Question about Samsung SGH-D600 Cellular Phone
Slide Connection When i slide my phone up the kep pads dont work,but when its down it does work
  • rapter1995uk Feb 20, 2009
    my screen is rorly fucked up. can anyone help me make this work.
Ok where do you live? uk Plumstead
Posted on Feb 20, 2009
When the phone is slide open, the top 4 buttons dont work
hi :) after reading your pro,i sure that phone ribbon has spoil already. because slide or flip phone.inside the conection are control by a ribbon. after long time slide or flip open/close.the ribbon will spoil. it conect from main board to upper inner keyboard control panel. that mean if ribbon spoil,the menu, options, mail, and calender button do not work.so. send to your nearby mobile shop for repair,change a new ribbon.your pro will solve :)
Jul 06, 2010 | Samsung Propel A767 Cell Phone
When i slide up of my samsung j-700 mobile 3
j 700 open the camera please slide up problem
Jun 01, 2010 | Samsung J700 Cellular Phone
N95 key pad working when phone is switched on but the screen in blank. the very odd time the screen does switch on. would it be a loose connection between phone and screen? and how would i fix? thanks john
Yes this is definitely loose connection. You may need to change the flex cable. Dismantle your phone (You can search for instructions on Google). you might only need to remove your slide.
Mar 03, 2010 | Nokia N95 Cellular Phone
I have a GE Profile slide in range with the F7 code. Will the business card work between ribbon cable and kep pad?
No, this is not an appropriate way to solve this issue. You will need to replace the ERC, in this case. One, or more of the function buttons are stuck. This has caused a short in the control. Replacing the ERC, will correct the issue properly.
Oct 28, 2009 | GE Profile JTP18 Electric Single Oven
How do I change the rotors on a 1996 F250 4wd truck?
CHANGING BRAKE PADS AND ROTORS
Changing the brake pads is pretty easy, after you remove the tire locate the two large bolts on the back side of the caliper i think they are 13/16 heads. remove these two bolts. after the bolts are out use a pry bar to work the caliper straight up off the rotor, slide the pads out of the caliper and compress the piston in the caliper, this can be done with a large c-clamp if you dont have a piston compressor (use the old brake pad as a buffer so you dont damage the piston).
4x2 remove the dust cap in the center of the hub use a pair of dikes to straighten and remove the cotter pin thats locks the castle nut in place then remove the castle nut (can be done with channellocks if you dont have large enough socket) slide the hub off the spindle careful not to drop the bearing and washer on the ground. *** put the lug nuts back on the studs up side down and flush them to the end of the stud if you still hve the stock open lug nuts if not then just be sure to hit the studs square so you dont damage the threads. place the hub on hard solid ground rotor side down and knock the studs out with a fairly good size hammer. reverse process to assemble
4x4 this is a little more difficult than 4x2 you will need some specialty tools (torqs, picks, snap ring pliers, and a 2 3/4 inch rounded hex socket) these instructions are for a stock ford automatic hub. remove the outer hub (three small torqs bolts). use a small to medium straight screwdriver to remove the first locking ring (inside lock) slide the inner hub assembly out of the hub. remove the outside snap ring from the axle shaft slide the three washers of of the shaft keeping them in order. there will be a small half circle keeper on the large nut remove this with a pick use the 2 3/4 socket to remove the hub nut slide the hub off the spindle careful not to drop the bearing and washer on the ground then follow the 4x2 instructions.
Oct 15, 2009 | 1995 Ford F250
My screen on my phone stays black. the music, ringtones,key pad noises, touch screen and phoning people works. basically, everything works but the screen is black all the time. how do i get it to work...
dear,
the strip that connects the keypad with the other circuitry is damaged. you need to repair it or replace it...it will be checked by an expert technician of mobile that either it is to be replaced or repaired...
flip and slide mobile have this kind of problem..moreover, it depends upon the usage of phone for flip/slide...
dont use it roughly, next time , it needs a lot of care..
goodluck..
hope it will fix the issue so dont forget to rate it...
Aug 27, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
White screen on my samsung rant
There is a fix. Ok so what you wanna do is power off your Samsung rant then you take out the battery and put it back in. After that you open to the slide pad and hold down the T and Y keys then power it on while still holding the 2 keys after the Samsung logo pops up then you can let go. Keep the slide keys open while it is powering on. You can close the slide pad when your screen shows up then it should be fixed. Well hope this works for you it worked for my moms phone when she was having this problem. Note: If your phone screen freezes or turns white again just redo the process.
Jun 03, 2009 | Samsung Rant Cell Phone
My samsung J700's buttons wont work
when i try to turn my phone on it only displays the make and model of the phone then switch off and on then repeat the same thing over and over again
Mar 09, 2009 | Samsung J700 Cellular Phone
Sgh-d500 slide problems
i want my bluetooth to work i dont hav any of the equipment to put into it so is there any other solutions
Sep 28, 2007 | Samsung SGH-D500 Cellular Phone
Samsung SGH-D600 Cellular Phone Logo
22 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
