Question about Lexmark Optra T614 Laser Printer
Light prints on one side
When repairing a T614's bell crank I turn the machine on its backside and install the new bell crank. After turning the machine on again I get light copies down the side of the sheet. I have replaced the charge and transfer rollers and still can't get it to print correctly. This has happened a couple of times. Do you have a solution to the problem?
    Sergeant:
    Champion:
  • 237 Answers
Have you tried a new fuser?
Posted on Feb 11, 2009
How to lline up timeing marks
on the crank there is a mark on the engine a mark its like a line on the backside of the engine and a spot on the crank sprocket on the top at the cam should have a hole in the center of the cam sprocket with a red line on the head top near valve cover it should line up properly or if you have 2 marks on the cam sprocket -- one on each side of the sprocket and on the engine side or cover should have 2 marks as well that line up do not take off the timing belt until you have all the marks properly lined up then you can remove the belt but do not turn over the engine without installing the new belt
May 28, 2014 | 1998 Chevrolet Malibu
Windows 7: The system does not accept my old installation disc, does not mattter, because windows7 got the installation process alone. BUT now the problem: For printing double side (frontside and backside...
You should be able to go to your printer, right click and select Properties, select Preferences, make sure the computer knows that the printer has 2>2 (duplexing) capabilities. See if you can't locate a place to select 2 to 2...
Jan 31, 2010 | HP OfficeJet d145 InkJet Printer
When loading paper tray on lexmark optra t614, one sheet of paper comes out of the front. Looks like feed rollers are sitting too low? I dont know what part to buy that will fix it. I guess I could use a...
if the pick wheels are just hanging down you need a bell crank for the auto-compensator this part is 56p1228 turn the printer onto its back this plastic piece is known to break. look to the right its located on the end of the long shaft comming fron the auto compensator and if its broken there should be a spring either in the tray of still hanging from the mount
Oct 28, 2009 | Lexmark Optra T614 Laser Printer
Where is the crankshaft postion sensor on a 2.7L 2003 sebring?
On the front of the motor at the bottom where the crank shaft comes out of the motor, the one with the largest pully, it will be mounted on the outside and has 3 or 4 wires going to it. If you remove and replace it make sure you get the correct air gap or it won't work.
Aug 18, 2009 | 2004 Chrysler Sebring
Invalid engine code
The easiest way to solve this is to work through Lexmark Technical Support.
Their web site may have the correct engine code on their site, but installation of the code can be tricky.
Are you getting a 900 Invalid Engine code message?
Don
Apr 23, 2009 | Lexmark Optra T614 Laser Printer
Lexmark Optra T614 Won't accept toner cartridge
there is a smart chip on the right side top of the toner cartridge clean these 2 connections with thee green plastic brillow on the back of a sponge. just do this lightly. cleaning this should fix your problem
Apr 11, 2009 | Lexmark Optra T614 Laser Printer
T614 is printing very small 2inch by 2inch on 8x10 page
hold right arrow go and return buttons down and hold power the unit up ubtill you see activity in the dispply then release this will reset factory defaults and solve your problem
Jan 08, 2009 | Lexmark Optra T614 Laser Printer
Optra T614 printer
i had the same problem and it went away after i removed the main circuit board and reinstalled it. (left side of the machine)
Apr 03, 2008 | Lexmark Optra T614 Laser Printer
Unisys UDS 25 Printer Problem - Identical to Lexmark T614
check the Technical Support Team for this machine My guess is the drum is on its way out - or some other replaceable control item but they will know.
May 25, 2007 | Lexmark Optra T614 Laser Printer
Lexmark Optra T614 Laser Printer Logo
85 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
