Question about Quasar SP-2723 27" TV
WANT TO ADD EXTERNAL SPEAKER TO QUASAR MODEL SP2723B
BUT THERE IS NO HEADPHONE JACK, ANY SUGGESTIONS?
    President:
  • 2,992 Answers
If you or someone you know is comfortable with soldering electronic circuits, you can solder some long extension leads to the speaker terminals in the set, feed them out through the ventilation slots in the back, and hook your extra speakers to them. Just be aware that the audio output circuit was designed to be used with the speakers in the set only. If Toshiba had meant for external speakers to be used they would have provided terminals for you. You may damage the amplifier with the extra load.
Posted on Feb 11, 2009
My dell latitude d510 internal spk is ready but output headfone jek not working
these are fairly passive in that if a headphone or earpiece is plugged in, they switch the output from the internal speaker to the external speaker. So, it's usually one of a few problems.
  • The jack is mucked up, and needs replaced.
  • The headphone plug wires have a broken connection
  • The headphone needs power to amplify, and that's not working.
If trying another headphone or earpiece you know is working doesn't work, it's the jack itself. They can only handle so many uses before they either fail closed, or open or completely. Depending on which one, either:
  • neither speakers nor headphones work.
  • only speakers work
  • only headphones work
Replacement necessitates opening the case and replacing the jack. For that, there's no help.
Sep 02, 2015 | Dell Latitude D510 Notebook
Vox vt40+
that is because it is two different output channels. eventually you will blow the speaker or your amp. It wasn't designed to handle the impedance of an external speaker through the stereo
headphone jack. Are you sure that your speaker is hooked up or plugged in?
Mar 30, 2014 | VOX Amplification Vox VT40+ Valvetronix...
The sound is gone
it will depend if the problem is only the speaker of the tv itself is bad, you can hooked up external to the headphone jack.but if the problem is with in the amplifier circuit you must trouble shot the circuit first.might the amplifier ic get bad.
Oct 10, 2012 | Televison & Video
External speaker socket
Look on the side of the laptop for the headphone jack. Plug it into the headphone jack.
May 02, 2012 | Computers & Internet
Does the acer aspire 5532 have a sound card or built in microphone?
I believe it has both, strictly speaking it won't be a dedicated sound card as such but the capability will be integrated onto the motherboard. According to Acer Support the 5532 has High-definition audio support, Two built-in stereo speakers and is MS-Sound compatible. The peripheral subsystem has a Headphone/speaker/line-out jack and a Microphone-in jack should you want to add an external microphone for better quality recording.
Apr 14, 2011 | Computers & Internet
I plugged in my headphones, but it didn't eliminate speaker sound. What am I doing wrong? Thanks
Assuming you plugged into the headphone jack, the switch contacts on the jack have apparently failed.
A cheating way to disable the speaker is to plug in a plug that has no connection to the terminals into the external speaker jack.
Mar 02, 2011 | Roland Cube 40XL Guitar Combo Amplifier...
Four weeks ago I bought an iPod Touch 32GB. After listening to my iPod on an external speaker I tried using the headphone and the sound is just too low. I thought my headphone was damaged but I tried it on...
Sounds like plugging the external speakers in has damage the spot were the headphones go in. If this is under warranty that bring it to apple store.
Jan 19, 2011 | Apple iPod touch
Adding remote control activated ''mute'' to TV headphone jack
Generally when the head phone jack is inserted the speakers will get disconnected automatically.
If you are going to use external amplifier you can try the AV sockets. Opening the TV you may require the special screw drivers some times.
Jul 07, 2010 | Televison & Video
Intermittent audio...picture fine
Does this model have a headphone jack? If so, plug a pair of headphones or external speaker into the jack, turn the volume to an acceptable listening level and see if the problem goes away. If so, the headphone jack may be bad.
Mar 02, 2009 | RCA E09344 Under Counter Kitchen TV 9"...
Quasar SP-2723 27" TV Logo
173 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
