Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
LCD dispaly is distorted
The display window on handset has 'bars' going through... cannot read messages/stored numbers, etc. What is the problem? Everything else is fine!
  • Anonymous Feb 13, 2009
    I have the same problemthe screen flashes contrast dark light etc, works fine other than that.
    Sniper:
  • 84 Answers
Try disconnecting the battery for 5 - 10 minutes. Sometimes when the handsets get a static shock it will mess up the LCD display, disconnecting the battery will fix the problem a lot of the time. If that doesn't work, you may need to replace the handset.
Posted on Feb 27, 2009
    Problem Solver:
  • 5 Answers
You either need a new battery or some one droped the phone
Posted on Feb 23, 2009
I forgot how to clear the stored voice mails
Les,
If you want to delete the actual voice mails, you have to go through your phone company (using their keypad commands) since voice mail is only accessible through your phone (but the voice mail messages are stored through your phone company provider).
Info from the Uniden DECT 6.0 6035 Manual:
Using the Voice Mail Service If you subscribe to a voice mail service, you can use your phone to access your voice mailbox. The new message LED on the handset ?ashes and VM appears in the handset display whenever you have messages waiting in yourvoice mailbox. When you subscribe to the service, your voice mail provider provides you with the access number and the required voice mail signaling tone. You can use your phonebook to store the access number.
Resetting the Voice Message Waiting Indicator
When you receive a new voice mail message, the new message LED on the top of the handset ?ashes and
appears in the handset display. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state. To reset, press and hold [?nd hs] on the base for ?ve seconds. A beep sounds and the message alert tone is reset.
Here is the manual:
Uniden 6035 1 Owner Manual
Nov 01, 2015 | Uniden DECT 6.0 Cordless Telephone...
Battery doesn't charge
Shirley, check if you inserted the chip properly. Usually the bars are your wifi strength. Most likely its the chip.
Mar 02, 2014 | Panasonic Lands Phones
I have a PANASONIC KX-DT333 with several handsets. On all handsets we cannot dial out . The message LINE NOT ASSIGNED comes up on all handsets.Also we have had no incoming calls. Callers are all getting a...
I don't know about a handset, since mine doesn't have a dial, but the phone underneath the handset has to have a button programmed with the lines you use in order to work. By default, the system has some number of Single CO buttons assigned in numerical order from the bottom to the top and left to right. You can test that by pressing PROGRAM, press the line buttons in sequence, and reading the display. They will say CO 001, 002, 003 etc. If they don't, you can always dial 0 001 store, 0 002 store etc and get the line appearance back.
This solution works in a small system and is very basic. It doesn't take a T1/E1/PRI or group CO buttons. into consideration. Such a solution is beyond the scope of a free forum.
Carl
Mar 13, 2011 | Panasonic KX-T7633 Corded Phone
Setting up my outgoing message: just purchased Uniden cordless DECT 1580. Manual says select command 8. How do I find Command 8? thanks, joan
please follow the instruction to register the handset to base
To register a DCX150 accessory handset:
1. Charge the handset completely.
2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely.
2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink.
3.On the handset, press and hold # until the handset beeps and displays Handset Registering.
4.When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
Thanx
Jul 21, 2010 | Uniden Cordless Phone
The font size suddenly reduced, to too small to
hi
Please try the following
Right click in the middle of the screen, left click on properties, a window entitled dispaly properties will come up, click on the tab that says settings. in this window there will be a slider bar with the title screen resolution slide to the left to nake smaller, slide to the right to make bigger
Feb 11, 2010 | Dell SP2008WFP 20" LCD Monitor
Resolution notice keeps coming up it says press 1 to clear message or 2 to disable message i do and it keeps coming up
Hi
The message on the screen will be something like
your best resolution is 1240 X680
To clear this error what you will need to do is right click on the desktop and click on properties, you will be presented with a window that says 'dispaly properties' click on the tab that says settings. in this window change the resolution (using the slide bar) to match the numbers shown on your monitor
Please can i ask that you leave feedback and vote if this has been useful
Feb 11, 2010 | ViewSonic VA1912w 19" LCD Monitor
Jandy Lite2 flashing LCD display with number 113
Error showing 113 - Had pro check it out, all systems normal (voltages, gas, etc.). Spent $310 and ordered new control assembly from Amazon (pool store wanted $425) installed myself in under 2mins and heater works perfectly again. Zodiac R0366200 Heater Control Assembly Replacement for Zodiac Jandy Lite2LJ Pool and Spa Heater
Jun 11, 2009 | Zodiac JANDY LITE 125K BTU NATURAL GAS...
How do you register a waterproof phone (TWX977) to a TRS9585
Not sure if you still have this problem, but...
Basically go on you base unit, and hit "MENU/SELECT". Scroll down to "REGISTER HANDSET" and click "MENU/SELECT". On your waterproof handset, hold the "#" key until it displays "REGISTERING HANDSET". And voila! After that finishes, your waterproof handset will be good to go!
Feb 03, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
On screen display
This might help you.
Proscan 19LA25Q 19" LCD HDTV at Crutchfield.com Proscan 19LA25Q 19' LCD HDTV: Detailed Info, Features and Specs, and Photos. ... Instruction Manual; Product Registration Card; Limited Warranty Card ...
www.crutchfield.com/ISEO-rgbtcspd/App/Product/Item/Main.aspx?i=68319LA25Q - 46k
Jan 09, 2008 | Proscan 19LA25Q 19 in. LCD Television
Disfunctional Handset
has the secondary handset ever worked. Reason I ask is that it happened to me with a new addtl handset and the problem was that I did not remove the small piece of paper between the handset and the battery which caused only distorted figures to display on the LCD of the handset.
Nov 22, 2007 | Vtech VT 2461 Cordless Phone
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
199 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
