Question about Sony BRAVIA KDL52XBR2 Television
Sony BRAVIA KDL-40S4100 Television 40 inch picture stopped...
I can turn the tv on and the green light on the bottom is on but no picture...i press all the buttons and nothing, and ive even tried moving it to another room... nothing, master reset?... nothing, i called and got a replacement but for the time id still like to fool around with it to see if i can fix this to possibly prevent this problem from showing up anymore...
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    when you power up TV, do you see any display on TV screen?
    You said you got replacement TV and still having same problem?
  • 44 Answers
If the green light stay's on but no picture, meaning black screen! Then you have a bad back light inverter. You can order this at www.shopjimmy.com, select sony then your model number.
If you are somewhat handy you could do it yourself! but it requirestaken tv fully apart. There are a lot of screws that should be baggedseparate as you go along. To ensure tv can be reassembled. follow thesesteps or have a expert do it!
1) remove shell (casing)
2) remove second layer, this will have your signal boards on it (a/v etc...)
3the back light inverter has a metal cover over it, with very tinyscrews. Also you will see multiple wire plugs going into it. Usuallywhite/pink or white/blue.
If this sounds to confusing Irecommend having an expert do this work! If you have found this helpful. Good luck!!
Part is $89.95
Sony Back Light Inverter SSB400W20S01 KDL-40S4100 or Check ebay!!
Posted on Mar 01, 2009
Sony bravia KDL 40S4100 No picture
If you wish to get some details; check the site linked here. Pull up older posts.
Troubleshooting procedure for No-Picture is given in detail.
Sep 06, 2016 | Sony Bravia KDL-40S4100 40 in. LCD TV
KDL-40s4100 power light on, black screen
Main PCB is bad . I just got the information from a Sony authorize servicer price for the part only $504.87
Nov 27, 2011 | Sony Bravia KDL-40S4100 40 in. LCD TV
There is a big block in my TV screen covering 8 to 10 inches. I have a Sony Bravia, model KDL-40S4100, and i bought it in 2008.
if it is a black block, look in the menu under closed captions and see if it is in the text mode. if so change back to cc1 or turn off.
Aug 19, 2011 | Sony Bravia KDL-40S4100 40 in. LCD TV
I also have the same issue with Sony Bravia KDL-40S4100. Screen won't turn on but the power light is on.
The inverter or ccfl lights are faulty will need to be tested on workbench or try on a warranty if still valid
Jan 06, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Colored bars on Sony Bravia LCD Digital Color TV Screen
This is a screen tab fault and in most cases will require the screen replacing
Sep 13, 2017 | Sony Bravia KDL-40S4100 40 in. LCD TV
SONY BRAVIA KDL-40s4100 is not working right
Please check whether the connections are secured between the TV and the connected devices.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Try connecting the TV to a different wall outlet and check if that helps.
Please connect a different device to the TV and check whether the issue persists.
If the issue still persists service of the TV is determined.
Jun 18, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
Theres no picture on my sony bravia KDL-40S4100
Try pressing the TV/Video button. The problem could be that the TV is set to an input with no source.
Feb 11, 2009 | Sony BRAVIA KDL52XBR2 Television
No Picture on TV when Power is on
This seet should provide some diagnostic help. The standby light should be blinking a repeated count with a pause. Post that count here. Also, is there sound?
The above info will indicate the problem circuit which will then suggest the remedy.
Thanks,
Dan
Jan 19, 2009 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony BRAVIA KDL52XBR2 Television Logo
582 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
