Question about Toshiba Satellite A100-S8111TD Notebook
No Volume at all my Laptop - Lost
No sound/volume on my laptop, working fine till the clean up.
Checked all the usaual audio settings and is fine.
Toshiba, satelite laptop.
Any help/suggestions plz
Thanks
  • 3 more comments
  • macarooon Feb 11, 2009
    Checked device manager, no yellow triangles, everything OK.
    Which is soundcard driver in device manager list?
  • macarooon Feb 17, 2009
    cheers all, thanks for helping
  • 903 Answers
The driver may have inadvertaly been removed. Try going into device manger (in control panel > sytem) and right click the soundcard, click on uninstall. Then reboot the computer and it should be picked up as new hardware and reinstall. If this does not install the drivers for it then go here:
http://eu.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=EU
select your model and download the driver needed.
I hope this helps
Posted on Feb 11, 2009
  • Debs
    Debs Feb 11, 2009
    it will be under sound, video and game controllers
  • 596 Answers
Have you tried reinstalling the audio drivers? Check in device manager and see if you see a question mark by the speaker icon. If you double click on it, it will allow you to reinstall your drivers. Good Luck.
Low headphone volume on laptop
Hi , is the sound working ok on the pc speakers or is it the same.
Apr 09, 2013 | Computers & Internet
I have an HP Laptop with Windows 7 and I have correctly set up my Logitech LS21 speakers, but the volume control does not enhance the sound coming from my laptop. The speakers work fine, but the sound is...
There are 2 volume controls on the audio output in windows 7. one is the system volume the other is the device volume. make sure that they are both at full and then control the sound volume on your speakers.
Jan 20, 2013 | Logitech LS-21 2.1 Speakers
SPEAKERS DON'T WORK WHEN I PLUG THEM IN.
desktop or laptop computer ?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
if its a desktop swap the speakers around if one still does not work its either a faulty speaker or the speaker connection
hope this helps
Sep 19, 2012 | Audio Players & Recorders
No sound through laptop
reinstall drivers
the speaker plug/outlets laptop on the side
hope this helps
Aug 05, 2012 | Medion Brand 12.1 WXGA Matte Laptop...
Dell Inspiron 1100 Laptop with FN Volume issues.
Starbug1S1- This may have been something you have already checked but I will suggest anyways. You said you had control of your sound from other means - Sounds and Audio Devices properties was one- did you notice a check box that reads Place volume icon on the task bar. This may remedy part of your problem if you put a check in the box. Hopefully this helps. Thanks.
Feb 11, 2010 | Dell Inspiron 1100 Notebook
My sound quit working on my presario v6000 it was working fine then suddenly quit the speakers an d the headphone jack on the laptop are not working i checked my drivers they are up too date not sure...
go to control panel>click on sound,speech,and audio devices>click on sound and audio devices>check, place volume icon in the taskbar, un check mute if it is checked,if you see the device volume grayed out, click on audio tab>sound playback>make sure that correct audio device is selected
Nov 17, 2009 | MSI KM2M Combo-L (MS-6738-010) Motherboard
Audio on Dell Webcam Central And voice record isn't working
I have a Dell 1545 with Dell web cam central & I've had this issue. The problem is that Dell web cam central installs it's own microphone settings onto your laptop called something like Dell web cam Live!. This isn't the built in microphone in my laptop & maybe not yours either. You have to change the settings for your computer system & Dell web cam central. Go to start> control panel> sound> recording .. on mine there is an option for Microphone "High Definition Audio Device" ... that is the built in mic. You want that for your default & apply it. Also .. as a side note .. I disabled the web cam central Live! microphone completely from this window. Then open Dell web cam central & go to the "Record Video's" option. In the middle of this is an orange button with a video camera icon. Next to this on the same button is a little arrow pointing down .. click that. Under microphone .. choose Microphone "High Definition Audio Device" just like the sound option in control panel. I've done this & it's completely fixed. I can record videos with sound & use my built in mic in voice/video chat.
Aug 15, 2009 | Dell Inspiron 1545 Notebook
Volume lost
Try this, go to control panel, sounds and audio devices, select audio tab and make sure the sound playback and record are set to your sound card.
I hope this helps.
I have another idea but try this one first and let us know if it works.
Good Luck.
Mar 11, 2009 | HP Pavilion dv9000z Notebook
There is no sound and volume on my laptop.
check for the sound for the required audio might be muted
Oct 03, 2008 | Audio Players & Recorders
Can not tunr volume up on e system 3086
there could one of two things wrong with the volume, 1, the volume control my need a clean or replacing, 2, the audio pcb has packed up and if you cant get it repaired you will need a new one fitted..hope this helps you.
Mar 23, 2008 | Toshiba Satellite A60-S1591ST Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
127 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
