Question about Brother MFC-8220 Fax
Brother printer problem- "noise" on printed paper
Recently I noticed three grayish dots on the paper that came from the brother mfc-8220 printer. Thinking it was maybe dust or something I used one of the air cans you buy to clean computer parts and sprayed it into the print. The printer was dirty, dust and all, but that didn't fix the problem. Actually it made it worse. Now not only do I have three dots down the left margin, I have "fuzz or noise" all over the paper making the paper look a bit grayish. How can I fix this
  • iancrook85 Feb 19, 2009
    I tried this and it didn't work, it even got worse. So I changed the toner. This fixed the dust but the three dots are still there and even more dark than before. The dots are all exactly 3.75 inches apart, don't know what that means but I thought it was interesting. Can anyone help?
    Tried this and still had the problem so I changed the toner. This fixed the "noise" problem but I still have the three dots, 3.75 inches apart. The dots are darker now than they were before. Help!
  • 215 Answers
3.75" apart points to only one thing and that is your drum unit.
hth,
razors
Posted on Mar 30, 2009
    Scholar:
  • 75 Answers
When you open the front door to replace your toner. The part that you put your toner in is the drum unit. pull that out. Remove the toner cart. blow the unit out.
( DO THIS OUT SIDE, TONER WILL BLOW OUT OF THE DRUM UNIT )
On the top of the drum unit there is a blue or green slide lever move the lever back & fourth 15-20 times.
re blow out the machine with drum unit out.
Reinstall the drum,
make 5 copies ( 1st feow will be bad hope thay will get better )
If not need to determan if the drum is bad or the fuser asm is cuasing the problum.
( part that melts the toner on to the paper )
Need to do a 1/2 print test.
1. make a copie or do a report
2. when the paper is 1/2 way thrugh the machine but not in to the fuser open front cover.
( may need to tray a coupel of times to do ot right )
3 look at the paper see if marks are on the paper.
( If not then the fuser is bad. if the marks are there the drum is bad )
Hope this help's
Posted on Feb 11, 2009
I have a Brother MFC 8460N that prints three black dots down the right side of each page when going through the printer. I have tried cleaning and it does not work. The black dots show up on copies as...
Measure the distance between the dots and that will give you the answer to which roller is causing the problem I believe the Drum is the only roller large enough to just cause three dots.
Aug 28, 2013 | Brother MFC-8460N All-In-One Printer
Black marks like a grid on left side of paper
I am a technician for brother printers. Yes it is your drum unit that is printing the grid on the unit. go our web site www dot tonerconcepts dot com and place an order for a drum from us. The drum your machine uses is the DR520/620 Our online price is $120.00 with free shipping
Aug 23, 2012 | Brother MFC-8480DN All-In-One Laser...
My brother mfc-8220 printer does not want to print. the drum was broken and i replaced it and the toner but yet i hear a grinding sound followed by an error message saying paper jam. I removed the paper...
it might be that the drum replaced is tighter or the space to pass with in the drum is less. friend did u replace the drum of a same model and same type?
May 12, 2011 | Brother MFC-8220 Fax
Brother multifunction laser printer, model #8220 : can you use color ink cartridges with this model or black /white only?
Welcome to FixYa!
The MFC 8220 is a Laser Printer. It uses Toner Cartridge. Product #TN540 or #TN570. It cannot use the regular ink cartridge.
See full details in this link: http://www.brother-usa.com/MFC/modeldetail.aspx?PRODUCTID=MFC8220&tab=supp
Thank you for using Fixya. Jas247
Apr 03, 2011 | Brother MFC 8220 All-In-One Laser Printer
Brother FMC 8220 manual
You can download/read the manual here (click here). If I am right, you printer model is Brother MFC 8220 instead of Brother FMC 8220 :-).
If I am wrong and need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 03, 2010 | Brother MFC 8220 All-In-One Laser Printer
Brother MFC 8220 -- paper keeps getting stuck in the drum. Replaced drum but still happening. Makes a loud noise when trying to print.
sounds to me like your fuser gear has broken. look for your exit rollers. they're right where your paper exits the machine. while watching them closely, open door, then close so that machine goes through its little warmup. if you don't see those rollers turning, chances are very good that your gear has broke.
hth,
razors
Feb 01, 2010 | Brother MFC 8220 All-In-One Laser Printer
Paper Tray won't raise
The spring that pushes the paper up is no longer able to perform its job. You need to replace the tray.
May 23, 2009 | Brother MFC 8220 All-In-One Laser Printer
Need MFC-8220 replacement adf document support or part number
you can order the part from us, we are an authorized service center for brother.
we can be reached at 310-671-8018
Apr 02, 2009 | Brother MFC 8220 All-In-One Laser Printer
Brother MFC-8220 Fax Logo
218 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
