Question about Whirlpool LER5636P Electric Dryer
WHIRLPOOL DRYER STPS SPINNING AFTER A FEW MIN OF USE.
About two weeks ago when I was using my whirlpool dryer (ser num: LER7646JQ0) it sudenly stopped spinning. I opened it up, cleaned out all of the lint in it but can't see what the problem is. After reading a couple of other inquiries I think it may be a temp gage. What do you think?
  • 4 more comments
  • Wendy Cartwright Feb 12, 2009
    Thank you for your responce... I have the unit open and the belt looks fine. It starts up fine, it heats and it spinnes, and after a few min it stops. Then I can not restart it for about 30 - 60 min. Do you still think it may be the motor? If it was the temp gage, would the temp gage affect the heating and spinning?
    How can I fix a " Lock out"?
    Does it need to be replaced?
    Thanks for the help, I will try to replace it this weekend and I'll let ya know if it fixed the problem. Thanks again.
    Wendy
  • Wendy Cartwright Feb 18, 2009
    Hello, Happy Wednesday! You were helping me with my problem… I Still need help… LOL
    Well, What is it actually name of the part? I have been looking for part numbers but couldn't find anything. What does it look like? You said it’s located in the back of the dryer (on the lint vent). Can you please help!!! I'm about to go old school and hand a bunch of wet cloths all around my house...LOL
    Thanks
    Hey, I removed the heating element to test your theory but it still cut off in 2 min... Now what do you think?
    President:
  • 1,902 Answers
I would check the belt and the motor. The temp gauge has to do with the heating of the system. You can locate both of those at the back of the unit
Posted on Feb 11, 2009
  • 4 more comments
  • Jeremy Reddick
    Jeremy Reddick Feb 12, 2009
    No, now it sounds more like it goes into lock out which means that it is a limit switch located on the dryer vent
  • Jeremy Reddick
    It is a silver quater sized looking piece. two screws holding itt on mounted on the hard metal pipe of the dryer vent in the back
  • Jeremy Reddick
    Yes you cannot repair the part it needs to be replaced. like 5 dollars
  • Jeremy Reddick
    You are welcome have a great week
  • Jeremy Reddick
    Jeremy Reddick Feb 18, 2009
    The limit switch is located on the metal part of the dryer vent.
    Behind the back plate. It may be called the high limit switch. Or a Trip switch. Get this part It has everything that you will need. Also will come with instructions to install the parts.
    http://www.partselect.com/PartDetail.asp...
  • Jeremy Reddick
    Did you jump the wires together? If you did and it still shut off then it would seem to be a relay or a computer problem. 99.9% of the time it is that sensor that goes bad and causes everything to shut down. That is why I said start there
I have a roper dryer but don't know what year it was made. the model number is REX4635EQ2 the Ser. number is MK0775343. What year model is this?
The second digit/character (K) indicates the year and the 2-digit numbers (07) immediately next to it indicates the week the dryer was made. The year code K is 2000 and your dryer was made on the 7th week of the year 2000 or February 2000. Click on the link below for the table of year codes of Whirlpool and Whirlpool-made appliances.
Determining the Age of Whirlpool and Whirlpool-made Appliances
Mar 30, 2011 | Dryers
I have a Whirlpool dryer...Mod nu# WED5800SQ0,
Sounds like your capacitor has stopped functioning. Most dryers have capacitors ranging from 8 to 10 ohms which store energy and give the drum the initial energy boost to start it turning. Unplug the machine and take off the side that contains the motor. in there you will find a small cylindrical object with two connections, thats your capacitor, replace it
May 24, 2010 | Whirlpool Dryers
Whirlpool gas dryer. Only few min.( less than 5min) heat work.
there is a thermal fuse inside the dryer it is a one time fuse also there is an ignitor that could be bad
Jul 03, 2009 | Whirlpool WGD5300S Dryer
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Whirpool dryer won't heat up
You need to replace the thermal fuse and the timer. A bad timer will over draw a thermal fuse and cause it to blow.
Please remember to unplug the dryer before servicing
Mar 28, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer heat not working
DO YOU HAVE A METER? FIRST CHECK THE DOOR SWITCH,SECOND REMOVE THE BACK PANEL AND CHECK ALL FUSES AND THE HEATING ELEMENT,LET ME KNOW WHAT YOU FIND AND WE CAN GO FROM THERE-MIKE
Feb 24, 2009 | Whirlpool LER5636P Electric Dryer
Ghost in my dryer????
Here are a few ideas of what might be wrong.. based on your description.. You've bypassed the thermal fuse and the dryer worked however once you removed the bypass, did it work after that? based on your symptom.. it appears that one of the auto-ressting 'overtemp snap switches' may be your problem and may be shutting your system down because it is tripping from excessive heat or it is prematurely tripping because it is defective. I've included a website link that shows assembly drawings and parts breakdown for you to examine but I suspect that you have a bad overtemp switch.. ( I assume that you've cleaned out all lint etc from the vent system both inside and outside the dryer) If you haven't... then you may not get adequate air flow and you truly are getting an overtemp condition.. Good luck.. Here is the link http://www.pcappliancerepair.com/model-display.php
Hope this helps !
Sep 05, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool Dryer not heating
first check the circuit breaker in the house, turn it off then back on. if that does not do it then let me know so we can go to the next step. Mike
Jul 14, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool gas dryer
I had the same problem only a few weeks ago.
Read from other forums and found the most common solution: "replace the gas-valve coils."
I ordered the parts, replaced and found that IT WORKS!!
I hope that helps.
May 03, 2008 | Whirlpool LGV4634JQ Gas Dryer
Gas dryer/ whirlpool
well your generating heat which is a good sign, either there is a blockage in your venting() most likely source of issue!) but you say ou replaced, i would then look to replacing the valve coils, 279834, about 20 bucks, easy to replace... its possible that they open the valve upon start up allowing heat, but after being on 20-30 min they overheat and no longer open not allowing heat to generate..
Apr 03, 2008 | Whirlpool LGV4634JQ Gas Dryer
Whirlpool LER5636P Electric Dryer Logo
146 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
