal (%60 to %70) when it works? There may be a lot of other wireless routers in your neighborhood, using the same channel yours is on. Sign into your router, and look for the Wireless Settings page. Change the channel (it is usually on channel 6) to channel 11, then apply the settings. The router will reboot and apply the new settings and it will take a minute or so for this to finish. I hope this helps!
Oct 01, 2013 | NetGear Computers & Internet
My acer aspire loses its signal randomly then comes back. Other laptops in the house are fine for connection. Any advice in simple terms appreciated as I don't know how to remove acer software for
Have had similar problems with two Gateways that are actually Acer--both two feet away on either side of each other: one or the other will lose connection--so not the units---if move the one not connecting closer (it is 50 feet with 3 walls between it and router) it will then pick up the wireless and work fine--I answer about 300 questions here each week so end up to avoid this in the mud/laundry room where I can depend on the signal and also have a smoke if I want.
May want to as a test move it closer to the router and see if same issue or not.
Apr 20, 2012 | Acer Aspire One AOA110-1588 Notebook
I can log on to my wireless account and get online, but then it i lose the signal, and when i scan, it picks up signal stenght on 90 % but wont connect, I can hard wire it and i get online with no...
The problem lies in the wireless connection. Either the wireless adapter on the game console, or with your wireless router. Although wireless internet makes it easier to get online and play, it is actually the worst choice for online gaming. this is due to the lag time in the signal relay to the router. Wired internet is the best choice for online gaming. If you can hook your console up to a wired internet connection, then I suggest you do that.
Jan 18, 2011 | Video Game Consoles & Games
So I got this Belkin router (N) and the wireless light just comes on and goes off as it feels what up?
On my Belkin router the wireless light only light up when somebody is actually connected using wireless - it also flashes orange when somebody is trying to connect but failing - my router is a F5D8236uk4
Feb 27, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin Wireless G Plus MIMO router - connectivity problem
  • this problem can be ISP releted they may have some issues on the ADSL line connection
Aug 10, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wlan light orange
Orange WLAN light means no connectivity to the network. Try to reconnect to your wireless network and make sure to enter the correct wireless settings like the network key and SSID.
Apr 25, 2009 | Computers & Internet
Blinking orange light
if you got an orange light to the router, It means that there's no Internet connection or not working from the router. I might advice you to check the Internet connection from your ISP, then check the configuration of your router or you might needing to reconfigure the router.
Mar 10, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Adapter no longer detecting ANY connections.
Hi cpjango,
Most routers especially the smaller ones do not have anything that resembles good ventilation.If you touch the router and its anything more than luke warn then its pretty clear that your router is overheating and unless you take a few steps could be at risk of being damaged beyond repair. My suggestion is to make sure its standing in a position where minimal router surface touches anything else.Also keep it away from your monitor, pc, desktop and anything else that produces heat. If it keeps randomly shutting off i would even recommend a small fan or a replacement.
that said I am assuming its not your service provider.
please tell me how this turns out.
Nov 13, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
Connection failure after period of time
If it's possible try moving the router to another telephone point that is nearer to the problem reciever. Unfortunately all sorts of objects can divert the wireless signal, something as simple as a door. If your wireless adapter picks up a signal of 57% it may also be very low on the 'bps' transfer and may only show as limited or no connectivity. The signal to the router may be average but it still has to transfer data to enable a network and internet connection.
Mar 03, 2007 | X-Micro Technology XWL-11GUZX (XWL11GUZX)...
NetGear RangeMax WPN824 Router Logo
1,997 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
