Question about GE Refrigerators
Icemaker leaks into freezer compartment
I have a G.E. model TBX25RPK refrigerator/freezer. The icemaker appears to be leaking causing a large column of ice to form underneath the tray where the ice cubes are made. Any thoughts on what is causing the leak or how to make the determination? Is this a DYI repair or will I need a repair service?
  • MDGalligan54 Feb 11, 2009
    Thanks, I will give that a try.
    Novelist:
  • 121 Answers
MDG,
Sometimes the drainage inlet for the defrost can get clogged and then the frost has no place to go (usually an evaporator pan at the base of the fridge) have you ever felt the side walls or within the fridge and it was warm? When it is working the tray heats to rid the fridge of the frost. The DYI solution is simple but can be frustrating. If the freezer is on top and you can remove the drip tray and the contents for that matter and see the inlet all the way in the back most likely covered in ice, turn of the fridge throw a bunch of towels togeter with sponges and buckets and le the fridge thaw out for the day sopping out all of the water. If you can get to the inlet squirk some hot water with a turkey baster down into the hole and listen for the flow out into the bottom into the tray. Take the back off of the fridge (or access panel at the botom) to see the evap tray. If it is totally dry and looks like it has been for a while then it hasn't been draining. Usually unless a waterline is leaking or broken ice formation is a faulty defrost, huge amounts of continuous water is a leaking suply line. The frustraing part of the DYI solution is if you don't get the blockage free from the line (usually a clear tubing that emties into the evaoprator tray) and put everything back together and restock the fridge about a week later it will start icing up again.
randy32sgi
Posted on Feb 11, 2009
Icemaker leaking despite replacement
is the ice maker actually leaking or do you have a crack in the ice bin allowing it to leak from cubes?
Aug 27, 2015 | Refrigerators
Ice maker leaking into ice storage tray
start with hose replcement buy parts at sears water hose to main ice maker might have crack in it or the stopper is bad get in ther look close with brite light
Oct 14, 2008 | Refrigerators
I have a GE Profile refrigerator, Model PFSS6PKWBSS, with icemaker on door. Water is collecting under Deli-draw and leaking down freezer door onto floor. How do I fix leak?
Hi
Try and access the ice dispenser assembly and check from where the water is leaking. You would need to disassemble the ice dispenser and ice maker to check this. The ice dispenser is located in the upper portion of the freezer compartment. This assembly stores ice made by the icemaker and dispenses ice on demand from the door dispenser target switch.
1. Remove the upper ice bucket tray.
2. Slide out the ice dispenser assembly.
3. Remove the ice cube solenoid linkage Phillips head screw and slide the linkage back.
4. Remove the ice crusher cover Phillips head screws (2) and remove the cover.
5. With a pair of pliers, twist off the backing plate tabs located on either side of the crusher.
6. With 2 small flat-blade screwdrivers, unlock the ice crusher locking tabs located at either side of the ice crusher.
7. Lift the ice crusher out of the bucket.
8. Remove the ice crusher back cover.
9. Remove the locking ring from the ice crusher auger.
10. Remove the plastic nut with a pair of pliers by turning it clockwise.
11. Remove the spacers and blades. The blades are numbered for reassembly.
Icemaker--
The icemaker is located in the upper rear of the freezer compartment and supplies ice to the dispenser tub.
1. Disconnect the icemaker cable connector.
2. Remove 1/4-in. icemaker mounting screws and slide out the icemaker.
This refrigerator is equipped with an Electronic Icemaker.
Hope this helps... Please post back if you need more information.
Daniel
May 01, 2011 | Refrigerators
Ice maker works but either overflows or leaks into the freezer compartment and ice bin making the cubes freeze together. Valve appears to shut off when cycling, and will turn off and not leak when ice...
hello, my name is Marclavoris, i will fix your appliance for you.....okay understand that when your icemaker is on, it sends voltage to water valve, if the solenoid in water valve do not close it will fill the icemaker with water..So replace your water valve and your problem is solve...thanks
Nov 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker leaking
Check two things.
1: see if you have ice buildup in the water inlet tube above ice maker, if you do chance are the water valve is bad, if not,
2: see if you have icicles hanging from bottom of ice maker, if you do you have a bad ice maker.
Either way, will need full model number and serial number both to get you the right part numbers for parts.
Oct 07, 2009 | GE Profile PSW26P Stainless Steel Side by...
Jenn-air side-by-side water dispenser leak
Check the fill tube to your icemaker and see if it has ice in it or in the fill cup to the icemaker. Most of the time when this problem happens it is the icemaker spraying the water. It could also be a bad module on the icemaker which can get stuck in the fill position and spray water all over the freezer.
Sep 14, 2009 | Refrigerators
I have an older ET21DM with an icemaker. Water is
you need to clean the drain after you clean the ice out you should notice a hole run a piece of wire down the hole a couple of times then flush with hot water
Jul 12, 2009 | Refrigerators
Icemaker leaking causing icicles
Is it overfilling with water? If so, it may be an problem with the fill valve leaking slightly. I say slightly because if it were a large leak, the freezer would have frozen puddles in it. Also check the water chute to be sure the water is all going into the freeze tray. Sometimes they can work loose.
If the seam is leaking, there could be a crack in the housing - not sure that's repairable - sometimes epoxy will work (5 minute, 2 part) but it can be difficult for glue to hold on the type of plastic used in an ise maker housing.
Mar 27, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
GE refrigerator, leaking water filter
The area above my water filter in my refrigerator is leaking. I doesn't leak until we run the water in the front of the door or the icemaker runs.I have changed the filer and the problem persists. Is there a part above the filter that needs replaced? The model # is GE TFX26ZPDABB. Thanks.
May 19, 2008 | Refrigerators
Refridge
Sounds like the icemaker mold is leaking so the whole icemaker should be replaced.  Leaking water will get on the icemaker heater and cause condensation which then freezes and makes frost.
Oct 17, 2007 | GE Monogram ZICS360NRRH C... Bottom...
Refrigerators Logo
205 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
