Question about Acer (4432A-002) CD-RW Burner
Reinstalled windows , DVD drive is D: but so is hardrive now !
Hello, well few months ago, had bad virus,.did a windows reinstallation,.finally over weeks managed to sort out, and get rid of other problems, like VirusAlert where time was, etc etc,..last problem is that on the crashed windows section hardrives are C: and D: and dvd rw is E: but on new installed windows,..hardrives are C: and E: and dvd rw is D:
so when just want to copy files from hardrive to dvd drive, a/ dvd drive not shown in mycomputer, can play dvd and cd,s from it by putting in D: in run menu
anyhow, please help if you can, thankyou
  • matt990 Feb 12, 2009
    well have looked in device manager etc,,and it just says in cd/dvd rom drive is working properly, warning signs,...thanks
  • dennis May 11, 2010
    i need to nkow what you see when you go here under cd/dvd drives?
    right click on my computer icon and scroll down and select properties,Click on tab marked HARDWARE, now click on tab marked DEVICE MANAGER,look under cd/dvd rom drives and double click it? what you see may help you fix it yourself , if you see any yellow quiestion marks anywhere else then fix them too ,
  • 67 Answers
Usually the extra hard drive and the DVD/CD are sharing a cable. I have had luck physically swapping the positions they are plugged into. weird, but true.
Posted on Feb 11, 2009
  • 75 Answers
Follow these steps to change the drive letter: Step 1: Open computer management by right clicking on my computer: reinstalled windows , DVD drive is D: but so is ha - 4595def.gif
Step 2. highlight Disk Management and then look for the drive letter you want to change. 73f7bbe.gif
Step 3. click change drive letter and select the one you would prefer for the drives make sure the one that is assigned will not be taken up so you will need to follow proper sequence to assigne treinstalled windows , DVD drive is D: but so is ha - 7581077.giftters in the previous sequence. 7581077.gif
you shud be back to how it was before.gud luck
  • 2,110 Answers
  1. Log on as Administrator or as a member of the Administrators group.
  2. Click Start, click Control Panel, and then click Performance and Maintenance.
    Note If you do not see Performance and Maintenance, go to step 3. Performance and Maintenance appears in Control Panel only if you use Category view. If you use Classic view, Performance and Maintenance does not appear.
  3. Click Administrative Tools, double-click Computer Management, and then click Disk Management in the left pane.
  4. Right-click the drive, the partition, the logical drive, or the volume that you want to assign a drive letter to, and then click Change Drive Letter and Paths.
  5. Click Add.
  6. Click Assign the following drive letter if it is not already selected, and then either accept the default drive letter or click the drive letter that you want to use.
  7. Click OK.
  • Sibananda Jena
    Sibananda Jena Feb 11, 2009
    to change a drive letter
    loadTOCNode(2, 'summary');
    To change an existing drive letter on a drive, on a partition, or on a
    volume, follow these steps:
    5. Click Change.
      if it is not already selected, click the drive letter that you want to use,
      and then click OK.
    7. Click Yes when you are prompted to confirm
      the drive letter change.
My asus x50gl will not play cds or dvds
Try reseatting the DVD/CD drive also reinstall the DVD/CD driver.
If this does not fix the problem then most likely the DVD/CD drive is faulty and then needs to be replaced.
May 09, 2012 | ASUS Computers & Internet
Ok so my compaq presario windows xp home edition service pack 3 cd burner was working fine till just a few minutes ago Windows Media Player said Connect a burner. I unistalled wmp and reinstalled still had...
make sure that the cd burner is getting enough power test all leads that are attached to the cd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 03, 2011 | Compaq (CDD480172) CD-RW Burner
My computer runs so slow and cant play my games on count of it. It needs cleaned up bad and i dont know how to do it. Please help me.
Backup all your files (E-mail, address book, music, license-keys for purchased software),
writing either to DVD-recordable disks, to an USB memory-stick, or to an external disk-drive.
Then, reinstall Windows, "wiping" everything from your disk-drive.
Run "Windows Update" (repeatedly) to get all the latest security-updates.
Reinstall anti-virus software.
Reload your files.
Reinstall the purchased software.
Reinstall the free software (Adobe Reader? WinAmp?).
Nov 13, 2010 | Microsoft Windows XP Professional for PC
> hard-drive bad
If you get a message "press F1 to continue", then do so.
Be ready to "backup" all your files and music from the disk-drive onto a USB memory-stick, or to burn some CD/DVD disks.
Then, replace the disk-drive, and reinstall Windows.
Sep 28, 2010 | Computers & Internet
Hello i have a packard bell imedia x9494 with windows vista few days ago i had installed windows 7 without problems than i had a virus in my computer so i had try to reinstall windows but now they say...
If your hard drive is not being detected, try looking in the bios. I had a similar problem and for some reason the setting for using the hard drive as a bootable device had been changed.
Sep 04, 2010 | Computers & Internet
My dvd drive doesnt open on my Compaq Presario SR2150NX, i finally got it open with the manual open, but im trying to install windows 7 on it, but when i try it says theres something wrong with something...
Check to see if the DVD drive is connected to the power supply and the IDE connectors.
Can your dvd drive be displayed in "My Computer"
If yes, then it is connected, so, you will have to reinstall the drivers. They could be corrupted?
Thank you for using Fixya,
Jan 17, 2010 | HP Compaq Presario SR2150NX PC Desktop
Need to dump my data from my mac to my maxtor external hardrive
you need to backup your system using windows back utility on your computer and save the files to your external hard drive.
Good Luck
Jan 19, 2009 | Maxtor Hard Drive
When the computer starts up. "Gateway" appears on the screen. Then the computer freezes. None of the reinstallation discs do anything. How do I fix this?
Reboot and keep tapping on F8 to go to Safe Mode. Do not put the reinstallation disk yet. Once in Safe Mode select "last known good configuration".
You can also run "Chkdsk" from the C hard drive Properties if you get to Safe Mode. Double click "My Computer", right click on C drive, select Properties, select Tools tab, go to Error checking and click on "Check now" then check "automatically fix file system errors" and "scan for and attemp recovery for bad sectors" and click "start"
If that doesn't work proceed to do System Restore in Safe Mode or remove previous programs that may have caused your Windows to freeze. If you suspect virus, run your anti-virus in Safe Mode.
If none of the above works then try your XP CD (or reinstallation disk) and do a repair.
Jan 09, 2009 | Gateway 838GM (RB838GM) PC Desktop
Open Questions:
Přeji hezký den. Mám velký Přeji hezký den. Mám velký problém s dvd mechanikou ve svém PC. Pc mám cca dva roky a dvd mechaniku jsem sotva využila 5x. Před nedávnem jsem pro svůj pc využila doporučovaný program na vyčištění Cleanr a nechala ho dělat svou práci bez mého zásahu a po té, když jsem chtěla spustit dvd, tak dvd mechanika se mi otevře, vložím dvd a zavřu, chvilku světýlko bliká a nemá to snahu ani začít načítat a tím se tedy ani nespustí. Prostě vůbec nereaguje. Zkusila jsem aktualizovat ovladač (mám u něj vykřičník) a to mi vykázalo, že ovladač je správně nainstalovaný a funkční. Tak co mám ještě udělat, abych vlastně skoro nevyužitou dvd mechaniku ve svém pc mohla používat? Omlouvám se, že se tak rozepisuji, ale bohužel moc nerozumím technickým záležitostem v pc. Softwer ovladače je : HL-DT-ST DVDRAM_GSA-H40N ATA Device model pc: ASPIRE M1100 ( ACER ) rating : 220-240Vac,3.15A,50Hz Opsala jsem co se dalo, pak je tam jen S/N + číslo a SNID + číslo. Budu moc ráda, když mi pomůžete. Dopředu děkuji a přejei krásný den. S pozdravem Bundzíková Světlana
Feb 28, 2017 | Acer (4432A-002) CD-RW Burner
See all Acer (4432A-002) CD-RW Burner Questions
Acer (4432A-002) CD-RW Burner Logo
79 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
